Welcome to the North American Subaru Impreza Owners Club Friday January 18, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 01-06-2018, 06:24 PM   #1701
ericdet
Member#: 327563
2018 Civic Type R
CW
Originally Posted by Orochi View Post
Finally got the PW Verticooler installed. Got a retune from Ron and this is the final map. Feels pretty good.
https://datazap.me/u/orochi/phatron-...a=3-8-11-26-30
Looks solid to me. Always good work from Ron.
ericdet is offline   Reply With Quote
Old 01-22-2018, 06:01 PM   #1702
Chuckable
Member#: 447566
2017 WRX
https://datazap.me/u/chuckable/log-1516658251
Doing an updated tune with some change in parts and a new tuner who seems awesome so far. Still early in the process. Any feedback?
Chuckable is offline   Reply With Quote
Old 01-22-2018, 06:06 PM   #1703
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
It looks pretty good so far, whos tuning it?
gn4rwhals is offline   Reply With Quote
Old 01-22-2018, 06:13 PM   #1704
Chuckable
Member#: 447566
2017 WRX
Ron Watson
Old 01-22-2018, 06:16 PM   #1705
Chuckable
Member#: 447566
2017 WRX
Oops you looked at the log I mistakenly posted before editing. Please look at the corrected post. Thanks!
Old 01-22-2018, 07:30 PM   #1706
mishapopa
Member#: 393629
2015 WRX
Ron Watson
you're in good hands
mishapopa is offline   Reply With Quote
Old 01-22-2018, 09:25 PM   #1707
Chuckable
Member#: 447566
2017 WRX
Thatís what everyone says. Appreciate the feedback.
Old 01-23-2018, 07:40 AM   #1708
ericdet
Member#: 327563
2018 Civic Type R
CW
Looks pretty good to me.
Old 01-26-2018, 04:37 PM   #1709
Aherna00
Member#: 478711
2017 WRX
WRB. E85.
Originally Posted by wrxlaunch View Post
Doesn't this seem a bit lean?
Aherna00 is offline   Reply With Quote
Old 01-26-2018, 04:48 PM   #1710
GlarryHoodDIT
Member#: 460907
2016 WRX
Not with the amount of Ethanol. But that fueling line could use a little cleaning up. It's Botti so there's little to worry about.
GlarryHoodDIT is offline   Reply With Quote
Old 01-26-2018, 04:51 PM   #1711
Aherna00
Member#: 478711
2017 WRX
WRB. E85.
Gotcha. So with e50+ blends you can run the AFR to the 12.5-13.0 range? why is that? Just the amount of knock resistance the ethanol offers?
Old 01-26-2018, 05:07 PM   #1712
GlarryHoodDIT
Member#: 460907
2016 WRX
12.5 is usually the leanest that will be targeted, the tune is still being revised so I bet that fueling line will be more consistent when it's done. Impossible to know what's being targeted without him logging Closed Loop Fueling Target. But his tuner knows what the target is so that's why it's not logged.
Ethanol has such a higher octane than pump gas, in addition to cooling properties that keep cylinder temperatures and pressure down. E85 is like 105 Octane, E60 is about 100 Octane and E50 is about 98 Octane.
I know Phatron (1/2 of PhatBotti) caps all of his tunes power-wise at E50, but I don't know about Botti. Either way he's looking at about 98-99 Octane.
Higher octane = more knock resistance, + ethanol's cooling it's even better.
Old 01-26-2018, 05:10 PM   #1713
Aherna00
Member#: 478711
2017 WRX
WRB. E85.
Thanks for the great info
Old 01-26-2018, 05:34 PM   #1714
ericdet
Member#: 327563
2018 Civic Type R
CW
Like Glary said above, 12.5 is usually the leanest you will see targeted. 12-12.2 on E50+ is normal. This log doesn't have crazy amounts of timing up top so he probably has a little leeway. My car would run 12.0-12.1 with 2-9 degrees more timing throughout the pull on E60.
Also keep in mind 12.0 Ethanol is a lot more fuel than 12.0 Gas stoich.
Old 01-29-2018, 04:58 PM   #1715
_brian_
Member#: 337626
2015 WRX
Crystal White Pearl
Originally Posted by _brian_ View Post
a few weeks ago my charge pipe popped off on track. ever since then i've been getting more -1.41 FKL/FBK than before at WOT. today i went through all the clamps and tightened/adjusted the intercooler. still seeing knock :/
https://datazap.me/u/brian/street-dr...&data=11-15-22
I've also had some weird -8 to -11 FBK numbers that I haven't seen before show up when driving around. No logs of those though.
update on this. i was getting -1.41 every time I went WOT and all around town. my strut top nuts were loose and one of the clips on my intake scoop broke earlier in the year and I never fixed it so I replaced that. so one or both of those two things fixed my phantom knock... now i'm knock free again.
_brian_ is offline   Reply With Quote
Old 01-29-2018, 08:24 PM   #1716
undyjr
Member#: 459692
2015 WRX
pure red
Congratulations. I too know the anxiety of WOT knock. I finally found someone to figure out my weird MAF scaling.
undyjr is online now   Reply With Quote
Old 01-29-2018, 08:46 PM   #1717
undyjr
Member#: 459692
2015 WRX
pure red
Old 02-02-2018, 11:51 AM   #1718
undyjr
Member#: 459692
2015 WRX
pure red
Paging Mr Eric, you have a datalog at the front desk....
Old 02-02-2018, 12:07 PM   #1719
sth36
Member#: 449914
2016 WRX, Stg 2, FF
Ice Silver
Originally Posted by undyjr View Post
What are your mods?
sth36 is offline   Reply With Quote
Old 02-02-2018, 12:16 PM   #1720
undyjr
Member#: 459692
2015 WRX
pure red
Originally Posted by sth36 View Post
What are your mods?
Built shortblock, Killer Bee fury turbo kit with a GTX3071R gen 2, Perrin header, Cobb big sf intake, both deletes and Snow Performance water meth port injection.
Old 02-02-2018, 12:26 PM   #1721
sth36
Member#: 449914
2016 WRX, Stg 2, FF
Ice Silver
Quite a unique setup. Hopefully Eric can hook you up with an analysis. I have about zero experience with meth
Old 02-02-2018, 12:48 PM   #1722
undyjr
Member#: 459692
2015 WRX
pure red
Thanks for looking
Old 02-02-2018, 03:40 PM   #1723
ericdet
Member#: 327563
2018 Civic Type R
CW
Well it looks like you finally went to FTCL. Lol. Holding 20psi @37 degrees is moving some serious air. Obviously the MAF is scalled down to compensate. This is the first really clean run I've seen from your car.
Looks good to me. I bet it rails. Wait until the weather warms up and see what that boost hits. Lol.
WGDC......... 0% What spring do you have in the gates? 1.5 Bar?
Old 02-02-2018, 03:56 PM   #1724
undyjr
Member#: 459692
2015 WRX
pure red
To my knowledge They have 14# springs in them. My break in tune limited me to 14#s. This is the first revision with the meth, then we go flex fuel and finally MS109. Turns out my catch cans and the sketchy hoses/fittings were the source of most of my MAF scaling woes.
Old 02-02-2018, 05:28 PM   #1725
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Mishimoto cans?
I think you posted before that the hoses and fitting were garbage.
