04-21-2004, 06:26 PM | #1 |
Member#: 45790
Vehicle:2006 Corvette C6 Z51 SUPERCHARGED |
Limited slip viscous coupling rear differential swap into a '99 Impreza.
After getting my '99 Impreza 2.5RS stuck numerous times (hey, AWD never gets stuck, right?) even with brand new snow tires on all 4 wheels this winter and noticing to my dismay that only 2 wheels spin when I give it gas on ice (not to mention the fact that if it gets pulled into slush when I am driving, giving it gas will make the car pull harder into the slush and get even more stuck) I have decided that I need a limited slip viscous coupling rear differential, such as is used in the 2000+ year models (I'm assuming that this would help a lot if my car is stuck on ice but not bottomed out, is that a correct assumption?). So the question is; does anyone know where I can buy one from cheap? I know some junkyards are supposed to carry them but that is not the case around here; how about an used parts store that sells them online; anybody know of one?
Thanks. Any tips on this conversion would also be very appreciated |
04-22-2004, 09:29 AM | #2 |
Member#: 5218
Vehicle:96L Most Over- Developed Beater |
car-part.com
-Jay Storm |
04-22-2004, 11:29 AM | #3 |
Member#: 177
Vehicle:The 93 W/EJ20K-sold Subaru-less :( |
you will need the axels too if you do this
the output shaft on the differnterials are differnt on SOME of the LSDs http://wac.addr.com/auto/obs/lsd/lsd.html |
04-22-2004, 01:41 PM | #4 |
Member#: 45790
Thanks! Appearently if I can find the LSD of a 2000+ Impreza RS it will fit right in without any other mods... That's what I need
04-22-2004, 03:53 PM | #5 |
Member#: 177
no
the axels are differnt the 99 RS diff has female output shafts the 2000-2001 rs diff has male output shafts <-- also looking for a 4.11 lsd this is a diff with male output shafts it happens to be an non lsd version tho |
04-22-2004, 04:58 PM | #6 | |
Member#: 45790
Ummm... The link above says it'll fit:
Damn, this looks like it will be expensive... |
04-23-2004, 11:45 PM | #7 |
Member#: 48667
You could always get a phantom grip LSD. I think they have been used with success in rally racing and Sport and compact car has used them in some project cars.
There was this auction to: http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT It's make me wonder if we could use any LSD. I mean if all the ring gears match up and the diff is a R160 which just about all suby diffs are maybe the internals are interchangable? This would get rid of the problem of trying to find a matching LSD with the right gear ratio. Any thoughts? -Cybin |
04-24-2004, 01:13 AM | #8 |
Member#: 177
hmm that link sure looks like an open diff .. it not a viscus
04-25-2004, 05:19 PM | #9 |
Member#: 48667
If your refering to the ebay ad, its not a viscus. In fact I'm not really sure subaru has made a viscus LSD. All the ones I've seen are mechanical LSD's.
-Cybin |
04-25-2004, 05:45 PM | #10 |
Member#: 177
there are only two type of lsd sold in NA
1. clutch type r180 in the usdm sti 2. viscus r-160 (in the various imprezas, legacys and foresters) actually there might be a third the svx had a viscus r-180 |
04-25-2004, 08:46 PM | #11 |
Member#: 48667
Jaxx, after looking around you are right. Subaru makes a viscus and clutch type center and rear diff. I guess I was hoping for a mechanical type unit like quaife sells. Wonder if the guy selling the diff. knows or cares that it might not be a LSD.
Regardless, if the internals end up being interchangable this would solve the gear ratio problems. It would be a big help for me with a 3.90 gear ratio, the only LSD with that ratio in the turbo legacy. |
04-25-2004, 11:41 PM | #12 |
Member#: 514
SCIC
Vehicle:07 Legacy Spec B Impreza 93 STI |
LSD 4.111 R-160
Here is what I did to get a LSD. First, I took out a cheap clutch type LSD unit from a 1987 3.90 ratio LSD. It came from a Subaru RX, but it was also in some Nissan models like the Datsun 510. Then because the LSD unit used 12mm bolts and my diff used 11mm bolts, I took it to a machine shop where they drilled out my original to accept the 12mm bolts.
Works well and I have been driving the car since, about 10,000 miles. The LSD needs replacing and I am thinking of a torsen type. Is there any reason you guys know of this could not be done on a standard open 4.111 R-160 Hatachi diff? Mike McBride |
Similar Threads | ||||
02 WRX 4EAT rear LSD swapped into a 02 Impreza OS 4EAT? | Subpar | Transmission (AT/MT) & Driveline | 9 | 08-04-2008 03:10 PM |
Just got my rear differential swapped out under warranty.... what could this sound be | innova | Brakes, Steering & Suspension | 5 | 01-12-2007 08:15 PM |
Limited slip/ lowering springs/ rear sway + more | Rockstar25 | Private 'Wanted' Classifieds | 3 | 11-16-2005 08:41 AM |
todays project: rear differential swap. a little stuck. | LatentWagen | Tri-State Area Forum | 23 | 06-27-2005 01:11 AM |
Possible swaps into a MY93 Impreza L? | Teh Legacy | Subaru Conversions | 0 | 09-09-2003 08:57 AM |
