Welcome to the North American Subaru Impreza Owners Club Saturday September 14, 2024
Old 08-13-2007, 03:24 PM   #1
boostinscooby
Member#: 91560
2012 STi Hatch
Default Swaping an MY05 STi engine into an MY06 or MY07 STi and vice versa.
Is there any differences between the 05, 06 and 07 sensor/engine harness wise? Im offering up my engine for a swap for a bone stock one and I was just wanting to make sure everything is the same. I know the ECU's are not the same. And I know they changed a few things like the 07 has a different vf series turbo but other than that I believe the engine harness and the sensors are all the same.
Thanks, Brett
boostinscooby is offline   Reply With Quote
Old 08-13-2007, 03:30 PM   #2
boostinscooby
Member#: 91560
2012 STi Hatch
Just noticed that the MY07 STi has top feed injectors. Do they have the same impedance as side feeds? Because everything is getting swapped straight across.
Old 08-13-2007, 04:51 PM   #3
boostinscooby
Member#: 91560
2012 STi Hatch
goodnight bump....
Old 08-13-2007, 05:05 PM   #4
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
www.TriStateTuners.com
pretty much not compatible at all with an 07... i think i mentioned this in your thread a while back?
all of the wiring has been chagned... it would be a lot of effort to swap it all over, especially doing 2 cars.
3 guys worked on my swap for two weeks straight... and a lot of people said that was a pretty quick turnaround.
TROLL is offline   Reply With Quote
Old 08-13-2007, 05:27 PM   #5
boostinscooby
Member#: 91560
2012 STi Hatch
Well STi swap into a wrx isnt fun anyways.
But for an 05 into an 07 and an 07 into an 05 cant you just swap the sensors and harness over? I mean it is the same exact motor and heads. An ej257 is an ej257 right?
Old 10-15-2007, 11:07 PM   #6
lo0nY
Member#: 68583
we dropped in a 07 EJ257 into a 03 wrx, everything works, car runs, did it in two days....only problem we having is trying to figure out how to get the cam position sensor to read the cam on the 07 motor....We got the gruppe s adapter for the sensor, but it still throws the code..
lo0nY is offline   Reply With Quote
Old 10-28-2007, 12:26 AM   #7
TROLL
Top Scoob 006
Member#: 14424
BugI w/ 07 STi Swap
ohhh... just the motor not the wiring or intake manifold or throttle body. phew whe i first read that i thought you did it all and my eyes almost popped out of my head. we did my swap in 2 weeks and that seems to impress people, haha.
Old 10-28-2007, 10:36 AM   #8
MSo
Member#: 5008
2002 /06 STi GGA
SRP
Did you change whole harness? or make the WRX harness work on the STI motor?
How you make Variable Timing solenoids work?
there is two cam sensors on EJ257 right?
So, I'm very interesting how you make wiring work!
Thanks in advance, Mike
MSo is offline   Reply With Quote
Old 10-30-2007, 01:00 AM   #9
lo0nY
Member#: 68583
i took everything on the top end of the old wrx motor and swapped everything that was a bolt on.....i plugged up the oil lines, and used the old harness, everything works....but the AVCS....just having problems with the Cam Position Sensor not picking up
Old 10-31-2007, 05:50 AM   #10
MSo
Member#: 5008
2002 /06 STi GGA
SRP
I believe 06-07 E257 has two Cam sensors on the back of the engine, so are you did the special harness for AVCS?
What about gas pedal and Drive By Wire crap, and how you make this work?
Mike
Old 03-06-2008, 11:38 PM   #11
MSo
Member#: 5008
2002 /06 STi GGA
SRP
What year of your engine?
Old 03-16-2008, 01:18 PM   #12
lo0nY
Member#: 68583
pulled out he 03 motor and dropped in an 07
04 STI 6 speed into 03 WRX and vice versa I'm Slow Transmission (AT/MT) & Driveline 14 08-10-2009 07:52 PM
Swapping an EJ257 STI engine into an RS or possibly WRX Audioexcels Subaru Conversions 0 04-27-2009 12:31 AM
04 STi Engine into an 04 WRX? rsmith2786 Subaru Conversions 2 04-04-2008 11:24 AM
HELP! 05 STi engine into an 03 WRX KillerBumbleBee Subaru Conversions 5 01-24-2007 11:10 AM
Is it possible to switch STi headlight reflectors into WRX Housings, and vice-versa? caterpill Electrical & Lighting 1 03-24-2006 04:57 AM
