#1251 |
Member#: 487006
Vehicle:17' STI not wrb... |
![]() General maintenance today; cabin filter, intake filter, and oil change.
#1252 |
Member#: 506894
W. Canada
Vehicle:2013 STi Grey |
![]() I tore out my stock IHI VF48 turbo to do a swap. Turns out the replacement turbo has a chip on the compressor side turbine. I also installed a tomei turbo inlet tube!
So now the car is sitting in the garage in pieces! |
#1253 |
Member#: 463349
Vehicle:2017 WRX Sport World Rally Blue |
![]() I decided to cover up that fake carbon fiber trim and flock it.
#1254 |
Member#: 491364
![]() After over a month of waiting, I finally received and installed the non resonated mid pipe.
#1255 |
Member#: 506642
BAIC
Vehicle:2017 WRX crystal white pearl |
![]() Finally went stage 2 with my 2017 WRX install went smooth no broken studs or stripped nuts
#1256 |
Member#: 251046
Vehicle:2004 WRX Wagon Stage 5.1.2a.2 |
![]() Installed the snow performance meth kit for my rotated setup. I put it in the spare tire well. Had to cut out that bump first. Hammered out the well in two spots. Carved a contour into some foam and then strapped down the tank. Ran the lines and got most of the wiring done. The top panel fits over the tank with about 1/2 inch to spare. I’m going to build a metal frame so that when closed, I can still put stuff in the trunk.
#1257 |
Member#: 496168
SCIC
Vehicle:2019 WRX Series.Gray |
![]() In the last few days I have swapped out my brakes to StopTech slotted rotors, performance pads, and ss braided lines, installed a Invidia Q300 CB exhaust, added a vortex generator, and installed a CS style front lip. Its been a busy couple of days, but the car is finally getting to were I want it.
#1258 |
Member#: 507023
NWIC
Vehicle:2005 2.5RS Impreza 35J - Regal Blue Pearl |
![]() When I got my 2.5RS it came with Forester wheels on it for some reason.
A few days ago I got and installed WRX rims, and got new tires all around. In the next week or so I'll be doing better break pads. Then I think I'll need to do the struts soon, the rears are leaking a tad, or should I replace struts first then do break pads. I mean, the car stops and all. |
#1259 |
Member#: 498642
Vehicle:'19 WRX Ltd 6M dgm '08 Mustang GT (the toy) |
![]() Inspect the pads at least for remaining friction material thickness and absence of extreme amounts of taper wear and let that be your guide.
A little late this time, but changing (or rotating) tires is a great opportunity to make at least a quick and dirty brake inspection. Norm |
#1260 |
Member#: 492327
Vehicle:19 WRX 16 STI 17Mk7R 20Supra 20Forester |
![]() Got my WRX and STI a new to me home.. it's got a large attached finished garage and I absolutely love it. Been giving the garage my finishing touches (epoxy floor, large LED overhead lights, new wifi enabled garage door openers, new shelves, workbench, etc etc) the last few weeks and hope to finish by end of the month.
#1261 |
Member#: 457131
SCIC
Vehicle:2011 WRX Sedan DGM |
![]() Changed spark plugs and decided to do a leak down test as well: 4% on cyl 1 and 2, 8% on cyl 3 and 4. Not bad for 98k miles.. I think. Could be worse!
#1262 |
Member#: 472279
NESIC
Vehicle:2015 WRX ( traded ) 2019 WRX WRB |
![]() Last edited by MAD WRX; 10-04-2019 at 04:17 PM. Reason: typo |
#1263 | |
Member#: 491364
![]() Quote:
Which muffler delete did you get? I paired it with the double wall burnt tips. Somehow, this mid pipe is more quiet than the stock especially on idle IMHO but it does have a nice roar when you step on it. |
#1264 |
Member#: 268031
Vehicle:2006 Forester XT |
#1265 |
Member#: 180155
NWIC
Vehicle:05 Jdm Sti 2.0 PSM |
#1266 |
Member#: 507100
![]() I traded my 2012 WRX in today
#1267 |
Member#: 507114
![]() Oil and filter change, added winter -20 washer fluid.
Bled brake fluid & added fresh clean fluid, topped off coolant. Rain X'd windshield. Washed car. Fresh coat of wax. Resurfaced headlights. Rotated tires. Properly torqued lug nuts. Checked tire pressures. Drove 80 mile round trip to pick up some business related items. Several hours later rechecked the tire psi and hit up the lug nuts again to ensure all torque specs are still in range. Kind of an over-achiever. She's almost ready for winter. |
#1268 |
Member#: 498242
![]() I started to drive to Virginia City in my 02 WRX wagon this afternoon, I got about halfway and my TMIC coupler came loose. I lost boost and drove home very slowly. I fixed the coupler back to the intercooler and tightened it up. I tried the drive again, and everything held up fine (my rotors did get a little warm towards the end). I had a blast.
![]() 02 WRX wagon AEM cold air intake MaXpeedingrods Coilovers Tomei equal length headers Tomei up pipe HKS turbo-back exhaust Lightened flywheel Extreme calipers with drilled n slotted rotors PnP TD04 Grimmspeed boost controller |
#1269 |
Member#: 302548
Vehicle:2019 Golf R 2018 High Country |
#1270 |
Member#: 498642
![]() Last edited by Norm Peterson; 10-10-2019 at 07:59 AM. |
#1271 |
Member#: 470679
Vehicle:2018 WRX Pure Red |
#1272 |
Member#: 498642
![]() Thanks; I never would have guessed.
Is it brighter than OE or is there some other advantage? Norm |
#1273 |
Member#: 498642
#1274 |
Member#: 397956
South East
Vehicle:2014 Forester Washington Black |
#1275 |
Member#: 498642
![]() Thanks again.
If I do this, I'm wondering if I might want to put it on a toggle-switch arrangement so that it doesn't have to illuminate every time the car is in reverse (potentially attracting unwelcome official attention). Many moons ago I adapted a fog light to improve reverse lighting in dark areas, so there's a chance I might actually do this. Norm |
