Welcome to the North American Subaru Impreza Owners Club Sunday September 8, 2024
Old 07-16-2009, 09:15 AM   #1
adrive43
Member#: 42008
02 FIZZ GDA R.I.P.
SQC #043
Default Is it possible to swap an 04 STi console into an 02 WRX?
Is it possible to swap an 04 STi console into an 02 WRX? The harnesses look as if they may fit, but the temp control on my 02 WRX has somewhat of a manual set-up- you turn the dial and it pulls on a "temp tube". With STi's "drive by wire," are the HVAC controls also monitored digitally?
adrive43 is offline   Reply With Quote
Old 07-16-2009, 09:34 AM   #2
Phreaker
Member#: 169914
2017 WRX
2021 Onyx XT
You must have not done any searching at all.
The console will swap over directly, the HVAC (temp controls) will not swap over without redoing your wiring harness for your car.
Phreaker is offline   Reply With Quote
Old 07-16-2009, 11:42 AM   #3
SMP
Member#: 206350
2004 PSM WRX
VF30
You can use the WRX Limited which has the same style manual HVAC controls as you do now.
Every other trim piece works okay
SMP is offline   Reply With Quote
Old 07-16-2009, 02:28 PM   #4
adrive43
Member#: 42008
02 FIZZ GDA R.I.P.
SQC #043
/\ Thanks for the info.
I was considering the 05+ STi console swap but seems like more work than I care to do without buying a whole dash out of a wrecked car.
http://forums.nasioc.com/forums/show...into+an+02+WRX
Old 07-16-2009, 02:37 PM   #5
Crawdads
Member#: 30907
SWP GDB-G
...or you could just pick up the shifter trim ring, install it and save yourself a lot of trouble.
Unless you really want the semi-auto climate control.
Crawdads is offline   Reply With Quote
Old 07-16-2009, 03:05 PM   #6
jaypt802
Member#: 149730
2002 Impreza WRX
why no do this get a 2005 sti console expect the trim around the radio/climate controls and for that trim you can use the one out of 2006/07 wrx tr model??????
jaypt802 is offline   Reply With Quote
Old 07-16-2009, 04:40 PM   #7
SMP
Member#: 206350
2004 PSM WRX
VF30
He makes sense!
Find whatever other parts you can uber cheap , but you only have to worry about the HVAC controls/trim from the TR
PS is that an STi cluster in your picture or just a red WRX one
Old 07-16-2009, 09:59 PM   #8
jaypt802
Member#: 149730
2002 Impreza WRX
Originally Posted by SMP View Post
He makes sense!
yes that is an sti cluster....i'm guessing its an 04 sti cluster since the center console trim is from a 04 sti....only thing is the steering wheel looks like its from a 2005 sti
Old 07-17-2009, 09:13 AM   #9
Phreaker
Member#: 169914
2017 WRX
2021 Onyx XT
That's deff a 04 STi steering wheel.
If you do more searching (even under my past posts) you'll find quite a bit information on swaps, I've swapped a few interiors from 02-04 to 05+ interiors.
I hate to say it, but this topic comes up in a new thread more often than it should
Old 07-17-2009, 12:01 PM   #10
jaypt802
Member#: 149730
2002 Impreza WRX
actually thats an 05 sti steering wheel.....
05
04
Old 07-16-2009, 06:07 PM   #11
vecdran
Member#: 162932
2020 Tacoma TRD Bro
Super White
05>04
(I have since painted the STi shift garnish a graphite color.)
vecdran is offline   Reply With Quote
Old 07-16-2009, 09:59 PM   #12
jaypt802
Member#: 149730
2002 Impreza WRX
Originally Posted by vecdran View Post
05>04
exactly what i want to do......minus having it black....
Old 07-17-2009, 03:53 AM   #13
Darryn
Member#: 69370
2007 Legacy GT
I would actually suggest just buying the center vent part (a direct swap with the old center vents and useless excuse for a cup-holder) and swapping it in. You can leave the rest of the center console unchanged. I personally did this and I like the look much better than what the car was originally like, and the cost was very minimal (i got the part used). If you want to do the console swap, there are threads here about it, but it is very involved and involves lots of parts including moving the handbrake (which was the reason I didn't do it, I prefer the handbrake placement in the v7 and early v8; I don't like the late v8 and v9 handbrake placement).
Darryn is offline   Reply With Quote
Old 07-17-2009, 11:36 AM   #14
SMP
Member#: 206350
2004 PSM WRX
VF30
Is the TR a black color or was that painted?
Old 07-17-2009, 11:38 AM   #15
Phreaker
Member#: 169914
2017 WRX
2021 Onyx XT
It comes in the silver color that most dashes come in, it has to be painted if you want it a different color.
I have mine Plastidipped and it looks pretty good IMO, I have multiple pictures in previous threads.
Old 07-17-2009, 11:37 AM   #16
SMP
Member#: 206350
2004 PSM WRX
VF30
PS I just realized he wants the 04 STi console... not the 05+
trying to swap an 05 sti engine into my 02 wrx chinpocoman Subaru Conversions 8 02-11-2009 09:25 AM
Is it possible to look up the IPs used by an AIM SN? vision.dynamix Off-Topic 15 12-09-2008 02:37 PM
is it possible to swap a front end from a saab?? bereda Interior & Exterior Modification 31 12-05-2008 06:56 AM
Is it possible to bridge 4 channels of sound into 2 for more total power? Uber Wagon Car Audio, Video & Security 5 11-03-2003 07:05 PM
Is it possible to create a direct plug in for an ipod? Hope2BinWRC Car Audio, Video & Security 4 07-29-2003 09:16 PM
