Welcome to the North American Subaru Impreza Owners Club Wednesday September 11, 2024
Old 12-16-2003, 11:48 AM   #1
obsrules
Member#: 16400
2002 Outback Sport
Savannah Green
Question How to change headlight bulbs?
Hi! This is probably really simple but I couldn't find it in the owners manual or by searching the forums. I'm looking for step by step instructions on how to replace the bulbs on my 2002 OBS. I'm not the most mechanical person but I'm hoping this is something I can do on my own. I just got a set of Phillips Hi-Visibility bulbs and am eager to see how well they do. Any answers or advice is appreciated!
Thanks
Al
obsrules is offline   Reply With Quote
Old 12-16-2003, 01:21 PM   #2
bleuquila
Member#: 31922
03 wrx wagon
78 brat
it's real easy. As I recall, you just pop the hood, and then sort of jam your hand in there and at the back of the headlamp housing unscrew this black plastic round knob (remember, counterclockwise looking forward, or clockwise from your perspective! ) You should feel it unlock after giving it a good twist, and then carefully pull the bulb back out of the headlamp assembly. After that, just swap the stock bulbs for the beefier Philips.
At least... it's something like that. If I've misremembered, I'm sure someone else will chime in, or else I can actually go outside and look
bleuquila is offline   Reply With Quote
Old 12-16-2003, 02:06 PM   #3
Hank3
Member#: 16157
'03 Mazda P5 <><
'02 WRX & '08 MS3 SOLD!!!
Also be sure not to touch the bulbs with your hands as the oils from them will cause the bulbs to blow.
Hank3 is offline   Reply With Quote
Old 12-17-2003, 09:19 AM   #4
obsrules
Member#: 16400
2002 Outback Sport
Savannah Green
Thanks for the replies. I'll give it a shot this afternoon.
Al
Impreza Outback Sport - how to change fogligt bulbs? Im a sock Newbies & FAQs 2 12-05-2007 02:26 AM
How to change foglight bulb 06-07 CGM6 Interior & Exterior Modification 5 08-12-2007 01:46 PM
HIghly Stupid Question - How to remove headlight bulb?! SubieWahn Electrical & Lighting 3 10-29-2005 06:03 PM
How to change LED bulbs in Spoiler Brake Light? scoobydrew06 Service & Maintenance 5 08-11-2003 10:22 AM
Help: Can't figure out how to install headlight bulb and harness back into headlight Gypsum2 Interior & Exterior Modification 2 07-29-2002 12:25 PM
