04-30-2012, 04:16 PM | #651 | |
Member#: 284247
RMIC
Vehicle:2002 Wrx MBP! |
04-30-2012, 04:22 PM | #652 |
Member#: 305000
Vehicle:2005 Legacy GT 5MT Bright Silver Metallic |
I'm really intrigued by your x-brace. i think it could definitely contribute to the rigidity and possibly rear suspension performance. how tightly did you bind it? how did you do it in general? we dont have the CAD CAM machines to run the scenario but the logic seems solid. suspension bridges support massive loads via tension, after all.
04-30-2012, 04:28 PM | #653 |
Member#: 284247
RMIC
^exactly, it had tightened up my rear end up a good amount, i only hand tightened it, but for ****s and gigs i think ill crank it down a little more and see what up with it..
04-30-2012, 05:01 PM | #654 |
Member#: 154173
Vehicle:2006 STI |
04-30-2012, 06:10 PM | #655 |
Member#: 74872
Vehicle:2006 STi White/Black |
Thats Ill! I got same Garmin Nav myself, and I never use it. But I got an idea what to do with it now How did you do this exactly? any info? |
04-30-2012, 07:37 PM | #656 |
Member#: 310040
Vehicle:2004 WRX and 15 sti |
05-01-2012, 02:40 PM | #657 |
Member#: 305000
garmin in instrument panel....
20120501_113618 by tommyburkart, on Flickr 20120501_113610 by tommyburkart, on Flickr |
05-01-2012, 03:43 PM | #658 |
The Emperor Protects
Moderator Member#: 13
SWIC
Vehicle:2019 Kia Stinger, 20 Bolt EV, 23 Jeep GC |
I like to see the tach...
05-01-2012, 04:22 PM | #659 |
Member#: 49297
Vehicle:17 WRX Limited |
I wouldn't call leaning your handheld GPS in your dash cluster a mod of any kind.
05-01-2012, 04:47 PM | #660 |
Member#: 305000
lol, its true. just a reply to earlier garmin stuff
05-01-2012, 07:18 PM | #661 |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
How have you guys mounted your garage door remotes?
Kinda wondering if theres a unique way to mount it in my 09. |
05-01-2012, 07:22 PM | #662 |
Member#: 281811
Vehicle:04 WRX World Rally Blue |
There's a thread somewhere where they soldered wires to the pins where the buttons are and connected them to a momentary push button so you could mount it anywhere.
05-02-2012, 08:07 AM | #663 |
Member#: 241254
Vehicle:2015 Scat Pack |
More gold then your local jewelry store.
I have to get some pictures of a few other things, I spent about 15 hours wet sanding and polishing bare aluminium fuel rails, and a sheet metal intake manifold on the brother in laws 427sb looks tittys now with billet cnc heads and valve covers! I'm trying to figure out how to tackle doing the blower, charge piping and awic next. I spend a lot more time on that car then I do my own especially when it comes to custom modifications. Everything is one off custom made. even our injectors are billet adonized and polished Last edited by noside; 05-02-2012 at 08:14 AM. |
05-02-2012, 11:21 AM | #664 |
Member#: 284247
RMIC
notice any different in under hood heat since the tape? im adding tape and a blanket before "summer" actually kicks in..
05-02-2012, 12:52 PM | #665 |
Member#: 284753
Vehicle:2004 WRX STI World Rally Blue |
05-02-2012, 08:48 PM | #666 |
Member#: 305000
05-02-2012, 08:51 PM | #667 |
Member#: 200132
South East
Vehicle:05 impreza sti AW |
Here's mod mod... audio video aux and usb females in the ash tray.
05-02-2012, 09:34 PM | #668 | |
Member#: 123574
Vehicle:2005 STi CGM |
1) Remove visor (a couple phillips head screws) 2) Remove mirror and cover from visor. The mirror is held in by the frame, which just snaps into place using plastic tabs that go under a metal piece in the visor 3) Start trimming. The hole left by the removal of the mirror and frame was about perfect for my GPS, but others may vary. Beneath where the mirror and frame used to be is metal and foam. I used a dremel to trim cut a square out of the metal, then a knife to cut out some of the foam. This leaves you with a thin section of foam and the fabric for the other side of the visor, which is thin enough to hear the speakers through. 4) Test fit, trim, test fit, repeat 5) Once you are satisfied with the results of step 4, clean up any obvious ugly edges with a needle and thread. As you can see from my pic, the spot where the antenna goes under the fabric was sort of rough, so using my 5th grade sewing class whip-stitch skills, I sewed it up a bit to make it look a little cleaner. 6) Now route your power cord through the visor. I cut a small notch in the stitching near the rod at the top left of the visor, where it attaches to the roof. Then I fed the power cord through there and cut another small notch into the remaining metal in the visor near the right side of the GPS. This small notch was used to hold the tip of the power cord in place with a pressure fit. My power cord came with small plastic ridges on it near the tip, which also helped when pressing it into the notch. 7) I kept the bottom part of the mirror frame in place for additional support for the GPS and to hide the lower exposed edge. Just trim it with a dremel, cut new notches for the tabs in the visor's metal (may not be necessary depending on your GPS), and push it back into place. 8) At this point you're ready to stick the GPS in. I decided to add some velcro for additional security in the visor. Two pieces of velcro stuck to the back of the GPS mate up with two pieces stuck to the foam behind the GPS in the visor. 9) Clean up the cut from where the power cord enters the visor. Again, I just did some whip-stitching that closed the cut as well as held the cord in place. 10) Remount the visor 11) Route the power cord. For this I ran mine behind the A-pillar and down to a new fuse under the dash. |
05-02-2012, 09:34 PM | #669 |
Member#: 272381
Vehicle:2004 Franky the Forester |
I can't find the thread at the moment, but I did see one where the guy removed the case and got it mounted under his shift boot. Only he knew the location of the button, and it was out of the way.
05-02-2012, 09:44 PM | #670 |
Member#: 123574
I really like this. I wanted a grille for my FMIC and I ended up just using some painted masonry mesh formed around the edges at the back of the opening, then epoxied in place. But I like your solution with the black trim around the mesh much better. Can you give any more details about it? How did you mount the grille to the bumper?
05-02-2012, 11:13 PM | #671 | |
Member#: 252324
Vehicle:04 STi JBP |
I got it from here... http://www.arbodies.com/abc-bodies/a...s/grillscreens |
05-02-2012, 11:21 PM | #672 | |
Member#: 281811
05-02-2012, 11:40 PM | #673 |
Member#: 200132
South East
Haha, I was going to do my RCA's on the bottom too.... When I went to drill the hole, I drill the aux (was going to be top left and usb to the right of that) too big (didnt measure the bit just eye-balled it) so I had to change the game plan. Still works out nicely, though I'll probably never use the RCA. I just wanted to have a nice flush look instead of wires sticking out somewhere.
05-06-2012, 10:48 AM | #674 |
Member#: 217257
Vehicle:2008 2.5i hatch Satin White Wrap |
05-06-2012, 11:14 AM | #675 |
Member#: 284247
RMIC
wrap? In going with woodgrain for mine
Similar Threads | ||||
Show us your unique modifications | lancewr1 | Interior & Exterior Modification | 7214 | 01-10-2012 12:09 PM |
Calling all 2011 owners WRX's/STI's - Guys and Gals - Show us your pics and your mods | bluerex79 | Member's Car Gallery | 6 | 05-02-2011 09:02 PM |
Calling all Graphix......Show Us Your Stuff... | grnlantern1 | Member's Car Gallery | 37 | 07-16-2002 01:25 AM |
show us your wrx gauge installs. | lstepnio | Member's Car Gallery | 51 | 05-22-2002 03:43 AM |
Show us your T's (OZ Super T's that is) | Who flung dung | General Forum Archive | 11 | 02-12-2001 07:46 PM |
