02-15-2010, 10:01 PM | #1 |
Vendor Sales Rating: (5)
Member#: 4803
COBB Tuning Surgeline Stage 2 and E85 Power Packages!
On top of our normal stock of COBB Tuning parts, we are offering specials on our revised Stage 2 Power Packages. Each of these packages include a COBB Tuning AccessPORT, COBB Tuning Turboback, either a COBB Tuning SF Intake/Airbox Combo or an AEM Cold Air Intake (depending on application).
These packages also include either 50% off installation of the Turboback and Intake or 50% off a custom dyno tune. COBB Tuning Surgeline Stage 2 Power Packages 02-07 WRX- $2040 w/SF Intake Combo 08-09 WRX Hatchback- $2145 w/AEM CAI 04-07 STi- $2040 w/SF Intake Combo 08+ STi- $2545 w/AEM CAI 2010 WRX Stage 2 w/AEM Intake and Custom Surgeline Tune 2004 STi Stage 2 w/SF Intake and Custom Surgeline Tune ********************* E85 TUNING DEALS ********************* Cheap Horsepower Packages!!! E85 Upgrade Packages for WRX and STI! We literally get hundreds of calls from customers asking us how they can make more horsepower, but stay on a budget, or retain their light modifications to stay within the framework of warranty and emissions concerns. In the past we would not hesitate to recommend a race gas or Torco tune. However both of these fuels can be expensive and detrimental for your car's longevity. There is a now a new option: E85. E85 is a blend of ethanol and premium gasoline with a net octane rating of about 105. It is also available at the pump in many states AND costs as little as $2.00 per gallon. An equivalent 104 "race" fuel would be $5-$8 per gallon. Another advantage of E85 is that it carries additional oxygen into the combustion chamber so you can run comparatively leaner AFRs and more timing to create much more horsepower and torque on stock-sized turbos. Coupling this fuel on a WRX with a 16G or 18G turbo and even more power can be produced! On a 2009 WRX with a Stock Turbo and upgraded TMIC we were able to make 345whp and 379wtq on an aggressive custom tune! A gain of 23whp and 40wtq over the pump fuel tune! See graph below With the STI, Stage 4 power numbers are easily achieved with a Stage 2 E85 tune and a stock turbo and intercooler. COBB Tuning Surgeline is now offering complete E85 upgrade packages including maps for your AccessPORT for 2002-2007 WRX and STI. (2008+ models require custom tuning at this point) 2002-2007 WRX and 2007 STI: Deatschwerks 750cc injectors, Walbro 255lph fuel pump and Surgeline OTS map $599 Deatschwerks 850cc injectors, Walbro 255lph fuel pump and Surgeline OTS map $749 2004-2006 STI: Deatschwerks 740cc injectors, Walbro 255lph fuel pump and Surgeline OTS map $699 Deatschwerks 850cc injectors, Walbro 255lph fuel pump and Surgeline OTS map $799 COBB Tuning Surgeline- (503) 670-9500
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. SUBARU EXPERT GROUP - MARSHALL GLASGOW | BILL GREGG | JON BOWEN | LANCE LUCAS | MATT BRYANT | MIKE MCGINNIS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Cobb Tuning; 02-18-2010 at 01:36 AM. |
02-16-2010, 07:21 PM | #3 |
Member#: 4803
Add a heatshield to your E85 Package!
Want to add a little heat protection to your E85 tune? Add a COBB Tuning SS Turbo Heatshield! COBB Tuning is pleased to announce that SS Heatshields for select Subaru models are back in stock! The COBB Tuning stainless steel heat shield is designed in-house and a replaces the factory turbo heat shield found on most vehicles. A modification which goes hand in hand with an aftermarket downpipe install, the heat shield prevents the heat from exhaust gas temperatures to vent into the engine bay, reducing heat soak into the intercooler. The COBB Tuning SS Heatshield is available for 2002-2010 Impreza WRX/STI, 2005-2009 Legacy GT and 2004-2008 Forester XT. The COBB Tuning SS Heatshield is available at COBB Tuning Surgeline NOW!!! *for stock sized turbos
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. SUBARU EXPERT GROUP - MARSHALL GLASGOW | BILL GREGG | JON BOWEN | LANCE LUCAS | MATT BRYANT | MIKE MCGINNIS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by Cobb Tuning; 03-10-2011 at 05:59 PM. |
02-19-2010, 03:35 PM | #5 |
Member Sales Rating: (2)
Member#: 182387
NWIC
Vehicle:2004 Wrx Wagon WRB - stg. 2 |
how much and what intake would be available for my forester?
and im not sure i trust this shop, let alone their tuner... haha |
02-22-2010, 03:04 PM | #6 |
Member Sales Rating: (1)
Member#: 82753
Surgeline tuned our new rally car last month- also running on E85. They do really excellent work. Everyone there is very professional- cool, comfortable atmosphere.
Check out the results here: http://racingdoug.blogspot.com/2010/01/dyno-day.html Doug #203 Subaru WRX Rally Car RalliTek Surgeline AMSOIL |
02-22-2010, 03:05 PM | #7 |
Member#: 4803
Back by popular demand! The COBB Tuning SF Intake is once again available from All COBB Tuning retails stores including COBB Tuning Surgeline,COBB Tuning Plano andCOBB Tuning.com! The COBB Tuning SF Airbox was designed to capture the cool air supplied to the SF Intake through the factory intake snorkle. Constructed of 16 ga. Aluminum the heat shield consists of a one-piece surround, directional lid, and stainless fasteners that help reduce a loss of power that could be robbed from your motor by a heated intake charge. Unlike some cold air intakes, which places the filter in the front fender, our design helps to supply cool air through factory ducting, while eliminating the risk of water ingestion. Comes with all necessary hardware and full illustrated instructions. Available for: 2002-2007 WRX/STI 2005-2009 Legacy GT *Requires the use of the COBB SF Intake system, package deals available
__________________
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. SUBARU EXPERT GROUP - MARSHALL GLASGOW | BILL GREGG | JON BOWEN | LANCE LUCAS | MATT BRYANT | MIKE MCGINNIS To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
03-06-2010, 01:59 PM | #8 |
Member#: 4803
Who wants some horsepower?!?
__________________
03-10-2010, 02:33 PM | #10 |
Member#: 4803
COBB Tuning is proud to announce the release of BETA support for 2010 Forester XT AccessPORT. Those looking for an immediate solution for datalogging, live monitoring and ProTuner support can update their current AccessPORT AP-SUB-003 or purchase a new unit and update it to the latest BETA firmware. ProTuning is currently required from select ProTuners using the BETA software, with Off The Shelf maps and AccessTUNER Race becoming available once BETA testing is completed in the near future. This new release is just the beginning of unlocking the secrets of the newest Subaru platform. Look for more and exciting announcements from COBB Tuning in the very near future!
__________________
03-30-2010, 11:54 PM | #12 |
Member#: 4803
Bump for corn juice!
__________________
03-31-2010, 06:10 PM | #13 |
Member#: 240740
Vehicle:2008 LGT 5eat |
Legacy e85?
Do you offer any services for Legacy GT owners who want to run e85? Is it possible to switch between normal gas and e85 on the fly using an accessport?
04-05-2010, 04:09 PM | #14 |
Member#: 4803
Vitamin_G-
We can definitely set you up to run E85. Give us a call at 503-670-9500 if you would like to set up an appointment for labor and a tune. As far as switching on the fly, it is not that simple. To switch between different fuels, you will have to completely drain your tank of one fuel and fill it with the other. We can show you this process as we drain your tank. Thanks!
__________________
04-05-2010, 11:37 PM | #16 | |
Member Sales Rating: (9)
Member#: 227731
NWIC
Vehicle:2004 Ford Crown Vic Police Interceptor |
I am curious about this aswell because, in a month or so, I want to go stage 2 on e85 with the option to switch to a more easily attainable fuel map if I'm in an area that has no e85 available. |
04-06-2010, 11:45 AM | #17 |
Member#: 206177
I have never used an AP, but tuning between E85 and 92 on a SAFC, I can tell the difference when there's not 100% one fuel or the other.
I'd be more interested to know how the tune accounts for E70 winter blend and E85 summer blend, as this would produce the same variance as not having all one fuel type in the tank. |
06-08-2010, 07:59 PM | #18 |
Member#: 4803
You have to drain as much existing fuel as possible when switching.
Stage 2 Packages are still available! Give us a call for a full quote.
__________________
06-15-2010, 03:09 AM | #19 |
Member Sales Rating: (26)
Member#: 175031
NWIC
Vehicle:2009 FXT Chamelia Red |
how much would an E85 injection kit and tune cost me...?
im installing a vf22 in the coming week and was planning on getting a great aggresive tune from you guys..considering E85 pending the price of it all... !!!=] ill call for dyno tune appointment soon but would like to know what the e85 kit and tune would run me!!!! |
03-10-2011, 05:55 PM | #22 |
Member#: 4803
We're still in R&D on those exhaust pieces. Stay tuned and we'll let everyone know when they're available
__________________
COBB Tuning Surgeline Sale! * Perrin * GrimmSpeed * Aquamist * E85 Power Packages * | Cobb Tuning | Engine/Power/Exhaust | 4 | 03-12-2010 07:08 PM |
COBB Tuning Surgeline Weekly Tunes! GTRs, WRXs, E85, 2700WHP Oh My! | Cobb Tuning | Proven Power Bragging | 24 | 02-23-2010 12:18 AM |
Legacy GT Cobb stage 1, Epic tuned STi stage 2...and a stock 335xi | Leggy_09 | Proven Power Bragging | 7 | 09-12-2009 06:07 PM |
COBB AP V2, Stage 2 and Cali gas | deparko | Southern California Impreza Club Forum -- SCIC | 12 | 07-10-2007 04:39 PM |
Anyone using COBB Tuning RT Stage 2? | fassts4 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 11 | 09-07-2001 07:30 PM |
