07-11-2005, 02:52 AM | #51 |
Member#: 90353
NWIC
Vehicle:Sold '95 22T Impreza '99 EJ205 L, AE86 GVR4 |
agh, lemme see if this works instead
http://image50.webshots.com/50/2/4/4...4BeNMud_fs.jpg sorry about the confusion
07-11-2005, 11:40 AM | #52 |
Member#: 832
RMIC
Vehicle:99 2.5RS, '85 911 '73 914 and 2012 BRZ |
BMXpunk,
Get me some pics to work with, and I can probably match your PVC lines for you. |
07-11-2005, 02:49 PM | #53 | |
Member#: 8039
NESIC
Vehicle:94 v2 STi RA - RHD |
07-11-2005, 05:12 PM | #54 |
Member#: 90353
NWIC
I got the pictures to work now.
07-11-2005, 05:14 PM | #55 | |
Member#: 90353
NWIC
thanks |
07-11-2005, 07:46 PM | #56 | |
Member#: 89599
RMIC
Vehicle:1995 95 Impreza red |
I think I have it figured out but if I get more stuck I will definately send some to you. Even if it just helps out natoe here. FOund a coffee cup to work for my mugger mod. its blue to contrast with my red intake manifold/piping, and match my blue NGK plug wires. |
07-12-2005, 08:24 AM | #57 | |
Member#: 8039
NESIC
I would not recommend doing this without some fuel control. Whether it be an AFC or emanage or whatever. Some sort of timing control would help too. My brother is selling his HKS AFR and Apex ITC. Let me know if your interested. |
07-12-2005, 01:25 PM | #58 |
Member#: 832
RMIC
You have forgotten that you need to remove and cap the EGR on the 1.8l manifold.
07-12-2005, 02:39 PM | #59 | |
Member#: 8039
NESIC
07-13-2005, 04:36 AM | #60 |
Member#: 90353
NWIC
to take care of the EGR do i just not run the vaccum line to the valve but leave it bolted to the manifold?
matt- pm me a price for the controllers, id just like to see how it runs without them for a while but it may be something id like to get. Transferring the cam and crank sensors- is straight forward since its easy to get them out of the block? I am sure ill be able to figure these things out its just ive never done anything like this before... thanks a bunch for the help. We ran into a problem today trying to pull the 1.8L, we cant get it seperated from the transmission even after lifting it out of the mounts... we know all the mounts are off and we have got a half inch gap between the two but they wont seperate! It is quite frustrating. the yard didnt have my engine tuesday so im going to get it tomarrow hopefully, and put it in ASAP. Thanks! ill post some pics when we get it done! |
07-13-2005, 12:03 PM | #61 |
Member#: 89599
RMIC
swapping the crank and cam sensors is cake. unblot-move-rebolt-tighten.
I had the same problem with my ej 22 tranny but the shift forks are different. you should just be able to pull if all of the mounts are off. If you are very careful you could use a pry bar to helpyou. Come to think of it, my ej18 were sticky but they did pul apart after some jiggling and a little prying. |
07-13-2005, 12:22 PM | #62 |
Member#: 832
RMIC
natoe,
is your car an automatic? |
07-13-2005, 02:28 PM | #63 |
Member#: 90353
NWIC
No, its a FWD 5 speed.
We did gently use a prybar, and even when we pull the lift away from the car it pull the engine AND tranny as far as the pitch stop lets it. There were 2 motor mounts we took off (it is up off the crossmember already), and there were 2 upper engine-tranny bolts, and 2 lower engine-tranny studs so i believe its all undone but wiggling and such doesnt help |
07-13-2005, 02:35 PM | #64 |
Member#: 832
RMIC
You don't still have the pitch rod connected do you?
07-13-2005, 02:57 PM | #65 |
Member#: 90353
NWIC
i didnt think we had to remove the pitch stop to get the engine out... do we need to? Right now the tranny is connected everywhere, and we have a jack under it for support.
07-13-2005, 05:20 PM | #66 |
Member#: 89599
RMIC
Mine was AWD, dont have a clue how to do yours. Your car is going to be insane to drive with FWD
07-13-2005, 05:29 PM | #67 | |
Member#: 832
RMIC
You do. Right now, you are probably binding on the two guide pins between the engine and the tranny, and are pulling too much up and not enough out. And if you are not careful, you will pull a pin out into the engine from the tranny. Don't ask me how I know this... |
07-13-2005, 06:00 PM | #68 |
Member#: 90353
NWIC
07-13-2005, 06:03 PM | #69 |
Member#: 90353
NWIC
07-13-2005, 06:55 PM | #70 |
Member#: 832
RMIC
I like the picture of your beast inthe back ground. Teh dog's are cool...
07-14-2005, 03:23 AM | #71 |
Member#: 90353
NWIC
07-14-2005, 04:01 AM | #72 |
Member#: 89599
RMIC
cool dogs. wanna know something funny? I ihave taken two motors out and put one in: and everytime, I have done it from the bottom NOT THE top. Geez youre wierd... wait, that might be me.
I dont get to work on my car til sunday I run the local bmx track and have to get it ready for big races this weekend. i drove a skidsteer loader from 6 pm to 2 am!!!!!!!!!!!!!! woooooo hoooooooo. |
07-14-2005, 12:47 PM | #73 |
Member#: 90353
NWIC
haha, wouldnt taking them out the bottom be a lot more work? removing the crossmember, steering, and some suspension stuff, while i just moved the radiator.
but my next step is to remove the crossmember anyways... ive never taken apart any steering components before :P but oh well. oh! and for a while ill be driving around with no front sway bar... that should be exciting, thatll be something i get very soon. As the engine goes, my junkyard told me that the engine i ordered turned out to be a bad one but supposively he got me another one and is including the turbo piping and crossmember so im still happy. im gonna pick it up today! |
07-14-2005, 12:56 PM | #74 |
Member#: 89599
RMIC
NO its not too hard because you dont have to disconect the tranny
4 crossmember bolts 4 tranny cross member bolts 6 strut top nuts 1 pitch stopper bolt 1 steering knuckle bolt put the front on jack stand lower entire drivetrain with hydraulic jack takes about 12minute total on my third time ( so what if I forgot the clutch fork the first time I had everything in the car) |
07-15-2005, 02:08 AM | #75 |
Member#: 90353
NWIC
yeah i guess your way would be easier if i needed the tranny out but i just left i there.
im so sad because my junkyard didnt have my engine, then they found one, it was bad though, then they found one but turned out it wasnt a turbo, and now they are 100% sure that this one they found is actually what i paid for and it will be ready friday even though i ordered it last thursday! they just better not come up with another lame excuse for it not being ready or im screwed since my engine is already out of my car... cant wait till i get it in and running though! ive driven my friends talon tsi, and god i love the sound of turbos spooling. how close is yours to running bmxpunk? |
v3 STi swap, 95 impreza coupe - Here goes nothing | elislider | Subaru Conversions | 202 | 01-05-2011 07:41 PM |
FS: Ver. 5 STi swap and 95 impreza coupe | pinter | NWIC Private Classifieds | 7 | 08-28-2007 01:07 AM |
95 impreza coupe!!! MINT 04 WRX SWAP | STi in ur face | Private Vehicle 'For Sale' Classifieds | 45 | 08-13-2007 01:35 AM |
WTT: 95 Impreza Coupe for 95 Impreza Sedan | bigboss | MWSOC Private Classifieds | 9 | 02-18-2007 04:40 AM |
FS: 95 Impreza Coupe swapped w/ Ver.2/3 | AWDsub | NWIC Private Classifieds | 12 | 12-06-2006 10:53 PM |
