Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 02-02-2018, 04:28 PM   #1726
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Mishimoto cans?
I think you posted before that the hoses and fitting were garbage.
gn4rwhals is offline   Reply With Quote
Old 02-02-2018, 05:06 PM   #1727
undyjr
Member#: 459692
2019 WRX STI
silica black
Originally Posted by gn4rwhals View Post
Mishimoto cans?
Yessir, I enjoyed reengineering the hoses and fittings. A copper tubing bender and 1/2 ACR copper tubing allowed me to duplicate the Mishimoto bends. Slides right in the hose. The same tubing makes a swedged bushing for the PCV valve.
undyjr is offline   Reply With Quote
Old 02-07-2018, 09:57 PM   #1728
Scoobman20
Member#: 388015
Default Lean at initial boost
Hey everyone. I'm struggling to figure out where this lean spike is coming from when I reach boost. I replaced the header gaskets and j-pipe gasket thinking it could be an exhaust leak above the O2 sensor, but no improvement. I also looked over the intake and intercooler couplings. Could this be blow-by from AVCS or some other leak? My other concern is my calculated load seems higher than quite a few logs I'm seeing with similar mods.
Here is the OTS Stage2 Big SF - https://datazap.me/u/scoobman20/stag...og=0&data=8-26
Here is the same map with an OL MAF re-cal and the CL delay reduced and CL map high load changed slightly (better but the spike is still there in the beginning) - https://datazap.me/u/scoobman20/stag....91&tmax=99.60
Mod List:
Catless J-pipe
3" Catback
Cobb 3" intake
TGV delete
EGR delete
Restrictor pill delete
Scoobman20 is offline   Reply With Quote
Old 02-07-2018, 10:10 PM   #1729
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Have you thought about getting a 3 port to contain your overboost? Seems to happen after it spikes then reaches target.
Old 02-07-2018, 10:35 PM   #1730
Scoobman20
Member#: 388015
Interesting observation and thanks for the suggestion, but I don't understand why exceeding the target boost would cause higher values than the commanded AFR. Maybe you know something I don't.
Old 02-08-2018, 12:21 AM   #1731
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
No just noticed it, figured I'd mention it.
Are you running a modified COBB map for the TGV/EGR deletes?
Old 02-08-2018, 12:25 AM   #1732
Scoobman20
Member#: 388015
Yes but only matched the open and closed tgv related maps and disabled all the codes.
Old 02-08-2018, 07:02 AM   #1733
ericdet
Member#: 327563
2018 Civic Type R
2008 N54 335i
Mod List:
Catless J-pipe
3" Catback
Cobb 3" intake
TGV delete
EGR delete
I don't see a spike. I see one log that is lean the entire time and another that is lean for a good portion. The only spike I see anywhere is the Command spike at CL/OL switch which is common. I think you're looking at the wrong end in terms of problems. It appears you have either a scaling issue or a leak in the intake tract. Even the closed loop portion of your log has a very large correction being applied. Almost 24% before the transition. You go from -8% to +25% total fuel in the span of 2000RPM.
If you're using the same valve timing with the factory TGV Open side I don't see AVCS causing these issues. TGV would be normally open in that region. So unless you're changing valve action it shouldn't be an issue. If you have reset to the Cobb OTS for that parameter and see if it changes.
ericdet is offline   Reply With Quote
Old 02-08-2018, 09:40 AM   #1734
tegxsi
Member#: 446029
This is pretty much what you get with OTS maps and from what I've read the COBB BIG SF intake is a pain.
The calculated load on some logs you see on here have the MAF along with a few other things scaled to avoid hitting the 3.30 load limit on the ECU. You will usually see it on Phatbotti/Ron Watson tunes.
When I tune for WOT open loop I zero the delay counter. I don't want any of that Evo like lean spool shenanigans lol.
If I were to tune for WOT full time closed loop then it would be the opposite along with a bunch of changes with the CL fueling and other delays.
tegxsi is offline   Reply With Quote
Old 02-08-2018, 10:11 AM   #1735
Scoobman20
Member#: 388015
Thanks for the helpful replies. That's interesting with the phatbotyi and Ron tunes. I'll try a few more WOT MAF Cal's and see where that gets me but I'm sure I'll hit that load limit. So if I scale the MAF lower then would I have to crank up the VE?
Old 02-08-2018, 10:53 AM   #1736
tegxsi
Member#: 446029
On basic bolt-on's I think most will stay under the limit.
Look for "Boost/Load Hard-coded limits" in Cobb's DIT Accesstuner tuning guide. It's not as easy as it seems since all load related tables need manipulating. You really need to know what you are doing...especially with ignition timing.
Old 02-08-2018, 11:43 AM   #1737
ericdet
Member#: 327563
2018 Civic Type R
2008 N54 335i
These are all percentage changes based on load. It's not that time consuming considering your just changing everything by what you removed. Lower Maf calibration x%, increase Fuel Trim x%, scale cranking x%, lower load x%.
Old 02-08-2018, 12:14 PM   #1738
tegxsi
Member#: 446029
That's the easy part. The thing is that every table that references load (Z-AXIS, i.e., ignition, AVCS, Fuel) becomes shifted depending on % change.
Old 02-08-2018, 12:17 PM   #1739
ericdet
Member#: 327563
2018 Civic Type R
2008 N54 335i
Default FA20 COBB Logs - Post Yours Here!
That's the easy part. The thing is that every table that references load (ignition, AVCS, Fuel) becomes shifted depending on % change.
Yes but you’re only changing the headers by the default % again. It’s still not difficult and doesn’t require anything but time.
Old 02-10-2018, 12:10 AM   #1740
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
YungBoba is offline   Reply With Quote
Old 02-10-2018, 02:59 PM   #1741
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Mods? Fuel? Mans needs to post more info.
Old 02-10-2018, 03:39 PM   #1742
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
It's in the Datazap link but I got too lazy to post here, whoops
TGV deletes
EGR deletes
Grimmspeed EBCS
Grimmspeed TMIC
Grimmspeed charge pipe
Cobb catback
Protuned by Ron Watson on ACN 91 hippy gas
Old 02-12-2018, 06:36 AM   #1743
cdog82
Member#: 415069
2016 WRX
Car: 2016 WRX
Power Mods:
-Invidia catted j pipe
-Invidia q300 catback
-Killer B Headers
-Grimmspeed Stealthbox intake
-Grimmspeed TMIC
-Grimmspeed Charge Pipe
-Grimmspeed 3 Port EBCS
-IAG EGR Delete
-AG Billet TGV Delete
-IAG Street Series AOS
-COBB Flex Fuel Kit
-DeatschWerks DW300C Fuel Pump
Tranny: 6MT
Fuel: Flex Fuel @ E57
Tune: Brentuning Flex fuel Etune
Gear: 3rd
https://datazap.me/u/cdog82/log-1518...log=0&data=5-8
cdog82 is offline   Reply With Quote
Old 02-12-2018, 09:43 AM   #1744
ericdet
Member#: 327563
2018 Civic Type R
2008 N54 335i
Originally Posted by cdog82 View Post
Car: 2016 WRX
Power Mods:
-Killer B Headers
-Grimmspeed TMIC
-IAG EGR Delete
-COBB Flex Fuel Kit
Tranny: 6MT
Gear: 3rd
Reset to Cobb default parameters. Not enough here.
Old 02-13-2018, 12:57 AM   #1745
cdog82
Member#: 415069
2016 WRX
oops sorry, here you go.
Car: 2016 WRX
Power Mods:
-Killer B Headers
-Grimmspeed TMIC
-IAG EGR Delete
-COBB Flex Fuel Kit
Tranny: 6MT
Gear: 3rd
https://datazap.me/u/cdog82/log-1518...?log=0&data=33
Old 02-13-2018, 12:39 PM   #1746
That_Boosted_Life
Member#: 422693
2016 WRX Premium
Lapis Blue Pearl
Car: 2016 WRX
Power Mods:
-Killer B Headers
-Grimmspeed TMIC
-IAG EGR Delete
-COBB Flex Fuel Kit
Tranny: 6MT
Gear: 3rd
Looks good. Is that the final revision? Just wondering why boost isn't so high in the 5k+ range as other logs
That_Boosted_Life is offline   Reply With Quote
Old 02-13-2018, 06:01 PM   #1747
cdog82
Member#: 415069
2016 WRX
Yes it's the final revision. I'll check with Bren but I got the impression that with my mods and the flex fuel etune they lean a tiny bit more towards the conservative side in order to preserve stock internals. Could be why they let boost drop a bit more than expected?
Old 02-13-2018, 06:36 PM   #1748
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
That tune is knocking, check right before 5k and 6k, FKL during WOT is not desired as the engine will pull timing out.
A little lean but it is ethanol and boost falls off hard and fluctuates at the tail end a bit, perhaps an upgraded BPV is in order?
https://datazap.me/u/cdog82/log-1518...19-20-24-33-36
Old 02-14-2018, 12:58 AM   #1749
Orochi
Member#: 448243
2015 WRX
Did a random log on the drive home tonight to see how the car is doing. Noticed a bit of overboost. Is this something to worry about?
https://datazap.me/u/orochi/2015-wrx...a=3-8-11-26-30
Orochi is offline   Reply With Quote
Old 02-14-2018, 01:51 PM   #1750
sth36
Member#: 449914
2016 WRX, Stg 2, FF
Ice Silver
Catless exhaust? Could be a little bit of boost creep there at the end, but it doesn't appear to be THAT cold out.
sth36 is offline   Reply With Quote
