Welcome to the North American Subaru Impreza Owners Club Saturday September 14, 2024
Old 12-03-2006, 04:07 PM   #1
xjordanx
Member#: 111716
2003 2.5RS
aspen white
Default good deal on a 5spd tranny, some questions about a possible swap into a 4eat RS
hello, i came across a fairly good deal on ebay for a 5spd transmission, shifter linkage, drive shaft, rear diff, and all four axles for a 2002 2.5rs (i have a 2003)
what else would i need to make this swap possible? having the tools and workspace to do the swap with isn't a problem for me.
here's a link to the auction
http://cgi.ebay.com/ebaymotors/SUBAR...56558598QQrdZ1
xjordanx is offline   Reply With Quote
Old 12-03-2006, 05:59 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
You need the pedal box, clutch master and slave cylinders and hydraulic lines, a MT ECU (or ground out the TCU wire on your ECU) as well. It doesn't look like te clutch/flywheel is included from the description, so you'll need that and a TO bearing as well. Probably need a MT tranny mount and tranny subframe as well. Make sure you have a proper drift punch for the roll pins on the front axles- it will make your life a lot easier.
Brian
Good deal on some good all season tires Bruce Wayne North West Impreza Club Forum -- NWIC 0 12-03-2008 08:10 PM
Some Questions about STi transmision swap FestaH Subaru Conversions 5 07-06-2007 11:05 PM
Is this a good deal on an engine/tranny? EPskate Subaru Conversions 2 01-24-2006 09:08 PM
good deal on sti swap? ImprezaRSfan! Subaru Conversions 88 05-12-2004 02:57 PM
opinions on a 5spd tranny swap.... merlin8019 Normally Aspirated Powertrain 5 10-21-2000 08:24 PM
