Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 02-14-2018, 01:53 PM   #1751
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
That log shows no overboosting and no boost creep. .5PSI over target is well within acceptable parameters- especially if it's that incredibly brief.
In the future you don't need to wind it out to 6700- the car is dead on power about 700rpm before that.
GlarryHoodDIT is offline   Reply With Quote
Old 02-14-2018, 02:13 PM   #1752
undyjr
Member#: 459692
2019 WRX STI
silica black
No need to go past 6k? Is that for this particular tune or FA20s in general?
undyjr is offline   Reply With Quote
Old 02-14-2018, 02:15 PM   #1753
calvdaboss
Member#: 454701
If your car is dead on power at 6000 you need a new tuner
calvdaboss is offline   Reply With Quote
Old 02-14-2018, 03:04 PM   #1754
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
Just in general on FAs running pump gas. With ethanol/WM/Race Gas you can hold power to 6500-7000 much easier, but 91/93 the car just doesn't sustain top end power on the stock turbo.
Old 02-20-2018, 11:48 AM   #1755
BubbaRacing
Member#: 473595
-2017 WRX USDm
- Stock with Stage 1 93 OTS
- 6MT
- 93
- Stage 1 Cobb OTS
- Mostly 3rd one of them was 4th
https://datazap.me/u/bubbaracing/log...?log=1&data=12
https://datazap.me/u/bubbaracing/log...?log=0&data=12
https://datazap.me/u/bubbaracing/log...?log=2&data=12
Let me know if you see anything out of ordinary. Sometimes I get what feels like timing being pulled but I don't think it occurred on any of these logs. I'm use to tuning ls cars with hp tuners but am new to the AP and wrx tuning.
I just received TGV deletes but haven't installed yet. Are there nay OTS maps for the delete or only custom tuning. Thanks!
BubbaRacing is offline   Reply With Quote
Old 02-20-2018, 12:45 PM   #1756
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Looks pretty standard for OTS, no knock in the WOT areas just some small FKL during cruise in one of the logs (unavoidable on OTS, normal).
We need need AFR logged as well as commanded to get a better picture but I have a feeling its probably swinging richer than commanded.
If you want to run the TGV deletes get the EGR delete kit and do both at the same time. You will need a custom map to run TGV deletes, also a 3 port boost control solenoid (Grimmspeed) is recommended by most tuners.
gn4rwhals is offline   Reply With Quote
Old 02-20-2018, 01:16 PM   #1757
BubbaRacing
Member#: 473595
Thanks!Yes I ordered the whole kit TGV/EGR and also ordered the delicious flex fuel kit with a tune. I'm just going to install it all at once. I'll look at the 3 port also.
Are you saying AFR on wideband? Or another AFR setting? I logged commanded fuel map and final, is there something else?
Thanks guys!
Old 02-20-2018, 03:48 PM   #1758
ericdet
Member#: 327563
2018 Civic Type R
2008 N54 335i
Thanks guys!
There's no AFR in your logs. Reset settings to Cobb default and add Command fueling. 3rd gear pulls are preferred. 3-6500.
ericdet is offline   Reply With Quote
Old 02-20-2018, 04:43 PM   #1759
undyjr
Member#: 459692
2019 WRX STI
silica black
Is anyone in the process of getting an e tune from Mikey Botti?
Old 02-20-2018, 06:00 PM   #1760
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Thanks guys!
Skip Delicious Tuning and go with COBB flex fuel support, unless something has changed Delicious has no AP integration.
Old 02-20-2018, 06:07 PM   #1761
alapilusa
Member#: 424692
2015 WRX
I think it has AP integration, but only a few select "approved" tuners have access as well as e-tune option from Delicious.
But agreed, skip delicious and get the Cobb setup. Way better.
alapilusa is offline   Reply With Quote
Old 02-20-2018, 06:09 PM   #1762
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
I just recall them not tuning very well on flex and I also recall a MAF cable on an older unit that caused issues.
Old 02-20-2018, 06:14 PM   #1763
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
Delicious Tuning's MK2 can be used with Cobbs AP that any ProTuners can tune. Says that in the first sentence. DT's FF kit also has more features and BT integration for your phone. DT are also highly reputable tuners throughout the industry.
https://www.delicioustuning.com/flexfuelcobb
Old 02-20-2018, 08:28 PM   #1764
BubbaRacing
Member#: 473595
Yeah I didn't see any drawbacks to this kit over the cobb. Also has fuel pressure protection in the evetn pump has a hiccup like they have known to do on come e85 setups. I don't plan to ever go full 85, probably 50-60 at the most ethanol content
Old 02-20-2018, 10:09 PM   #1765
RussianTiny
Member#: 387467
2018 WRX Limited
WRB Stage 2 FlexFuel
Oo I like the Bluetooth E content feature. I don’t run with my AP hooked up and that would be nice to do a spot check before refueling with an E blend. Would most flex Fuel tuners be able to use the DT kit if they can use the Cobb?
I don’t think I’m switching FF kits but I’d like to know the options
RussianTiny is offline   Reply With Quote
Old 02-20-2018, 10:46 PM   #1766
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
Originally Posted by DeliciousTuning
Delicious Tuning - 15+ WRX DIT Mk2 Flex Fuel kit is a complete seamless solution for your Cobb Accessport V3, that any Cobb Protuner can tune. It features all the same functionality as Cobb's standard DIT flex fuel kit, but with added fuel pressure and safety features.
It's just a sensor to monitor E content. Provided it works, it should be no different than Cobb's sensor, just with more options for monitoring.
Old 02-22-2018, 01:13 AM   #1767
ayau
Member#: 332408
Here's mine my final tune. Tuned by Ron at PhatBotti.
https://datazap.me/u/ayau/log-151927...og=0&data=9-24
2015 WRX
EGR, TGV, GS EBCS
6MT
93
Custom e-tune
3rd gear
Overall, I'm very satisfied with the tune. Power delivery is way more linear compared to stock tune. Can definitely feel the extra power.
ayau is offline   Reply With Quote
Old 02-22-2018, 04:51 PM   #1768
Straight6
Member#: 419593
2015 WRX
EGR, TGV, GS EBCS
6MT
93
Custom e-tune
3rd gear
I wish my boost control looked like that.
Straight6 is offline   Reply With Quote
Old 02-22-2018, 07:16 PM   #1769
ayau
Member#: 332408
For someone that isn't experienced in looking at logs, what are some key things to look for when reading a log? What makes a good or bad log?
Old 02-22-2018, 08:56 PM   #1770
Wrex85S
Member#: 478447
2018 WRX
WR Blue
would love to see a COBB vs MAP tune comparison as well. I have a 2018 that I want to stage 1 but unsure of the reliability of the more "aggressive" MAP tune.
Wrex85S is offline   Reply With Quote
Old 02-22-2018, 08:59 PM   #1771
GlarryHoodDIT
Member#: 460907
2020 Golf GTI
There's dozens of Map logs and dozens of Cobb logs. Just look through the 71 pages.
Old 02-22-2018, 10:01 PM   #1772
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Both maps 93 octane, stock car.
MAP 91 STG1: https://datazap.me/u/gn4rwhals/maper...12-13-15-21-24
COBB 93 STG1 HWG: https://datazap.me/u/gn4rwhals/cobb-...24&zoom=89-525
Between these 2 the COBB 93 HWG tune is more aggressive but runs pig rich.
Old 02-23-2018, 08:17 AM   #1773
Straight6
Member#: 419593
There are many logs here and I have done plenty myself. I prefer the MAP tune but the HWG COBB v300 maps are just as strong. MAP is smoother for sure but I was getting too much cruise knock driving around with both. E tune eliminated that issue and it picked up a lot more power in the midrange. I would honestly be very happy with the MAP tune power wise if it wasn't for the random knock issues. I like this tune a lot.
Old 02-23-2018, 10:38 AM   #1774
mishapopa
Member#: 393629
i was constantly getting knock with the MAP stage 2 tune and DAM would drop as low as 0.75. couldn't go on the highway for longer than an hour without DAM dropping. good power though. would only use their tune as temporary solution honestly.
mishapopa is offline   Reply With Quote
Old 02-23-2018, 02:53 PM   #1775
Veritas1286
Member#: 410759
2015 WRX
Dark Gray
Modlist :
invidia catless J - > stock catback
Grimmspeed Intake
Grimmspeed EBCS
Grimmspeed TMIC
P&L Chargepipe
PRL TGV Delete
PRL EGR Delete
Grimmspeed Lightweight Crank Pulley
https://datazap.me/u/cbussard/log-10...23-26-29-30-31
Absolutely happy with it so far. It pulls hard
Veritas1286 is offline   Reply With Quote
