11-17-2000, 01:38 PM | #1 |
Member#: 2543
Vehicle:2002 wrx |
What's the difference between turbo and a supercharge?
I just wanna know what's the difference between the supercharge and a turbo. I know most of the info about the turbo and I dont know jack about superchargers. Well, what I wanna know is which one is better? do the supercharger need a intercooler? etc,etc,etc.
11-17-2000, 01:50 PM | #2 |
Member#: 2683
South East
Vehicle:2011 STi 5-Door White |
Both units do basically the same thing: compress the intake air before it enters the cylinders so that there's more oxygen.
Superchargers run their compressor off the crankshaft of the engine, just like the A/C compressor or power steering pump. Turbos run their compressor off of engine exhaust gas which spins a turbine which spins the compressor. Superchargers normally give less lag at low rpm ranges than turbos, but may put more wear on your engine and usually don't give as much of a performance gain at the peak. Turbos lag because the exhaust gases have to spin the turbine up to speed before their compression really takes effect. This has been a really rambly answer, but I hope it helped. I also don't claim that all of this info is 100% correct, but it's the way I've learned it. Ross N. |
11-17-2000, 01:57 PM | #3 |
Member#: 1259
Vehicle:1999 Impreza RS Rally Blue Pearl |
From what I gather, there are much more reliable turbo set up's for this car at the moment than Superchargers.
11-17-2000, 03:27 PM | #4 |
Member#: 681
Hey, post this in the "newbie" section for crying out loud!!
ASNG |
11-18-2000, 12:58 AM | #5 |
Member#: 2452
SCIC
Vehicle:2016 WRX WR Blue |
Some good shiz grimlock. I really didn't know that myself..
11-18-2000, 10:29 AM | #6 |
Member#: 2959
Turbo... GGOOOODDD. Supercharger... BBBAAAADDD.
Similar Threads | ||||
what's the difference between turboxs and vishnu's unichip? | Poe | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 30 | 10-24-2002 11:14 PM |
What's the difference between GC8 and GDA springs? | Red Rocket | Brakes, Steering & Suspension | 3 | 08-16-2002 05:48 PM |
quick question, what's the difference between 18mm and 20mm sway bars? | popnGEAR | Brakes, Steering & Suspension | 17 | 05-15-2002 02:20 AM |
What's the difference between AWD and 4WD? | IBO | Newbies & FAQs | 24 | 07-31-2001 12:56 PM |
What's the difference between AWD and 4WD? | Fubaru | Newbies & FAQs | 19 | 05-03-2001 10:15 AM |
