Welcome to the North American Subaru Impreza Owners Club Saturday September 7, 2024
Old 08-27-2005, 03:38 PM   #201
Natoe
Member#: 90353
Sold '95 22T Impreza
'99 EJ205 L, AE86 GVR4
man, how much did the perfect power cost? and also, i dont have the factory turbo IAC or the MAP sensor, so wouldnt that be a problem?
what does it tune? and is it some sort of a wideband O2 sensor?
Natoe is offline   Reply With Quote
Old 08-27-2005, 04:04 PM   #202
bmxpunk
Member#: 89599
1995 95 Impreza
red
All the better that you dont have the IAC or a map sensor. THat will make it easier on you. I put in a GM MAP sensor because it is more accurate but you would just splice that wire into you throttle position sensor. It wa like 450-500 and you can tune it from your laptop. It can adjust timing and fueling and run one other solenoid like an injector or a boost controller
bmxpunk is offline   Reply With Quote
Old 08-27-2005, 04:40 PM   #203
Natoe
Member#: 90353
thats pretty awesome, expensive though...
so id be able to hook it up to my setup with just the 1.8 wiring harness including the 1.8 throttle body and MAF? what did you do about the knock sensor? still have it not hooked up?
v3 STi swap, 95 impreza coupe - Here goes nothing elislider Subaru Conversions 202 01-05-2011 07:41 PM
FS: Ver. 5 STi swap and 95 impreza coupe pinter NWIC Private Classifieds 7 08-28-2007 01:07 AM
95 impreza coupe!!! MINT 04 WRX SWAP STi in ur face Private Vehicle 'For Sale' Classifieds 45 08-13-2007 01:35 AM
WTT: 95 Impreza Coupe for 95 Impreza Sedan bigboss MWSOC Private Classifieds 9 02-18-2007 04:40 AM
FS: 95 Impreza Coupe swapped w/ Ver.2/3 AWDsub NWIC Private Classifieds 12 12-06-2006 10:53 PM
