Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 01-31-2007, 12:24 PM   #1
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
Default 04 Sti steering rack into an 02 WRX
I've done the search and have not found the answers.
Is this a direct fit replacement.
Do I need to replace the pinion with the rack?
I have ordered just the steering rack and was needing to know if I need the pinion also.
Any and all help will be greatly appreciated.
Thanks,
Don
Don Arm is offline   Reply With Quote
Old 01-31-2007, 12:44 PM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Originally Posted by BIGSKYWRX View Post
The 04 (usdm) STi has the "old" style rack/cross member- it is a direct bolt in for the 02-40 WRX's.
"Rack and pinion" refers to the internal configuration - everything's inside one box. It attaches to the stock steering column u-joint.
If I were you I'd replace the mount bushings with some nice urethane ones while you're under there. You will also need a bottle of fluid to complete the swap (it's ATF - may as well step up to a synthetic e.g. the Motul 1 ATF).
UkNuck is offline   Reply With Quote
Old 01-31-2007, 03:32 PM   #3
Don Arm
Member#: 17520
2002 Impreza WRX
Midnight
Thanks, appreciate the quick response.
putting an 08+ STI steering wheel into an 07 WRX? NMZ_WRX Interior & Exterior Modification 1 05-19-2010 08:57 AM
06 STi steering rack into an 02 WRX? Arnie Subaru Conversions 0 12-23-2009 07:26 PM
FWD impreza steering rack on an 02 WRX Skoobie Brakes, Steering & Suspension 0 02-16-2008 12:26 AM
JDM STi Steering Rack on a 02 WRX? NothnButTheFacts Brakes, Steering & Suspension 7 11-26-2007 08:50 PM
will an 05 sti ebrake fit into an 02 wrx? blueandgold Interior & Exterior Modification 3 10-07-2006 03:51 PM
