Welcome to the North American Subaru Impreza Owners Club Saturday June 21, 2025
Old 05-24-2005, 02:13 AM   #1
silex
Member#: 87706
Default STi Engine Swap into early year Impreza
I geard Garage Tuning can do this swap, but I guess the main reason I'm posting this is that I'm very new to Subi's and their engines. I am definetely aiming for an engine swapped car for my summer project and I am either highly considering a Nissan 240SX hatch with a 1JZ from a MK3 Supra or an early year Subi with STi engine. Guess I'm wondering about what my STi engine swap options are. I hear of this Type 1,2,3 and what not...jdm versus usdm...not really sure what to go with. I plan to make some high power and make the car a dedicated track car worthy of such.
silex is offline   Reply With Quote
Old 05-24-2005, 02:22 AM   #2
saar
Member#: 43770
2013 Impreza WRX Lim
2001 Impreza WRX STi
If it's a STi Engine into a GC body your looking at ...it's not a totally uncommon swap... The differnt versions of engines most commonly swapped in are Ver.6, Ver.7 and the pin-ultimate swap the USDM 2.5L STi motor ... You may want to read around the 'Subaru Converison' Forum a bit ... To get a better idea of the steps involved in the swap.
saar is offline   Reply With Quote
Old 05-24-2005, 03:10 AM   #3
silex
Member#: 87706
When you GC body I'm assuming the '95+ coupe? Can you explain the differences between the different engine types?
Old 05-24-2005, 09:00 AM   #4
inchoate
Member#: 5470
2014 Honda Odyssey
Nondescript
there's very little exterior difference between subaru engines. they are for the most part interchangeable. if you do a search you should be able to find out about the different types. just to start you out, the ej-20 is the 2 liter, ej-25 is the 2.5, and ej-257 is the usdm 2.5 motor.
inchoate is offline   Reply With Quote
Old 05-24-2005, 10:07 AM   #5
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
The types are different versions. v1 thru v9. I would buy a JDM v7 or v8 to swap into a GC. They make a lot of power and have the ability to hold more power too.
More impreza version info: http://www.northursalia.com/t...y/history.html
mbiker97 is offline   Reply With Quote
Old 05-24-2005, 01:11 PM   #6
Homerisking
Member#: 79164
2005 WRX
tHe Silver one
Not an sti but still drool worthy.....one of the nicest gc8 I've ever seen. Its a wrx motor with a v8 intake manifold. Check out the link.
http://forums.nasioc.com/forums/show...hlight=gc8+sti
Homerisking is offline   Reply With Quote
Old 05-24-2005, 03:20 PM   #7
silex
Member#: 87706
Thanks for the reply guys. The 'Conversion' forums and the associated FAQ's answered a majority of my questions . I guess what I'm wondering is the potenntial of the EJ20 versus the STi's EJ25. I also hear the longblock on the JDM engines are built to withstand more torture than a comparible USDM so in the long run, it might be worth it more to sacrafice the 30HP with the JDM STi to save a bit of money. Any truth to any of this?
Old 05-24-2005, 03:27 PM   #8
JDM_Scobaru
Member#: 57809
Good luck trying to wire a 96+ motor into a pre95 car! You would have to convert from obd1-2. Stick to a swap that is closest to your year so wiring wont be as bad.
JDM_Scobaru is offline   Reply With Quote
Old 05-25-2005, 02:03 AM   #9
silex
Member#: 87706
That's true, but if you're going to go the JDM route, they don't use an EGR system so it makes it much easier to install. One less thing to put in. Just have to smog it under the table.
Old 05-25-2005, 07:03 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
....EGR isn't an issue....it is all the wiring needed to the harnesses to make it all work properly....there are pics of spaghetti around......and like posted above.....an 95+ with a 95+ motor is easiest.....
Old 05-25-2005, 05:10 PM   #11
silex
Member#: 87706
Okay I get it. The previous guy made it seem that the problem was in the differences between OBD systems.
Old 05-25-2005, 05:38 PM   #12
cRayZee
Member#: 6271
2001 2.5RSTi
2007 Legacy Spec B
garage tuning did my swap. 2004 2.5 USDM STi in a 2001 2.5 RS I'm very happy with it
cRayZee is offline   Reply With Quote
05 STi Engine swap into 04 WRX ?s srREXed Subaru Conversions 12 06-24-2016 11:02 AM
00 RS engine will swap into which years Forester or Impreza easily? imprzya Subaru Conversions 2 04-02-2008 04:26 PM
Full STi engine swap into WRX jdiddy Subaru Conversions 3 03-16-2006 12:55 PM
04 sti engine swap into 97 outback sport godof12v Subaru Conversions 0 09-18-2003 09:50 PM
turbo engine swaps into previous imprezas? dj_dk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-14-2001 10:26 AM
