Welcome to the North American Subaru Impreza Owners Club Saturday June 14, 2025
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 06-07-2023, 02:17 PM   #1
mems3
Member#: 188617
Chapter/Region: PRSIC
2008 WRX Sedan
Default 2018 WRX jumpy turbo psi
Hi everyone! My wrx2018 is a beast works marvelously up to about 13- 15 psi. When I floor it the needle calmly rises until it reaches around 15 psi where it then starts to jump between 12 psi and 20 psi and a loss of power is felt.
What say you?
mems3 is offline   Reply With Quote
Old 06-07-2023, 03:18 PM   #2
desertrat505
Member#: 526234
sounds like a boost leak; check for a cracked tubo inlet, intercooler coupler hose clamps, charge pipe hose clamps. It's a start.
desertrat505 is offline   Reply With Quote
Old 06-08-2023, 02:27 AM   #3
mems3
Member#: 188617
2008 WRX Sedan
Old 06-08-2023, 02:27 AM   #4
mems3
Member#: 188617
2008 WRX Sedan
You are saying it could be the intake part of the turbo? Do these symptoms exclude the downpipe exhaust section?
Old 06-08-2023, 11:28 AM   #5
EvaUnit01
Member#: 511379
2019 WRX
Dark Grey Metallic
From my experience, boost leaks/spikes like that will start in the intake track. I would start at the intake box and work down to the turbo inlet, then from the charge pipe all the way up to the TMIC and throttle body.
On the FA, the most notorious thing to fail is the turbo inlet since it's made of plastic. You have a 2018 so it's been through a lot of heat cycles.
EvaUnit01 is offline   Reply With Quote
