02-02-2018, 04:28 PM | #1726 |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
Mishimoto cans?
I think you posted before that the hoses and fitting were garbage.
02-02-2018, 05:06 PM | #1727 |
Member#: 459692
South East
Vehicle:2019 WRX STI silica black |
Yessir, I enjoyed reengineering the hoses and fittings. A copper tubing bender and 1/2 ACR copper tubing allowed me to duplicate the Mishimoto bends. Slides right in the hose. The same tubing makes a swedged bushing for the PCV valve.
02-07-2018, 09:57 PM | #1728 |
Member#: 388015
Lean at initial boost
Hey everyone. I'm struggling to figure out where this lean spike is coming from when I reach boost. I replaced the header gaskets and j-pipe gasket thinking it could be an exhaust leak above the O2 sensor, but no improvement. I also looked over the intake and intercooler couplings. Could this be blow-by from AVCS or some other leak? My other concern is my calculated load seems higher than quite a few logs I'm seeing with similar mods.
Here is the OTS Stage2 Big SF - https://datazap.me/u/scoobman20/stag...og=0&data=8-26 Here is the same map with an OL MAF re-cal and the CL delay reduced and CL map high load changed slightly (better but the spike is still there in the beginning) - https://datazap.me/u/scoobman20/stag....91&tmax=99.60 Mod List: Catless J-pipe 3" Catback Cobb 3" intake TGV delete EGR delete Restrictor pill delete |
02-07-2018, 10:10 PM | #1729 |
Member#: 453427
Have you thought about getting a 3 port to contain your overboost? Seems to happen after it spikes then reaches target.
02-07-2018, 10:35 PM | #1730 |
Member#: 388015
Interesting observation and thanks for the suggestion, but I don't understand why exceeding the target boost would cause higher values than the commanded AFR. Maybe you know something I don't.
02-08-2018, 12:21 AM | #1731 |
Member#: 453427
No just noticed it, figured I'd mention it.
Are you running a modified COBB map for the TGV/EGR deletes? |
02-08-2018, 12:25 AM | #1732 |
Member#: 388015
02-08-2018, 07:02 AM | #1733 | |
Member#: 327563
Vehicle:2018 Civic Type R 2008 N54 335i |
If you're using the same valve timing with the factory TGV Open side I don't see AVCS causing these issues. TGV would be normally open in that region. So unless you're changing valve action it shouldn't be an issue. If you have reset to the Cobb OTS for that parameter and see if it changes. Last edited by ericdet; 02-08-2018 at 07:08 AM. |
02-08-2018, 09:40 AM | #1734 | |
Member#: 446029
The calculated load on some logs you see on here have the MAF along with a few other things scaled to avoid hitting the 3.30 load limit on the ECU. You will usually see it on Phatbotti/Ron Watson tunes. When I tune for WOT open loop I zero the delay counter. I don't want any of that Evo like lean spool shenanigans lol. If I were to tune for WOT full time closed loop then it would be the opposite along with a bunch of changes with the CL fueling and other delays. |
02-08-2018, 10:11 AM | #1735 | |
Member#: 388015
02-08-2018, 10:53 AM | #1736 | |
Member#: 446029
Look for "Boost/Load Hard-coded limits" in Cobb's DIT Accesstuner tuning guide. It's not as easy as it seems since all load related tables need manipulating. You really need to know what you are doing...especially with ignition timing. |
02-08-2018, 11:43 AM | #1737 | |
Member#: 327563
02-08-2018, 12:14 PM | #1738 |
Member#: 446029
That's the easy part. The thing is that every table that references load (Z-AXIS, i.e., ignition, AVCS, Fuel) becomes shifted depending on % change.
02-08-2018, 12:17 PM | #1739 |
Member#: 327563
FA20 COBB Logs - Post Yours Here!
02-10-2018, 12:10 AM | #1740 |
Member#: 450808
SCIC
Vehicle:2017 WRX Premium WR Blue Pearl |
Couple 3rd gear WOT logs.
https://datazap.me/u/yungboba/stage-...0&data=9-24-28 https://datazap.me/u/yungboba/stage-...0&data=9-25-29 |
02-10-2018, 02:59 PM | #1741 |
Member#: 453427
Mods? Fuel? Mans needs to post more info.
02-10-2018, 03:39 PM | #1742 |
Member#: 450808
SCIC
02-12-2018, 06:36 AM | #1743 |
Member#: 415069
Vehicle:2016 WRX Black |
Car: 2016 WRX
Power Mods: -Invidia catted j pipe -Invidia q300 catback -Killer B Headers -Grimmspeed Stealthbox intake -Grimmspeed TMIC -Grimmspeed Charge Pipe -Grimmspeed 3 Port EBCS -IAG EGR Delete -AG Billet TGV Delete -IAG Street Series AOS -COBB Flex Fuel Kit -DeatschWerks DW300C Fuel Pump Tranny: 6MT Fuel: Flex Fuel @ E57 Tune: Brentuning Flex fuel Etune Gear: 3rd https://datazap.me/u/cdog82/log-1518...log=0&data=5-8 |
02-12-2018, 09:43 AM | #1744 | |
Member#: 327563
02-13-2018, 12:57 AM | #1745 |
Member#: 415069
oops sorry, here you go.
Car: 2016 WRX Power Mods: -Invidia catted j pipe -Invidia q300 catback -Killer B Headers -Grimmspeed Stealthbox intake -Grimmspeed TMIC -Grimmspeed Charge Pipe -Grimmspeed 3 Port EBCS -IAG EGR Delete -AG Billet TGV Delete -IAG Street Series AOS -COBB Flex Fuel Kit -DeatschWerks DW300C Fuel Pump Tranny: 6MT Fuel: Flex Fuel @ E57 Tune: Brentuning Flex fuel Etune Gear: 3rd https://datazap.me/u/cdog82/log-1518...?log=0&data=33 |
02-13-2018, 12:39 PM | #1746 | |
Member#: 422693
Vehicle:2016 WRX Premium Lapis Blue Pearl |
02-13-2018, 06:01 PM | #1747 |
Member#: 415069
Yes it's the final revision. I'll check with Bren but I got the impression that with my mods and the flex fuel etune they lean a tiny bit more towards the conservative side in order to preserve stock internals. Could be why they let boost drop a bit more than expected?
02-13-2018, 06:36 PM | #1748 |
Member#: 453427
That tune is knocking, check right before 5k and 6k, FKL during WOT is not desired as the engine will pull timing out.
A little lean but it is ethanol and boost falls off hard and fluctuates at the tail end a bit, perhaps an upgraded BPV is in order? https://datazap.me/u/cdog82/log-1518...19-20-24-33-36 |
02-14-2018, 12:58 AM | #1749 |
Member#: 448243
TXIC
Vehicle:2015 WRX DGM |
Did a random log on the drive home tonight to see how the car is doing. Noticed a bit of overboost. Is this something to worry about?
https://datazap.me/u/orochi/2015-wrx...a=3-8-11-26-30 |
02-14-2018, 01:51 PM | #1750 |
Member#: 449914
RMIC
Vehicle:2016 WRX, Stg 2, FF Ice Silver |
Catless exhaust? Could be a little bit of boost creep there at the end, but it doesn't appear to be THAT cold out.
