03-23-2018, 04:36 PM | #1976 |
Member#: 419593
03-23-2018, 07:51 PM | #1977 |
Member#: 459692
South East
Vehicle:2019 WRX STI silica black |
https://datazap.me/u/undyjr/intersta...&data=16-17-21
This is a log of my typical 4th gear interstate pull. Been noticing a "step" during the pull. I'm starting to think it's my water meth pump starting full spray which is set at 15#s. What do you guys think? |
03-23-2018, 10:36 PM | #1978 |
Member#: 481336
Vehicle:2016 WRX Limited Silver |
Hi!
I've waited so many years for my dream car and I finally got it. I read through 75 pages of this thread before I finally pulled the trigger and order my AP from MAP and I have a log. I'm pretty sure it looks great but always willing to have another set of eyes. Huge shoutout to this thread for the wealth of knowledge and MAP for the excellent customer service. This tune really brought the car alive, and thank god for the throttle re-map. so much more driveable. - 2016 WRX limited - Bone stock - 6MT - 93 - MAP 91 Stg 1 - Gear 3 https://datazap.me/u/budekai/map-91-....03&tmax=10.99 Edit: And for fun, plugged the runs into VD. Only the last pull (R03) was on a completely flat piece of road. Last edited by budekai; 03-23-2018 at 11:17 PM. Reason: adding information |
03-24-2018, 07:44 AM | #1979 |
Member#: 419593
Ok, how about this one :
https://datazap.me/u/e90/map-v7?log=...-3-10-13-20-27 No bueno ? Too lean ? |
03-25-2018, 01:06 PM | #1980 |
Member#: 481336
Decided to move up to the 93 MAP tune. Here are 3 pulls. R04 is on a flat, smooth road. the others were mixed. Let me know if you see anything to worry about.
- 2016 WRX limited - Bone stock - 6MT - 93 - MAP 93 Stg 1 - Gear 3 https://datazap.me/u/budekai/map-93-...&data=3-5-7-21 |
03-25-2018, 03:26 PM | #1981 |
Member#: 460907
RMIC
Vehicle:2020 Golf GTI |
^^Looks good, fueling and everything looks clean.
Now that the daily temps are starting to rise aftermarket ICs are really going to start to shine. |
03-25-2018, 03:29 PM | #1982 |
Member#: 332408
Will be installing GS IC, Jpipe, and flex fuel soon. Stay tuned for more Phatbotti tuned logs...
03-25-2018, 04:24 PM | #1983 |
Member#: 419593
Wasn't mr.nicknasty8 just saying that these are pulling fuel up top and the AFR is actually more lean (close to 12) than 11.4 it is showing? My MAP logs look almost exactly the same.
03-25-2018, 06:29 PM | #1984 | |
Member#: 391748
NESIC
Vehicle:2015 WRX CWP (sold) 2019 STi CWP |
03-25-2018, 07:32 PM | #1985 |
Member#: 459692
South East
03-25-2018, 07:41 PM | #1986 |
Member#: 478291
Vehicle:2018 WRX WRB |
Can somebody take a look at this log. Got some fine knock learn in higher rpms. Seemed to learn to 0 pretty quickly.
2018 wrx MAP stage 1 93 oct No other mods I also just sent it over to Ian at MAP. https://datazap.me/u/mkodada/log-3?log=0&data=5-18 Thanks |
03-25-2018, 07:47 PM | #1987 | |
Member#: 477459
NESIC
Vehicle:2018 WRX Crystal White Pearl |
I have a 2018 wrx with the MAP 93 oct too and had fkl in almost the place. Except mine hit -2.8. I reached out to Ian to last week week too but haven’t received any response. https://datazap.me/u/mp9656/log-1521...=...1-12-13-19 I have a protune scheduled with Bren on 4/11. Going to stick with the Cobb 91 tune until then. |
03-25-2018, 07:50 PM | #1988 | |
Member#: 478291
Are you concerned about this. Not getting anything during normal driving. Just going to stay away from WOT. |
03-25-2018, 07:54 PM | #1989 |
Member#: 453427
Vehicle:2017 WRX Crystal White Pearl |
The new revision of the MAP tune is odd, either your car loves it or your fuel trims get too negative in the higher RPM range.
Anyone know what the safe range is for FA20 Turbo? I assume +/- 8-10% for STFT. Negative trims are "go lean" and positive are "go rich" most of the logs are pulling fuel out at WOT from what I've seen. Edit, from COBB: A/F Correction #1 (A/F Correction 1) -> Short-term (immediate) fueling correction in closed loop based on input from the front oxygen sensor. This is a percentage correction of the injector pulse width base. Positive values indicate fuel is being added as a result of the correction. Negative values indicate fuel is being removed. |
03-25-2018, 08:00 PM | #1990 | |
Member#: 478291
Did my other numbers look ok? Would you recommend going with the Cobb stage 1 93. Or just stay away from WOT. Not getting any bad readings just that one. |
03-25-2018, 08:04 PM | #1991 |
Member#: 391748
NESIC
03-25-2018, 08:10 PM | #1992 | |
Member#: 419593
03-25-2018, 08:20 PM | #1993 |
Member#: 478291
03-25-2018, 08:28 PM | #1994 | |
Member#: 478291
Sorry little confused so my log is showing a lean AF correction #1 at WOT? Would you recommend switching to conn stage 1? And is it a good idea to run the 91 oct with 93 to protect further. Really got the AP for increased drive ability. |
03-25-2018, 08:31 PM | #1995 |
Member#: 391748
NESIC
03-25-2018, 08:35 PM | #1996 |
Member#: 478291
03-26-2018, 02:04 AM | #1997 |
Member#: 223813
BAIC
Vehicle:2016 WRX Premium Lapis Blue Pearl |
Hey all, just wanted some feedback on a 3rd gear log I ran tonight. Anything look off? Thanks in advance!
Specs: 16 WRX; Cobb OTS Stage 1 91 map; Perrin Charge Pipe; STi SPT catback https://datazap.me/u/pr0file/32518-c...-5-12-17-18-22 |
03-26-2018, 07:27 AM | #1998 | |
Member#: 327563
Vehicle:2018 Civic Type R 2008 N54 335i |
03-26-2018, 07:33 AM | #1999 | |
Member#: 327563
03-26-2018, 08:44 AM | #2000 |
Member#: 459692
South East
