09-04-2003, 12:55 AM | #1 |
Member#: 41271
Vehicle:2004 STi |
noob question: how to remove a windshield sticker
first time put on some windshield sticker. but it wasn't curved enough so i have to remove it. will a hair dryer do the job?
thx
09-04-2003, 01:22 AM | #2 |
Member#: 24034
Vehicle:was higher so you could all hate on me too! |
Vinyl? Are you asking if you can take it off then reposition it and reapply? If so then I’m not to sure. If you just want to take it off peel it right off with your fingers.
09-04-2003, 01:31 AM | #3 |
Member#: 41271
Vehicle:2004 STi |
hmm....it seems stuck on pretty firm....remember heard somewhere else need a heat gun to remove them.....maybe a hairdryer will do the same....
09-04-2003, 01:57 AM | #4 |
Member#: 25850
Vehicle:2003 Infiniti M45 Silver |
Just take a razor blade and swipe it under the sticker, it will peel right off.
09-04-2003, 02:51 AM | #5 |
Member#: 20492
Vehicle:4 -valve Derper Let's JDM styling! |
Vinyl stretches... if you peel it off by hand odds are it'll look sucky when you put it back on
09-04-2003, 11:10 AM | #6 |
Member#: 40248
South East
Vehicle:2003 WRX Midnight Pearl (black) |
get your buddy at the sign shop to make you a new one and allow for a curved surface. Does it say "Fear This" or "Got Nos?"?
09-04-2003, 12:13 PM | #7 |
Member#: 31702
Vehicle:2013 WRX |
you're not gonna be able to re-use it.
to remove it, just use a razor blade, and water helps to remove the sticky glue residue. or even better, water and soap mix. just put it in a spray bottle. and if you want to put the sticker on, use the water and soap mix. here's how. just clean the surface. let it dry. then spray the water/soap mix on the windsheild(or anywhere else you apply stickers), and spray the sticky side of the sticker lightly. place the sticker on the windsheild, and adjust it before the water dries. you can use a credit card, or driver's licence to "push" the water from underneath the sticker. make sure you go over the whole thing with the CC or DL fairly firm. wait for a few minutes, and slowly pull away the film on the front of the sticker, working from one corner. sounds crazy to get the sticker wet, but it works. that is how every graphic on my past 3 cars have been put on. and i learned that from a buddy who did it for a living. here's the vinyl on my celica. i couldn't even imagine what it would have turned out like if i had to put the stickers on dry! |
09-04-2003, 01:01 PM | #8 |
Member#: 41271
Vehicle:2004 STi |
Thanks guys. Very helpful!!!
I'll try to remove them tonight and post the result. Reuse is not a concern but if it came off OK, i might just put it somewhere else. btw, nice ride, black-x |
DUMB question: how to remove headlights on 06? | Must@ng | Electrical & Lighting | 2 | 01-03-2010 11:00 AM |
how to remove rear windshield exterior trim | sweendiggs | Interior & Exterior Modification | 2 | 09-20-2006 03:39 PM |
How to remove a windshield washer nozzle? | da n00b | Service & Maintenance | 3 | 02-03-2005 02:00 AM |
How to remove stickers? | edkwon | Interior & Exterior Modification | 8 | 04-17-2001 11:26 PM |
