Welcome to the North American Subaru Impreza Owners Club Wednesday September 11, 2024
Old 05-20-2005, 12:02 AM   #1
LegacySE
Member#: 31759
19 VW Tiguan
Vortech SC BRZ 13 CWP 6MT
Default 05 STI takeoffs on 05 2.5RS?
Hey guys, my friend has a 05 2.5rs wagon and he recently found a deal on a set of 05(V9?) sti takeoffs.
Some questions on these takeoffs..
-Would the 05 sti strut fit the RS knuckle/hub? Some says that the knuckle is wider and beefier than the rest of the Impreza.
-If they don't fit, the 04 STI takeoffs should correct? Since the takeoffs avaliable to us are from USDM sti (sedans), the rear springs are shorter than wagon springs. Would it give an uneven look to the car? none to 0.5" drop is what i heard, but the rear is questionable.
Thanks
-LegacySE
LegacySE is offline   Reply With Quote
Old 05-20-2005, 10:35 AM   #2
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The 05 STi mounting holes on the struts need to be enlarged for fit any of the other imprezas. I'm not exactly sure what all has to be done though.
Shot answer: Not plug and play.
mbiker97 is offline   Reply With Quote
Old 05-20-2005, 12:39 PM   #3
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
Originally Posted by LegacySE
(1)-Would the 05 sti strut fit the RS knuckle/hub? Some says that the knuckle is wider and beefier than the rest of the Impreza.
(2)-If they don't fit, the 04 STI takeoffs should correct?
(1) No the fronts won't fit for the exact reason you cited. I've heard of people using a spacer but that's mickey-****ing-mouse.
(2) Correct, the 04STi takeoffs will fit any GD impreza.
nhluhr is offline   Reply With Quote
Old 05-20-2005, 02:25 PM   #4
RaceComp Engineering
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
The best combo is what we have been working on collecting. 04 STI take off fronts and 05 STi take off rears. The 05 rears ( to my knowledge) dont knock, but time will tell. The combo will work well and you can still use JDM pinks or Prodrive 05 Sti springs very well. Plus with some of the updates to the rear 05s ther should be less bobble head...........
Myles Williams
www.racecompengineering.com
[email protected]
Racecomp Engineering LLC.
9123 Old Annapolis Rd Suite 103w
Columbia, Maryland 21044
410-730-RACE
410-730-5503 FAX
410-707-0108 mobile.
RaceComp Engineering is offline   Reply With Quote
Old 05-20-2005, 03:42 PM   #5
XmanSTi
Member#: 65206
1986 Brat
Red
there's reports of klunks on '05s already (repeats even). I am thinking of finding the right grease to put into the seals to prevent the knock/stiction for significantly longer periods of time, but I've been too lazy, and frankly if I fix the klunking all the whiny, anal people will stop dumping their inverted struts for cheap and the value of takeoffs will go up before I've amassed enough to sell and retire on the profits
XmanSTi is offline   Reply With Quote
Old 05-23-2005, 11:26 AM   #6
Member#: 54202
ASK ABOUT NEW RCE
SWAY BARS FOR STI
bumped
Myles Williamswww.racecompengineering.com
[email protected]
410-730-RACE
410-730-5503 FAX
Installed 2004 STi suspension on 2000 2.5RS Fred Brakes, Steering & Suspension 56 12-15-2010 01:46 AM
05 sti struts on 05 wrx 4wdwrx Brakes, Steering & Suspension 11 11-08-2004 01:30 PM
I am going to put a TON of STi stuff on my 2.5RS... SailRacer General Community 22 09-22-2004 05:33 PM
STI HID's on a 2.5rs deruvian Electrical & Lighting 3 06-26-2004 07:11 PM
STi springs on a 2.5RS C0met Brakes, Steering & Suspension 2 03-31-2004 08:28 PM
