10-17-2005, 12:58 PM | #76 |
Member#: 5050
cool, Ill do that with the ground. Now problem 2, still unsure and unanswered. Fuel lines.
Connect the dots This is a mistake, the 1.8 lines are in a traiangular pattern, the 2.5 lines are lineir like pictured below.
10-18-2005, 05:11 AM | #77 |
Member#: 69513
NWIC
Vehicle:98 OBS EJ207 4.444 black/grey |
try this
pm me if you need more help |
10-18-2005, 09:57 AM | #78 |
Member#: 5050
wait.... is the fuel filter on the drivers side? I thought that was the charcoal canister.... or is the charcoal canister on the pass side near the radiator? Wheres the fuel filter so I can use that as a refference. Thanks for the diagram Im sure when I sit infront of the car Ill be able to find out what it is your talking about!
10-18-2005, 10:30 AM | #79 |
Member#: 16274
Vehicle:2001 GM6 2.0L vf30 e30 black/rust |
the fuel filter is on the drivers side by the shock tower.
10-18-2005, 11:48 AM | #80 |
Member#: 5050
ok and how do I tell which of your steel lines are which? They are arranged in a triangular pattern on the car...
10-18-2005, 01:43 PM | #81 |
Member#: 77677
Vehicle:1997 OBS '07 KLR 650 |
I went to look at my car...I have the same linear arrangement.^^^
My best suggestion would be to find the one line that goes to the fuel rail, and tag it. Next, find the one that sort of goes in the direction of the charcoal canister, and tag that. process of elimination....... |
10-18-2005, 03:49 PM | #82 |
Member#: 5050
word, ill get the info when im back up in nova. Then its time to hook up the vacum system.... OH FUN! lol
10-23-2005, 11:11 PM | #83 |
Member#: 5050
10-23-2005, 11:15 PM | #84 | |
Member#: 5050
This is right, and i think its fixed.... Now, I have more issues. Theres a vac/fuel steel line comming out facing the radiator on the pass side directly to the side of the PS pump... and another on the opposite side facing up, both on the front of the motor/manifold area. WHERE DO THESE GO?! WHAT HOOKS UP TO THEM?! Im in the last leg of things here, I need to get these little kinks worked out! |
10-27-2005, 08:40 PM | #85 |
Member#: 51940
NESIC
Vehicle:2001 White |
i'm so glad nasioc is back up so i can read page two of this thread. i was stuck on page one ever since it went down !
10-27-2005, 10:48 PM | #86 |
Member#: 16274
are you using the 1.8 intake manifold or the 2.5 manifold? It sounds like the 1.8, but i want to make sure..
11-01-2005, 04:56 PM | #87 |
Member#: 5050
11-01-2005, 04:59 PM | #88 | |
Member#: 5050
11-01-2005, 06:41 PM | #89 |
Member#: 16274
The 2.5 throttle body has a rather large port in the manifold for the IAC valve. The 1.8 throttle body doesn't need that.. So in order to make that 1.8 tb work, i just purchased a 2.5rs tb gasket, or you can use the old one, and a sheet of gasket material. Then just trace the 2.5 gasket onto the sheet, leaving out the large port at the top, and viola! You have a custom gasket that works. No need for 3 different gaskets like i've read about people doing..
11-01-2005, 08:45 PM | #90 |
Member#: 5050
"i just purchased a 2.5rs tb gasket"
On my manifold/tb combo with the 2.5 gasket there was still 1-2mm of open IAC port on the manifold. I needed the plate with the 2.5 gasket on the manifold side and the 1.8 gasket on the TB side for it to completely seal against the manifold. |
11-01-2005, 09:56 PM | #91 |
Member#: 13910
NESIC
Vehicle:2005 Legacy GT blue |
Subscribe, I have a 95L waiting for an engine in my price range.
11-19-2007, 04:20 PM | #92 |
Member#: 25842
Vehicle:1993 Impreza Purple |
I just did this same swap over the weekend, and this thread was a huge help. Couple notes:
-TB gasket: I bought a roll of gasket material, cut it out to match the external dimensions of the 2.5 IM with the hole for the 1.8 TB. RTV'd both sides, works great. -Wiring: pretty much all of it was covered here, but for those who haven't done it, it's very straightforward if you have any idea about wiring. The injector plugs could be de-pinned (no splicing necessary), but the other few (coil, temp sensor, etc.) did require splicing, as the female ends weren't the same between harnesses. -Use the original 1.8 PS pump, alternator, and AC compressor, with all original brackets. The ONLY different thing I did was for the AC compressor, the bottom "sliding' bracket piece. The 2.5 has a slight curve in one section, and makes tightening that innermost lower bolt easier/possible. Not a big deal, and not worth doing unless you have the thing laying around. -I have a CEL for the EGR valve. I didn't do a single thing to make it work, so I wasn't surprised. Just FYI. My charcoal canister is also not hooked to anything. (Also just for reference, to check a CEL on an OBDI car, there are two small black disconnected plugs under the dash on the driver's side, kind of between the steering column and center dash area; plug them in with the car off, then turn the key to ON (not running), and the codes will flash ) -Not that this is ideal, but the 1.8 exhaust manifolds will bolt right up to the 2.5 block, just for reference. My only issue now is a weird loud squealing noise, which we think might be related to something with the plate that bolts to the torque converter. Prior to the swap I had no such noises, so I'm a little bit at a loss. EDIT: After a test drive, seems to be RPM related. Is there anything weird with a difference in TC/flywheels between the '00 and '93 years? I'm using everything from my '93, and am wondering if the flex plate needs to be from an '00 or something. RE-EDIT: Swap is pretty quick Last edited by sscguy; 11-19-2007 at 04:35 PM. |
12-03-2007, 03:53 PM | #93 |
Member#: 25842
Update: I've been driving the car around for awhile, and am having only two problems. The first has to do with the car starting, where it'll start, then rpms drop and it dies. This'll happen 3-4 times, then it'll start ok. It seems to do it more when warmed up rather than cold, and was doing it now and then before the swap. I think it might be at least partially related to an improperly routed ground (I have a big one going to the starter, and don't remember taking it off there, but couldn't find another place for it).
The second problem is with fuel mileage. On average, I'm getting 19mpg, which blows. With the old engine even in bad shape, I got 28mpg regularly. I am running this swap off the original EJ18 ECU, and I'm thinking maybe it's lean or rich for whatever reason, or maybe the injectors are just dumping more fuel in than should be normal. While an SAFC (which I have laying around) would solve the problem for sure, I'd rather go the easier route of plugging in a '98 RS ECU if that would work. Any thoughts? The squealing noise wound up being the little splash guard between the bellhousing and block, which had gotten bent upwards and was rubbing on the flywheel. |
wrx suspension into a 94 impreza? | boyguan | Brakes, Steering & Suspension | 0 | 08-05-2006 03:19 AM |
EJ25 swap into 94L Complete!!! Afterswap questions. | 83Rabbit | Subaru Conversions | 6 | 11-01-2005 04:55 PM |
EJ25 Swap into OBS | Soon2BturbodRS | Subaru Conversions | 2 | 08-24-2003 10:25 PM |
Turbo Legacy Engine into a 94 Impreza L? | Homemade WRX | Subaru Conversions | 5 | 04-11-2003 10:48 AM |
doing an EJ25 swap into my 99 sportwagon...any tips? | ej25wagon | Normally Aspirated Powertrain | 4 | 07-01-2001 05:53 PM |
