02-18-2013, 08:33 PM | #1 |
Member#: 179014
Vehicle:'06 WRX/STi Built Motor/6766/E85 |
Non-AVCS Cams in AVCS Heads?
I have searched and searched and couldnt really come up with all that actually needs to be done.
Anyways, I purchased some Crower 272 cams (Not Brian Crower) and they happen to be Non-AVCS cams for a EJ25. What I have gathered so far is that the intake cam gears needs to be swapped to the 2.0 liter intake cam gears. Can anyone confirm this? I also gathered that since there is two cam sensors on the AVCS heads, that using these cams ill actually only be using one of them since one side reads the cam position and the other operates the AVCS. Can anyone confirm this aswell? Ive seen like only two cars that have had these cams, but cant get any info on what was completely done.
02-19-2013, 10:31 AM | #2 |
Member#: 90642
Vehicle:WKD Everything |
we put non avcs cams in avcs heads all the time, but not on cars that are setup to use avcs. mechanically its simple, you just swap the cams and the timing assembly parts that are related.
sorry if that only helps with part one |
02-20-2013, 02:47 PM | #3 |
Member#: 179014
So basically just change the the cam gears to 2 liter cam gears and thats it?
02-20-2013, 04:58 PM | #4 |
Member#: 118630
South East
Vehicle:2005 Wrx wagon Red |
Tell us more of what you're trying to do. Sounds like you're not disabling AVCS but you were trying to upgrade the intake cams and you realized you bought non AVCS cams. The exhaust side on an 06 wrx is non-avcs, Only the 09+ sti's have intake and exhaust variable cam timing.
You'll need to send the non AVCS cams back and get new cams for Avcs enabled subarus. AVCS enabled subaru ECU's have the cam position sensor mounted in the head and it reads directly from the cam itself. If the cam lacks the coin slot like divot in the back of the cam, the sensor won't be able to work and you'll throw a code, the cam will also lack the oil passages needed to activate the AVCS which works by rotating the cam gears themselves via oil pressure. You won't have a leak or break the car by not having those passages but you'll never be able to actuate the AVCS without them and there's no real way to machine those in without doing more expensive work than buying the correct units to begin with. Non-AVCS engines have the cam position sensor mounted behind the intake cam pulley itself on the driver side bank only, you can get the adapter from a couple different manufacturers. However, the AVCS enabled ECU's have 2 cam sensors so you can't even retrofit that way I don't think. Lastly, regardless of leaving AVCS on or off, the stock 2.5L AVCS cams will out perform the 2.0L cams. Either stay with the stock cams or swap the upgraded ones for units with the AVCS cam position sensor slots and the AVCS oil passages. Really, you can just swap them for the same cams made instead for the STI. It's the same thing. |
02-20-2013, 08:41 PM | #5 | |
Member#: 179014
As of right now, I believe I have the solution to it: WRX cam gears, Non-AVCS cam seals, and delete the code for whichever cam sensor that throws a CEL. |
02-20-2013, 10:40 PM | #6 |
Member#: 118630
South East
Well there you go then. I actually have a set of Non AVCS cam gears if you'd like to trade.
01-09-2018, 10:51 PM | #7 |
Member#: 160587
RMIC
Vehicle:2005 Impreza WRX STi Obsidian black pearl |
well you can run them, but like what everyone else said, probably a bad idea. I bought AVCS cams, but got the non Avcs cams and put them in, car runs well, just dies at idle and oddly only throws the driver side code P0345
07-30-2019, 05:51 PM | #8 |
Member#: 504553
SCIC
Vehicle:2005 WRX wagon Platinum Silver |
I read everything you guys wrote here and I just want to make sure I have the right understanding of this. I have a slightly different setup, but same issue.
I have an '05 wrx, I got my hands on an JDM AVCS EJ205 and slapped it in. I was thinking instead of going the "buy JDM harness and ecu" route, I'd just buy some non-AVCS cams, and cam gears and cancel out avcs all together. Is there anything that I'm missing to delete avcs? |
