11-05-2017, 12:11 AM | #1476 |
Member#: 472308
Vehicle:2015 WRX Red |
My subie has been bulletproof to date, but my old 330i met a similar fate
11-05-2017, 07:38 AM | #1477 |
Member#: 419593
That pic is going to give me nightmares .
11-05-2017, 11:26 AM | #1478 |
Member#: 459692
South East
Vehicle:2019 WRX STI silica black |
https://datazap.me/u/undyjr/checking...ta=11-12-17-20 Here's a log after a ride along with my tuner. Is it still conservative? Overly so?
11-05-2017, 01:35 PM | #1479 | |
Member#: 386600
Vehicle:2015 WRX |
It could be that the tuner advanced the timing where it is running rich, and retarded it where it's running lean, leading to a conservative tune, but this is a pretty sloppy way to tune, and won't result in the best power output. All tunes should start with a well-calibrated MAF. In any case, no knock is a good sign. I haven't been following your posts. What are your mods? Do you have an aftermarket intake that could be making MAF calibration tricky? 24psi of boost to redline is kind of surprising. You have a non-stock turbo or just a really good intercooler? |
11-05-2017, 06:15 PM | #1480 | |
Member#: 459692
South East
11-06-2017, 10:49 AM | #1481 |
Member#: 327563
Vehicle:2018 Civic Type R 2008 N54 335i |
There is a pretty large spread from calculated to Actual AFR, which certainly points to MAF scaling. Since you're spraying Meth it kind of compounds the issue. I'm not that proficient on Meth injection but I would assume the relation from Target to Actual would be the opposite of what you're seeing unless the tuner is actually using large doses to actually supplement the fueling system. Just seems like a lot that can go wrong if the meth stops flowing. What fail safes are you employing?
11-06-2017, 11:12 AM | #1482 |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
I'd swap to an ETS or PRL intake if you have to run an intake, I would also expect richer AFR in relation to commanded due to the meth.
Look into the blown engine thread, there are a lot of reports of engine grenading with the COBB Big SF intake. |
11-06-2017, 12:19 PM | #1483 |
Member#: 15339
Vehicle:2015 CWP WRX Flex Fuel tune by Phatron |
Crawford AOS installed... on a third gear pull 91 oct. everything ok? AF1 ok? AFR ok?
thanks! https://datazap.me/u/gsechen/aos-logs?log=1&data=9-24 |
11-06-2017, 12:56 PM | #1484 | |
Member#: 459692
South East
11-06-2017, 02:24 PM | #1485 |
Member#: 432126
Vehicle:2015 WRX Galaxy Blue |
Hey guys please take a look at my datalog. Running a COBB OTS Stage 2 tune.
- COBB catted/resonated j-pipe - Invidia Q300 catback - Perrin charge pipe - Grimmspeed TMIC - IAG AOS Datalog: https://datazap.me/u/violentleaf/3rd...ata=3-15-17-19 Thanks! |
11-06-2017, 03:47 PM | #1486 | |
Member#: 327563
11-06-2017, 03:51 PM | #1487 | |
Member#: 327563
PS. I wouldn't rev it out 7K. |
11-06-2017, 05:24 PM | #1488 | |
Member#: 432126
Is there a specific reason with these cars I shouldn't take it to 7k or are you just giving a general recommendation? Thanks for the feedback. |
11-06-2017, 05:30 PM | #1489 |
Member#: 327563
11-06-2017, 06:15 PM | #1490 |
Member#: 181243
Vehicle:03 Impreza |
For anyone interested here is a Phatbottie Stage2 vs a Bren Stage 2
Phatbotti Stage 2 E tune https://datazap.me/u/vikingsaahockey...data=3-9-12-24 Brentune Stage 2 E Tune https://datazap.me/u/vikingsaahockey...&data=3-7-9-18 Car runs night and day better with the Phatbottie tune. |
11-06-2017, 06:28 PM | #1491 | |
Member#: 419593
11-06-2017, 07:51 PM | #1492 | |
Member#: 181243
I was getting a lot of cruise knock on the Bren tune . It's all virtually gone now with the phatbotti tune . |
11-07-2017, 09:22 AM | #1493 |
Member#: 432126
Ok that makes sense.
Here's the new log with default parameters plus commanded fuel. https://datazap.me/u/violentleaf/3rd...ta=5-7-8-16-20 |
11-07-2017, 12:21 PM | #1494 |
Member#: 327563
I definitely don't see "a lot" of power difference. Pulls are not harmonious in RPM either. One is short. The other is shorter. Tighter AFR and better boost control as well as the absence of knock on the Phatbotti tune.
11-07-2017, 12:26 PM | #1495 | |
Member#: 327563
11-07-2017, 01:08 PM | #1496 | |
Member#: 419593
I am planning on getting a Phatobotti tune myself once I install few additional parts so again, I am just trying to learn as much as I can when looking at these logs. |
11-07-2017, 01:14 PM | #1497 | |
Member#: 459692
South East
11-07-2017, 01:31 PM | #1498 | |
Member#: 446029
11-07-2017, 01:36 PM | #1499 | |
Member#: 327563
FA20 COBB Logs - Post Yours Here!
Only one log even has MAF g/s. One has more PSI of boost pressure average but considering you have no idea of the conditions it doesn't tell you much. One is probably making more power than the other but the other is doing it much more reliably. My car will fluctuate from 275-245 g/s depending on the weather. There are a few tuning aspects that involve g/s and calculated load that can alter the outcome. Only the tuner would know these things though. Undy for all we know your logged MAF g/s could be lower than the actual. Last edited by ericdet; 11-07-2017 at 01:57 PM. |
11-07-2017, 01:37 PM | #1500 |
Member#: 327563
