Welcome to the North American Subaru Impreza Owners Club Sunday November 18, 2018
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 03-04-2018, 01:47 AM   #1801
GlarryHoodDIT
Member#: 460907
2016 WRX
It's cruise knock, not really something to worry about. The knock sensors are crazy sensitive compared with the EJs and thus record a lot more cruise knock. Unfortunately, cruise knock alone will often drop your DAM on OTS maps and the stock tune.
We need a 3rd gear, 3000-6500 WOT pull. Take a log of just that and post it here and we can evaluate from there.
GlarryHoodDIT is offline   Reply With Quote
Old 03-04-2018, 01:52 AM   #1802
rzmwrx
Member#: 481396
2016 WRX
Even though this just started, nothing to worry about? If you mean "cruise knock" as in cruise control, I wasn't using CC. Regardless, I just find it odd that this is new. I would think I would have seen it from day one of adding the AP.
I'll try to log some WOT pulls tomorrow and see what happens.
rzmwrx is offline   Reply With Quote
Old 03-04-2018, 01:59 AM   #1803
GlarryHoodDIT
Member#: 460907
2016 WRX
No, I'm not referring to cruise control.
Read these, they are invaluable. It's likely false knock.
https://www.cobbtuning.com/subaru-kn...logic-changes/
https://innovativetuning.com/subaru-...knock-control/
https://cobbtuning.zendesk.com/hc/en...ck-Corrections
"It shouldn’t be surprising to see a drop in DAM on the DIT vehicles (as it is on early cars where DAM being less than ideal is an indicator there is an issue) especially running lower octane fuels. How long the DAM takes to return to 1 is not indicative of how serious the knock event was and does not mean the car is still knocking. In order to advance the DAM on DIT vehicles, you have to drive in specific load/RPM ranges without knock."
As to why it just started happening probably a coincidence. It's more surprising it wasn't doing it from the beginning.
Old 03-04-2018, 02:13 AM   #1804
rzmwrx
Member#: 481396
2016 WRX
I had read the first link before. I was hoping I was being paranoid and "catching what I don't want to catch" like the article says.
Third link appears to have been taken down. But hadn't seen the 2nd one. So thanks!
Old 03-04-2018, 02:22 AM   #1805
GlarryHoodDIT
Member#: 460907
2016 WRX
Nothing in your logs looked to horrible, nothing past 2* timing. Was your AC or defrost on? Those are notorious for producing false knock.
Just google Cobb Knock Control and read the first 5-6 articles.
We've seen logs in here with DAM at .062 and the car was still pulling 3-4-5-6* of timing, yours is considerably more mild than that.
Old 03-04-2018, 02:32 AM   #1806
rzmwrx
Member#: 481396
2016 WRX
No AC or defrost. I realized the AC causing false reading a few days after I installed the accessport. Kept getting feedback knock as soon as I turned on the heater.
Just got worried cause I hadn't seen any DAM at all up until two days ago. Now I've seen it twice, and one did not correct itself and a bunch if FKL, which started after first DAM correction, which was very rare up until this point. Now it's happening 'a lot.' But then again i know nothing about tuning so like you said its probably no big deal.Maybes weather related or crappy gas? I'll keep an eye on it and keep logging and try to find a gas station with 93 near me.
Old 03-04-2018, 03:16 AM   #1807
GlarryHoodDIT
Member#: 460907
2016 WRX
I'm not sure what you mean by "I hadn't seen any DAM at all up until two days ago". I'm assuming you mean DAM dropping? It should be a 1.0. .812 isn't too bad. When I was running OTS maps I was constantly having DAM drops and seeing crazy FKL and FBK on my monitors even with my DAM at .750 or even .500. I was thinking the worst obviously, but in the end I just don't think the OTS maps played that well with my car. As soon as I got E Tuned my problems went away. Not to say my car never knocks, I'll see knock during cruise if my AC or defrost is on and maybe 1/50 WOT I'll see a 1.4, but it's much more manageable now.
If you can find 93 try that, if you have access to E85 try running 1-2 gallons MAX PER TANK and see if that helps at all. 1-2 gallons of E85 should effectively raise your octane to 92-93, but if you put more than 1-2 gallons your car might have issues with matching fueling targets.
Old 03-04-2018, 10:20 AM   #1808
_Makaveli
Member#: 448404
2016 WRX
CWP
Can you check out my datalog
https://datazap.me/u/makaveli/cobb-s...14-16-19-20-22
This is the best I could get, 3rd gear WOT.
I just wanna make sure my car is running good
_Makaveli is offline   Reply With Quote
Old 03-04-2018, 10:44 AM   #1809
rzmwrx
Member#: 481396
2016 WRX
I mean it had never been anything but 1.0 for a month since I installed the accessport. Now I'm seeing fluctuations and the only change has been weather.
Old 03-04-2018, 12:18 PM   #1810
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
You are underboosting through most of the pull, try the HWG map if they have one for the ETS intake, or look into getting a tune for your mods.
Some small -1.41 FKL in the 5k range, keep an eye on it but nothing to freak out about. AFR is right in line with commanded, so that is good.
Also start your pulls at 3k, starting at 2k is lugging the engine a bit.
gn4rwhals is offline   Reply With Quote
Old 03-04-2018, 01:10 PM   #1811
_Makaveli
Member#: 448404
2016 WRX
CWP
Ok thanks I'll try out the HWG map, I'm gonna run OTS for like 2-3 more months then look at getting an E-tune hopefully that will fix everything
Old 03-04-2018, 01:55 PM   #1812
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
91 octane and OTS map is your culprit. These cars are extremely sensitive to fuel quality and even on an OTS map designed for 91 octane, you're still gonna have knock and DAM drops. Best thing to do is to get an etune or a protune.
YungBoba is offline   Reply With Quote
Old 03-04-2018, 08:57 PM   #1813
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
https://datazap.me/u/simplej/bren-lo...5&zoom=446-845
FBO minus headers and TGVd, tuned by Bren.
simpleJ is offline   Reply With Quote
Old 03-05-2018, 12:24 AM   #1814
YungBoba
Member#: 450808
2017 WRX Premium
WR Blue Pearl
Took a log this morning.
"Stage 1.5" WRX
-TGV deletes
-EGR deletes
-Grimmspeed EBCS
-Grimmspeed charge pipe
-Grimmspeed TMIC
-Cobb catback
-Dyno tune - Ron Watson/Phatbotti on 91 Octane
https://datazap.me/u/yungboba/stage-...a=3-9-12-23-25
Old 03-05-2018, 02:13 PM   #1815
ayau
Member#: 332408
How can a good protune have no knock (not yet anyway) than stock tune, yet make more power? What exactly are tuners adjusting to reduce the chance of knock?
ayau is offline   Reply With Quote
Old 03-05-2018, 02:17 PM   #1816
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
LOL the knock sensors
Old 03-05-2018, 02:24 PM   #1817
ayau
Member#: 332408
Lol hopefully a reputable tuner wouldn't do that. How do you know if the sensors are turned off without asking your tuner? Are the knock sensors on or off, or can the sensitivity be lowered?
Old 03-05-2018, 03:31 PM   #1818
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
You’d think that wouldn’t you...
They all modify it- they have to to some degree to make the car run correctly as the FA’s knock controlnstrategy is kind of whacked from the factory in that it picks up all kinds of noise, some shut it off so they don’t get calls and emails from kids who don’t understand knock
Multiple ways to skin a cat here:
Unplug knock sensor and turn off cel
Global reduction in sensitivity, or off
Alter the “listening” ranges
Etc
Yes you can tell if you know how to read the knock sensing in logs.
You should be seeing at least -1.41’s on a pretty regular basis and some FKLs under load. Probably not more -4.22ish cruising under load up hill and -2.81 at wot. If you see above that your wick is probably turned up too high, and if you’re not seeing at least those values every now and then you probably have your sensors turned off. That’s why a little knock every now and then is actually a good sign: it means your tuner is responsible.
“My toon never knocks, bro” is bs, it does, all the time, your ap just isn’t recording it because your ecu can’t hear it.
Old 03-05-2018, 04:12 PM   #1819
GlarryHoodDIT
Member#: 460907
2016 WRX
Phatron tuned with EGRD/TGVD- I see 1.4 blip a few times if I have the Ac/Defrost on- never see it at WOT since I've gone flex. I used to see it every 1/10 WOT runs on 91, but since using Ethanol I've never seen it at WOT- except during logging. I'm confident in Ron and his tuning strategies, he's one of the few Id let touch my cars ECU.
Old 03-05-2018, 04:42 PM   #1820
ayau
Member#: 332408
I'm also Phatron tuned with EGR, TGV, ECBS on 93.
I only recall seeing one instance of -1.41 at around 6.3k RPM during a 3rd gear WOT revision.
I haven't seen a single knock since then. I also don't have my AC/defrost turned on. I'll enable them and see if the ECU picks up any false knocks.
Maybe 93 actually makes a difference? Who knows. But I'd expect the ECU to pick up some false knocks unless the knock sensors have been aggressively desensitized.
Old 03-05-2018, 08:21 PM   #1821
ayau
Member#: 332408
I just drove around with the AC on and saw -1.41 feedback knock. I guess knock sensor is still on. Just don’t know if they were desensitized.
Old 03-06-2018, 03:36 AM   #1822
comp3wrx
Member#: 473898
2018 WRX
2018 WRX Premium w/ Performance Package
- Transmission: 6MT
- Fuel: 91 Octane (California)
- Mods: ETS intake w/ airbox
- Map: BrenTuning E-Tune Stage1+ETS Rev6
- Datalog: 3rd Gear Pull
https://datazap.me/u/comp3wrx/2018-0...og=0&data=7-28
How does this look?
Before installing the ETS intake, I tried out the Cobb Stg1 91oct OTS and MAPerformance Stg1 91oct v6 beta tunes. Both tunes eventually had the DAM drop to 0.8xx and could never get above 0.875 even after multiple tanks of gas from different gas stations. The current BrenTuning map feels a bit slower than the MAPerformance map, but the DAM hasn't dropped from 1.0 for over 2 months. We'll see how it does in hot weather this summer. That's when the DAM drops occurred with the Cobb and MAPerformance maps.
comp3wrx is offline   Reply With Quote
Old 03-06-2018, 07:35 AM   #1823
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Probably, just not in that range, and probably not in a detrimental way.
You should see 1.41 or even 2.81 almost everytime you drive the car
Old 03-06-2018, 07:37 AM   #1824
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
- Transmission: 6MT
How does this look?
Lookin’ pretty good to me
I can tell you still have the factory boost restrictor in though lol
Old 03-06-2018, 11:49 AM   #1825
tegxsi
Member#: 446029
- Transmission: 6MT
How does this look?
It should be slow... I don't see much WOT ignition advance. Maybe the next rev?
tegxsi is offline   Reply With Quote
