Welcome to the North American Subaru Impreza Owners Club Sunday November 18, 2018
Old 08-14-2013, 11:53 PM   #76
teethandnails
Member#: 340175
2013 WRX Hatch
WR Pearl Blue
Originally Posted by tinkwithanr View Post
I'm not sure if I love or hate this thread. Lots of great info, but I wasn't planning on going stage 2 until I read through this. I mean do I really need a warranty....
If it blows up... just gives you an excuse to make it cooler.
Warranties are for chumps
teethandnails is offline   Reply With Quote
Old 08-15-2013, 11:52 AM   #77
2012STORMTRP
Member#: 313767
2012 WRX Limited
Car: 2012 WRX Limited
Mileage: 21400
Mods: Stage 2+ Grimmspeed Ported N Polished & Ceramic Coated Manifolds, Crosspipe, Uppipe W/EWG, Tial 38mm EWG, Grimmspeed EBCS and Manual Boost Controller, Grimmspeed Lightweight Crank Pulley, Moroso Dual Catch Cans, Process West TMIC, Turbosmart Dual Port BOV ( set to Recirc ), Cobb SF intake with the box, Invidia Catless DP ( Ceramic Coated by Grimmspeed ), Invidia Q300 Catback w/ Titanium Tips, DW 65c Fuel pump, Kartboy Short Throw, WC Lathe Works Titanium Shift knob, Acess Port V2 Protune
Tuner: Mike Botti
Dyno: Mustang AWD - 307WHP 325TQ on all fours
Stage 1 since 600 Miles ( Dealer installed Q300 and Cobb Intake )
Stage 2 since 1800 Miles ( Protune by Akuma Morotsports in NJ - 287WHP - 313TQ )
Stage 2+ since 17k Miles - Added Moroso Catch cans, fuel pump, and new upipe with Tial 38mm EWG
Can runs like a champ
2012STORMTRP is offline   Reply With Quote
Old 08-15-2013, 02:43 PM   #78
FCmaniac
Member#: 142029
2013 Forester
2008 350z, 1991 Miata BRG
^^what max IDC's are you seeing?
FCmaniac is offline   Reply With Quote
Old 08-15-2013, 05:33 PM   #79
wrxaussie831
Member#: 279113
2011 WRX Sedan
Dark Gray Metallic
2011 WRX Premium Sedan
Stage 2 at 37k
Mods: Nameless Axleback, Perrin TMIC, Invidia Catless Downpipe (heat wrapped), AEM CAI
POWER: 336awhp/356 ft-lb torque
Tuned by: Mike Adkins (MTuned) at VSR Motorsports
wrxaussie831 is offline   Reply With Quote
Old 08-15-2013, 10:25 PM   #80
2012STORMTRP
Member#: 313767
2012 WRX Limited
88% at WOT, Stock Injectors. usually around 30-40 at moderate throttle
Old 08-15-2013, 11:02 PM   #81
teethandnails
Member#: 340175
2013 WRX Hatch
WR Pearl Blue
What target AFR are you running? Must just be that part of the country.. At 11.2 AFR I was running 93% on stock injectors..
Old 08-15-2013, 11:18 PM   #82
2012STORMTRP
Member#: 313767
2012 WRX Limited
Accessport sits steady at 11.1 at WOT, I did change my fuel pump to a DW 65C maybe it feeds my stockers better?? I have no Idea what my target is... I'll check it out the next time i got for a spin.
Old 08-16-2013, 01:04 AM   #83
Coreycarlile911
Member#: 282614
2006 Wrx sti
Black pearl
Car: 06 sti 138k miles stage 2 since 20k and pro tune at 60k
Mods:[email protected] shortram
- hks tbe
- Perrin turbo inlet hose
- grimmspeed 3 port
- grimmspeed lightweight crank pulley
- grimmspeed up pipe (ewg going on next tune with headers)
-random mounts and bushings
Power: Car was protuned by Cobb tuning in Portland Oregon on a mustang with a ap set up with various boost maps 16-19 and also track versions of all boost levels. The 19 map made 295hp 325tq. So car has been stage 2 for 108 k and still runs and pull just as good as the day it was stage 2.
Coreycarlile911 is offline   Reply With Quote
Old 08-25-2013, 11:25 AM   #84
wrxratedsti
Member#: 108667
2004 sti:
shorty ram intake
catless tbe
stage 2 on 93 for past 10k, car has 58k
car runs strong and gets about 25mpg if i keep my foot out of it...
wrxratedsti is offline   Reply With Quote
Old 08-26-2013, 01:12 AM   #85
whitewater_ncsc
Member#: 366521
I am glad to see this, I was thinking about starting a similar thread since I have all my parts to go stage to but reading all those engine failure thread are starting to give the cold feet.
I should probably just stop reading and do it...
whitewater_ncsc is offline   Reply With Quote
Old 08-26-2013, 08:40 AM   #86
jerbull88
Member#: 248089
2015 sti
metallic grey
Unless you have a wideband o2 then you have no way of knowing your wot AFR.
jerbull88 is offline   Reply With Quote
Old 08-26-2013, 12:28 PM   #87
fastman
Member#: 333680
2013 STI Hatch
ISM
Alas, I have left you all and went the Pro-tune route yesterday after about 4150mi
fastman is offline   Reply With Quote
Old 08-26-2013, 02:42 PM   #88
BApat
Member#: 357829
2013 STi
Tangerine Orange Pearl
What do you mean by this? Are you implying that because you are pro-tuned you aren't considered Stage 2 anymore?
BApat is offline   Reply With Quote
Old 08-26-2013, 03:03 PM   #89
damian_mb
Member#: 365650
2013 WRX Hatch Base 13,000 miles
Stage 1 93 octane OTS map @ 1500 miles
Stage 2 93 octane tweaked OTS map @ 12,000 miles
Stage 2+ (injectors, pump, FMIC, and BPV) Pro Tune @ 13,000 miles
20lb's is coming up next... My tune is very safe.. A little too safe. My tuner agreed to turn it up. 310awhp goal.
Mods: COBB airbox, Invidia Q300 turbo back, Synapse DV, Racer X FMIC, FIC 1100CC injectors, 65c fuel pump, Grimmspeed 3 Port
Protuned by Kozmic Motorsports: 290whp 302wtq on a mustang dyno @ 18.5lbs
I think you are well above 310awhp actual numbers, unless you want 310awhp on the stang dyno.
damian_mb is offline   Reply With Quote
Old 08-26-2013, 04:16 PM   #90
Wrexflex
Member#: 326301
2012 WRX LR - Sold
2015 Forester Premium CBS
2012 WRX sedan base 25,000 miles
Stage 1 93 octane Cobb + AEM Map @ 2,500 miles
Stage 2 93 octane Cobb+ AEM Map @ 5,000 miles
Stage 2 93 octane Torqued Perf. map @ 6,000 miles
Stage 2+ 93 octane protune @ 20,000 miles
Mods: AEM CAI, Invidia Q300 cbe, Maddad Catted DP, Process West tmic, DW750cc injectors, DW 65C fp, GS 3port EBCS, NGK colder plugs, GS light pulley, Forge BPV @ 21psi.
Protuned by Ray @ Turbotek Tuning: 333 whp @ 5600 rpm, 337wtq @ 4000 rpm.
Wrexflex is offline   Reply With Quote
Old 08-27-2013, 11:58 AM   #91
fastman
Member#: 333680
2013 STI Hatch
ISM
I guess your right. I'm still worthy to be classed as Stg 2
Old 08-28-2013, 08:26 PM   #92
Joe02wrx
Member#: 284636
2002 Wrx wagon
Mileage: 21400
Tuner: Mike Botti
Now tgv delete to get the most out of her
Joe02wrx is offline   Reply With Quote
Old 08-30-2013, 10:30 PM   #93
kbobomber89
Member#: 231418
2006 WRX
i own a 2006 wrx now but my first wrx was stage 2 for a while.
2005 WRX
mods: catless turbo back exhaust, cobb intake, gimmick turbo inlet, catless up-pipe
unsure of the mileage but i ran cobbs ots stage 2 map for a little over 6 months with no issues until my protune. blew up on the dyno
kbobomber89 is offline   Reply With Quote
Old 08-30-2013, 11:57 PM   #94
Andrewxxcarlson
Member#: 316415
2006 WRX
Yikes... ^^^^
Andrewxxcarlson is offline   Reply With Quote
Old 08-31-2013, 10:15 PM   #95
kbobomber89
Member#: 231418
2006 WRX
Yea well the tuner started by saying "tuning subarus are difficult for me". So I was skeptical but what's done is done. 10 hard pulls was a little much I thought and that's why I think the motor popped. Very disappointing day.
Old 08-31-2013, 10:22 PM   #96
Asharus
Member#: 276300
2015 Ford Mustang GT
Oxford White
wow, i woulda left the place as soon as he said that.
Asharus is offline   Reply With Quote
Old 09-02-2013, 10:29 PM   #97
sizemic1
Member#: 270669
2011 WRX Sedan
Stg 2 Phatbotti e-tuned
CAR: 2011 WRX - 52,000mi
MODS: CNT catted downpipe , Invidia q300 catback, Cobb AccessPort,
POWER AND TYPE OF TUNE: ~300ish e-tune by Ron Watson of Phatbotti
HOW LONG: 40,000mi
sizemic1 is offline   Reply With Quote
Old 09-05-2013, 04:58 PM   #98
kilfarsnar
Member#: 106116
2016 VW Golf R
Limestone Grey
2006 WRX Wagon, ~81,000 mi.:
Relevant Mods:
TurboXS downpipe, Greddy Evo2 axle-back
Grimmspeed EBCS
Walbro 255 fuel pump
Group-N Engine & Trans mounts
VF39 turbo
STi TMIC, hood scoop boot & splitter
Stage 1 at 20,000 mi., Cobb OTS
Stage 2 at 40,000 mi., Protuned at EFI Logics by Chris, 299 WTQ/225 WHP
Stage 2 w/ Greddy at 50,000 mi., Retuned by Chris, 288 WTQ/245 WHP
VF39 at 71,000 mi., Protuned by Bren, 330 WTQ/290 WHP
Data logs look good, and the car feels great!
kilfarsnar is offline   Reply With Quote
Old 09-05-2013, 05:04 PM   #99
teethandnails
Member#: 340175
2013 WRX Hatch
WR Pearl Blue
Yeah I want to make 310 on a mustang :-))
Old 09-05-2013, 05:24 PM   #100
HyG3nx
Member#: 355826
09 WRX hatch
Relevant Mods:
Grimmspeed EBCS
VF39 turbo
How or why did your wtq go down after installing axel back?
HyG3nx is offline   Reply With Quote
