Brakes & Suspension Forum sponsored by The Tire Rack |
01-10-2007, 08:33 PM | #1 |
Member#: 97472
Vehicle:2005 PDX STi Aspen White 12.7@110 woot |
Just got my rear differential swapped out under warranty.... what could this sound be
I have an '05 STi on Cobb sport springs.
Just got my rear diff replaced under warranty because it was leaky. It appears that there is a brand new rear diff installed. When I am going very slow, and then take a sharp sharp turn (like 5MPH) I hear some popping and clanking from what seems to be my front wheels. It happens on the drivers side when I go left and the passenger's when I go right. Could the process of replacing the rear diff have anything to do with this? I don't know exactly what they do so I'm not sure but do know it happened as soon as they swapped it. Any help is appreciated! Please!
01-11-2007, 08:48 AM | #2 |
Member#: 44771
Your diff needs to break in a bit I think. I had the same sounds when my STi was new. Tight turn, clunk, clunk, pop, clank. Nearly pooped myself!
I think you're just fine :-) I've been wrong before though. |
01-12-2007, 04:45 AM | #3 |
Member#: 97472
Hmmm weirdness. I thought it could be the control arms or something. I'm hoping you're right!
01-12-2007, 05:52 AM | #4 |
Member#: 152
Vehicle:2002 Impreza WRX WRB |
Do you have your DCCD locked?
01-12-2007, 02:56 PM | #5 |
Member#: 65065
Vehicle:2004 EJ205 STi 2007 Forester STi |
o2sys has an "identical" problem on his swapped 6speed. send him a PM to find out if it was resolved
plus, you shuold ask this in the drivetrain forum |
01-12-2007, 08:15 PM | #6 |
Member#: 97472
No DCCD is set on Auto, but I know what you're referring to.
I just got the car back from the dealer and they said "Normal differential break-in sounds" and that everything looks tight and correct under my car. I'm going to try reseting the ECU because I hear the center diff has some issues sometimes. ooops about the wrong forum I guess I thought it might have something to do with my car being lowered. |
what could this problem be? | RobK0000 | Service & Maintenance | 2 | 12-21-2006 05:23 PM |
Just changed my rear differential oil and noticed it was overfilled | volkl23 | Transmission (AT/MT) & Driveline | 10 | 04-13-2005 04:09 PM |
What could this problem be? | FIK | Transmission (AT/MT) & Driveline | 7 | 11-21-2004 06:52 PM |
What could this sound mean? Something is Broken? | adamsrs | Brakes, Steering & Suspension | 2 | 04-26-2002 12:23 PM |
I just got my MY02!!!! They are out!!!! | matt7184 | General Forum Archive | 6 | 09-12-2000 05:14 PM |
