Welcome to the North American Subaru Impreza Owners Club Friday September 20, 2024
Old 07-25-2008, 06:47 PM   #1
Subpar
Member#: 178953
2002 Impreza OS
Default 02 WRX 4EAT rear LSD swapped into a 02 Impreza OS 4EAT?
Same gear ratios from what I've read, but is there a DIFFerence in the housing?
I have searched Nasioc, but nothing came up.
Subpar is offline   Reply With Quote
Old 07-26-2008, 01:23 PM   #2
DS1
Vendor
Member#: 111780
Different trans completely.
Turbo 4eat's use different internals and valvebodies.
Also the WRX 4eat has the variable center diff the the obs doesn't.
You need to find a non-turbo trans
-Dylan @ DS1
DS1 is offline   Reply With Quote
Old 07-26-2008, 04:42 PM   #3
Subpar
Member#: 178953
2002 Impreza OS
Hmmm, I don't think I'm explaining myself clearly.
I have an 02 Impreza Outback Sport (4EAT). The rear diff is bad. Will the rear LSD from an 02 WRX (4EAT) bolt directly in, or will I need to modify anything?
I don't want to swap the transmission, just the rear diff.
I don't have much knowledge of newer Subarus, I'm used to working on beat GL junkbuckets.
Old 07-26-2008, 06:21 PM   #4
DS1
Vendor
Member#: 111780
Oops, the rear diff will bolt in but you will need a set of LSD axles
Old 07-28-2008, 11:57 AM   #5
Subpar
Member#: 178953
2002 Impreza OS
Crap. Different spline count? I'm guessing maybe I should just buy a complete rear end - diff/axles/hubs/disc brakes. It would be nice to have rear discs...
Old 07-28-2008, 01:39 PM   #6
DS1
Vendor
Member#: 111780
Different stub into the diff, the rear conversion would be a good idea.
Old 08-04-2008, 01:28 PM   #7
Subpar
Member#: 178953
2002 Impreza OS
Can anyone confirm that 02 WRX wagon rear axles are different from 02 WRX sedan rear axles? Part numbers and/or photos would be helpful.
Old 08-04-2008, 02:46 PM   #8
DS1
Vendor
Member#: 111780
10mm narrower for the wagon than the sedan.
Old 08-04-2008, 02:56 PM   #9
AndrewtechAutomotive
Member#: 99694
2015 rocketbunny brz
red
Confirmed. The WRX wagon axles are 1cm narrower than the sedan axles.
Phil
AndrewtechAutomotive is offline   Reply With Quote
Old 08-04-2008, 03:10 PM   #10
Subpar
Member#: 178953
2002 Impreza OS
Thanks for the info, much appreciated. Now I can stop asking questions and start working on getting my car back on the road.
2004 WRX 4EAT rear LSD options SKANk9915 Transmission (AT/MT) & Driveline 5 07-29-2008 01:49 PM
04 WRX tranny swap into a 02 WRX help ! Don Arm Transmission (AT/MT) & Driveline 1 08-18-2006 11:04 PM
LSD swap into '99RS and whiteline bushings review. powerlabs Transmission (AT/MT) & Driveline 1 01-20-2005 10:04 AM
Limited slip viscous coupling rear differential swap into a '99 Impreza. powerlabs Subaru Conversions 11 04-25-2004 11:41 PM
LSD swap into 2002RS DDMan Transmission (AT/MT) & Driveline 0 04-22-2003 12:21 AM
