Welcome to the North American Subaru Impreza Owners Club Tuesday November 20, 2018
Old 12-23-2009, 07:26 PM   #1
Arnie
Member#: 1725
99 Subaru Impreza
GF silver
Default 06 STi steering rack into an 02 WRX?
Well, tried to search for specifics but any info of substance eluded me. Please posts up if you have any threads of note.
With that said, I'm looking to install an 06 STi steering rack into my 02 WRX wagon. I would also be using the 06 STi crossmember. What am I looking at as far as compatibility is concerned? Should it just bolt up? Are the power steering lines a straight bolt up to the older 02 power steering pump? What about the steering column? Are the splines/spline count the same between the two cars or should I make sure to get the STi steering column as well? I've never done power steering work before, when I install the lines are their o-rings or something used? Is it a good idea to source fresh ones?
Any tips and insight would be greatly appreciated.
Arnie is offline   Reply With Quote
putting an 08+ STI steering wheel into an 07 WRX? NMZ_WRX Interior & Exterior Modification 1 05-19-2010 08:57 AM
FWD impreza steering rack on an 02 WRX Skoobie Brakes, Steering & Suspension 0 02-16-2008 12:26 AM
JDM STi Steering Rack on a 02 WRX? NothnButTheFacts Brakes, Steering & Suspension 7 11-26-2007 08:50 PM
04 Sti steering rack into an 02 WRX Don Arm Brakes, Steering & Suspension 2 01-31-2007 03:32 PM
will an 05 sti ebrake fit into an 02 wrx? blueandgold Interior & Exterior Modification 3 10-07-2006 03:51 PM
