04-08-2014, 12:47 PM | #251 |
Member#: 329822
Vehicle:2016 STi WRB |
04-08-2014, 04:00 PM | #252 |
Member#: 310506
South East
Vehicle:2005 WRX STi CGM |
Ok - I called the machine shop. They use a 600 grit polishing method which should not remove any material from the crankshaft but simply clean the surface up. It is not "micropolishing".
04-08-2014, 05:27 PM | #253 |
Member#: 386261
anybody have a sti motor for sale
04-08-2014, 05:33 PM | #254 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
04-08-2014, 08:50 PM | #255 |
Member#: 239335
W. Canada
Vehicle:2011 WRX WRB |
After the polish recheck and see if it is with factory specs. If so it is good to go.
04-09-2014, 10:56 PM | #256 |
Member#: 310506
South East
Dang... So I've measured two rods with the King Bearings (STD) and the 7/16" ARP 2000's, and i'm coming up with clearances of .0036 and .0031... Is this normal for new rods? I've got the Brian Crower H-beam rods and the king standard size bearings. What bearings would I need to get around .0025 clearance??
Thanks! |
04-10-2014, 08:12 AM | #257 |
Member#: 310506
South East
Bumppppp
04-10-2014, 11:25 AM | #258 |
Member#: 56203
Proly from the polished crank?
04-10-2014, 11:37 AM | #259 |
Member#: 310506
South East
No, I compared the values to the oem spec. The crank was perfectly within spec as far as the crank pins are concerned.
I measured the inner diameter of the rod with bearing (2.0506) installed and subtracted 2.0470". That's how I got the clearances. |
04-10-2014, 11:50 AM | #260 | |
Member#: 310506
South East
One thing I thought was weird is I e-mailed Dustin at BC to ask for torque specs / special procedures from them for torquing the ARP2000 rod bolts into the H-Beam rods.
Here's what he said. Quote:
I'm wondering if they need to be tighter, which is causing these larger than usual rod bearing clearances. |
04-10-2014, 12:25 PM | #261 |
Member#: 383547
A 2000 bolt 7/16" diameter thread would need around 80 lbs with moly to get the correct stretch, depending slightly on the length. Typically rods come with torque specs for you to use if you do not have a stretch gage. These torque specs are on average about 15% less than the perfect torque/stretch amount, perfect being 75% of the yield of the bolt. This is not a published fact, it is what myself and other machinists I know have noticed over the years. We think that they supply you with a lesser torque value so that there's no danger of a defective torque wrench or operator to over torque the bolt, surpassing the 75% yield. All rods need proper vetting before being used, checked for correct stretch/torque and then size after reaching the correct torque. That 45 makes no sense to me.
04-10-2014, 12:30 PM | #262 | |
Member#: 383547
04-10-2014, 12:32 PM | #263 | |
Member#: 310506
South East
Hmm - I just called Dustin, and he said that the actual bolt diameter is 3/8", which is why he gave me the torque specs he did. He said the 45ft/lb for the 3/8" should be right. How should I approach adjusting the rod clearances are this point? Last edited by BeastianSTI; 04-10-2014 at 12:52 PM. |
04-10-2014, 01:56 PM | #264 | ||
Member#: 383547
04-10-2014, 02:20 PM | #265 | |
Member#: 310506
South East
I suppose i'll drop the rods off to my machine shop to have them check them out. What specifically should I ask them to check? |
04-10-2014, 03:35 PM | #266 |
Member#: 383547
Ask the shop if they have a stretch gage and can measure the stretch on your rods and note the torque req'd to get there. Bring them the sheet that you got with the rods, it should give the stretch amount. At this point they need to measure the rods for oor and size compared to the stock spec. Not all shops know that this is req'd, if they are among them, then find another shop.
04-10-2014, 03:46 PM | #267 |
Member#: 310506
South East
Dang - it really sounds like there isn't a whole lot I can do to put this engine together if everything requires a machine shop to measure stretch of bolts etc... I thought rods would have been OK to just torque to spec in the specified sequence. Becoming a lot more complex :/
04-11-2014, 10:03 AM | #268 |
Member#: 310506
South East
Hey guys, i'm sure we've all seen that video on youtube where "subaru-mike" assembles the motor:
https://www.youtube.com/watch?v=-gmtEQ1GpmA I was going to follow this for torquing the case halves together to measure my main bearing clearances. I noticed that he says go to 37 ft/lbs for the large bolts, and 20 ft/lbs for the smaller ones. This does differ from the manual, but i'm wondering if going to 37ft/lbs could be a substitute for going to 14.8 ft/lbs -> tightening another 90*. Are there any good resources of tutorials on bolting the case halves together? |
04-11-2014, 10:04 AM | #269 | |
Member#: 348177
TXIC
Vehicle:2002 Bugeye Haltech GTX3584RS |
Dude youre not building a uber precision race motor. These things were designed by engineers to be slapped together with varying degrees of precision. You can get all crazy with stretch and quantify every little measurement if you want too but its wasted effort for a dd. Just torque that **** to spec and drive it. |
04-11-2014, 10:10 AM | #270 |
Member#: 310506
South East
I plan on putting doing 400 WHP... I've always lived by "do it right the first time, or don't do it at all".
I don't want an aluminum paperweight because I didn't follow the proper documentation. All I know is that the key to a good motor is precision in measurements and torque. I want to build it properly. Appreciate everyone's guidance on all of this. |
04-11-2014, 11:35 AM | #271 | |
Member#: 383547
04-11-2014, 11:43 AM | #272 |
Member#: 310506
South East
Could I throw the cases on the engine stand? I found that the block wanted to move around a lot when I was torquing the bolts before.
04-11-2014, 04:49 PM | #273 |
Member#: 310506
South East
OK - confirmed with the machine shop that just finished up the heads and what not that they take the bolts right to 37 ft/lbs as well instead of the 17 - > 90* approach.
Everything measured out appropriately - i'm ready for assembly now!!! |
04-18-2014, 10:01 AM | #274 |
Member#: 310506
South East
Assembled the case with crank and rods last night. I couldn't find anything about bearing tang direction, so I put them all facing down.
Waiting for the piston ring filer to get here so I can adjust the top rings in each cylinder and get this puppy together |
04-20-2014, 07:32 AM | #275 |
Member#: 108051
AKIC
Vehicle:2005 WRX STi WRB |
Yup the wrx fsm calls for 37ft lbs i to do it this way.
