Welcome to the North American Subaru Impreza Owners Club Saturday March 6, 2021
Old 01-17-2021, 11:22 PM   #2051
peerless
Member#: 521123
02' Legacy Wagon
Metallic Green
Stripped out the A/C from my little 02 Leggy Wagon. Haven't got the condenser out soon. Going to be replacing the coolant outlet and bypass hose so will pull the radiator then and get the condenser out.
Also going to pull the A/C / Alternator bracket out and cut it down to size as its slightly ridiculous at the moment with all the extra beef to be able to support the A/C compressor. Or I might just fab up a entirely new bracket from mild steel but I have a feeling the factory piece is going to be lighter and cleaner looking then anything I might be able to cobble together.
peerless is offline   Reply With Quote
Old 01-18-2021, 09:38 PM   #2052
Kochi_STi
Member#: 369411
2002 WRX STi Limited
Originally Posted by jdm05 View Post
Curious to how you like the new suspension bits. Want to replace mine soon too.
So I got her back last night with a good inspection sticker for 2 years. Had all 4 wheel bearings replaced (at my request) as they were noisy and had some play. Wheels are much quieter now.
As far as the trailing arm and rear knuckle bushings are concerned, I think it’s one of those mods you can get away with without any real negative side effects. It’s not any noisier and doesn’t feel harder, but I can feel a difference in the rear end and cornering feels more consistent.
At least I feel like I can get away with it on my car because I’ve already replaced most of the rubber bushings and mounts with poly and there’s a lot of road/engine noise.
Kochi_STi is offline   Reply With Quote
Old 01-18-2021, 10:19 PM   #2053
peerless
Member#: 521123
02' Legacy Wagon
Metallic Green
So I put my alternator bracket on a 10oz diet
Well I got it all cleaned up so its not some bulky thing that is obviously missing an A/C compressor.
Old 01-19-2021, 02:49 AM   #2054
Bullitt3577
Member#: 497200
2019 WRX
Cool Gray Khaki
Default What'd you do to your subie today?
Installed the blower motor cover under the dash on the passenger side to muffle out the blower motor whine/buzz on my 19 WRX. It definitely helps quiet it down and was $45 well spent! Here’s the part numbers in case anyone else wants to order it.
Panel #66066FJ010
Push pins (Need 2) #99045AE020JC
Bullitt3577 is offline   Reply With Quote
Old 01-21-2021, 10:31 AM   #2055
Discard_WRX
Member#: 440751
2020 STI
Pure Red
STI front lip and nameless performance 4" muffler day
Discard_WRX is offline   Reply With Quote
Old 01-21-2021, 08:29 PM   #2056
Pumkin
Member#: 400308
2018 STi
Installed Perrin pitch stop, Perrin strut brace and Grimmspeed intercooler couplers.
Pumkin is offline   Reply With Quote
Old 01-21-2021, 08:34 PM   #2057
SeattleSup
Member#: 521836
[quote=Discard_WRX;46502562]STI front lip and nameless performance 4" muffler day
Hey, I threw on a 4" set today too! Previous owner has deletes and were not my cup of tea.
SeattleSup is offline   Reply With Quote
Old 01-22-2021, 11:37 PM   #2058
cocoykc
Member#: 521388
Just came back from a nice night time ride.
cocoykc is offline   Reply With Quote
Old 01-23-2021, 06:32 PM   #2059
andresohc
Member#: 521737
Default Replaced tranny, diff, half shafts.
Trying to replace the rear driveshaft (transmission to rear diff) but the part my son got of ebay has a destroyed center CV joint. Also the driveshaft I pulled out is 63.5 inches long which is one inch longer then the ones listed for sale for same vehicle. Had to replace the tranny because the input shaft bearings above the center diff exploded as well as the rear seal. Metal parts all thru the tranny. Its been quite an adventure.
andresohc is offline   Reply With Quote
Old 01-24-2021, 11:46 AM   #2060
JT20
Member#: 521888
Today, I went to it, put my cupholder in, and left it at the shop for Monday's minor bodywork and external AT filter change.
New here, Hello everyone!
JT20 is offline   Reply With Quote
Old 01-24-2021, 11:51 AM   #2061
Doppio
Member#: 519052
'17 STI Ltd.
'15 WRX - Sold
Oil, diff and trans' service with motul all around.
Welcome aboard
-D
Last edited by Doppio; 01-24-2021 at 11:51 AM. Reason: Grammar. Spelling is hard....
Doppio is offline   Reply With Quote
Old 01-24-2021, 12:57 PM   #2062
JYC11
Member#: 521881
2010 STI Hatch
Gray
Tried to list it for sale!
JYC11 is offline   Reply With Quote
Old 01-27-2021, 10:40 PM   #2063
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Saabaru: all year round driver.
Removed the second tray from the 1up bicycle rack, checked oil level because it has developed a leak.
Bugeye: good weather only vehicle.
Installed ecu and trim, applied anti seize to front Brembo caliper bolts, pushed caliper pistons in all the way in anticipation for new pads and rotors.
D-Rodman is offline   Reply With Quote
Old 01-27-2021, 10:51 PM   #2064
WallopingTuba
Member#: 488146
2015 WRX
Red
Picked her up from the dealer after about 4 weeks.
WallopingTuba is offline   Reply With Quote
Old 01-28-2021, 12:22 PM   #2065
Dorsz914
Member#: 521998
Mounted Invidia q300 exhaust.
Dorsz914 is offline   Reply With Quote
Old 01-28-2021, 11:30 PM   #2066
Scorpius
Member#: 370806
2019 WRX/STI DGM
2016 WRX/STI ISM
Aimed my headlights as they seemed a bit lower than normal after the front end was rebuilt after I went deer hunting.
Scorpius is offline   Reply With Quote
Old 01-31-2021, 03:34 AM   #2067
Kochi_STi
Member#: 369411
Oil change, wash, and wax coating on the carbon.
Old 01-31-2021, 07:57 PM   #2068
haveatank
Member#: 463244
Sold my WRX
haveatank is offline   Reply With Quote
Old 02-01-2021, 04:17 PM   #2069
idntvpe
Member#: 521263
Drove it to work
idntvpe is offline   Reply With Quote
Old 02-02-2021, 10:58 PM   #2070
D-Rodman
Member#: 110078
02 Bugeye JDM STi
OBP BLACK
Saabaru:
Replaced right side rear brake caliper, picked up a remanufactured caliper at the local Subaru dealer. Pricey at $149 considering a remanufactured from Rock Auto is half the price, hopefully it’ll last a long time and I’ll feel better about it. Replaced the rear brake pads and brake rotors while at it.
Old 02-02-2021, 11:47 PM   #2071
Foo_Blyat
Member#: 93750
Looks good. Subaru actually has an oem ac delete bracket that's super light for those that don't have the tools to cut down the cast bracket
Part number 11711AA090
Foo_Blyat is offline   Reply With Quote
Old 02-03-2021, 09:05 PM   #2072
oxnardkoolkid
Member#: 522137
2017 Wrx
Pearl
Originally Posted by Cons View Post
I don't think we've had one of these in General for awhile. So, without further ado, here's what I did to my subie today:
Wiretucked my accessport wire
And I got my stuck cupholder working. It's amazing how much crud can build up in ~15 years!
How bout you all?
I ended up putting in the flex fuel kit for my 2017 wrx it was a breeze! Cobb made it easy to install. Thanks Cobb
oxnardkoolkid is offline   Reply With Quote
Old 02-03-2021, 09:13 PM   #2073
arempee26
Member#: 491364
Added this rear diffuser. I like this better than the pointy- spiky metal diffusers out there. It gives the rear of the car more aggressive IMO.
arempee26 is offline   Reply With Quote
Old 02-04-2021, 02:32 AM   #2074
gannex
Member#: 522147
I replaced a leaking turbo inlet with a new silicone turbo inlet on my new ej205 swapped 2002 Legacy B4
gannex is offline   Reply With Quote
Old 02-07-2021, 08:05 PM   #2075
arempee26
Member#: 491364
Added the JDM rear splash guard. Now, I can say the rear of the car is finally complete. Still debating if I should add the exhaust finisher or not.
