09-27-2004, 10:28 PM | #1 |
Member#: 71297
Vehicle:2005 STI WRB |
Broke 1kmls on my 05' STI!! Got $2000 to spend on Mods
I just broke 1000 mls on my brand new STI . Im looking to get between 350-400 WHP . Can $2000 get me there???
I think i found a turbo back HKS, so far thats it.
09-27-2004, 10:53 PM | #2 |
Member#: 524
Vehicle:04 STi White |
No, can't even hit 350WHP. cracking 300WHP might be possible, haven't done the math lately
I'd do GPMoto short ram ECUtek Inlet hose Turboback Walburo 255lph pump |
09-27-2004, 11:03 PM | #3 |
Member#: 22866
Vehicle:2007 Victory Vegas 8 Ball Black |
nah, 2K ain't even gonna get you close...sorry...
figure around 4-5K to start. 1K...TBE exhaust 1K+...EMS 1400...Green 400-800...Injectors/Walbro intank pump |
09-27-2004, 11:06 PM | #4 |
Member#: 40328
South East
Vehicle:2004 WRX STi BSP #728 |
where u at dude?
09-28-2004, 12:10 AM | #5 |
Member#: 71297
south miami Ok OKok maybe 2 grand wont get me there RETAIL, but second hand or third hand equip. might get somewhere up there, dont you think??
I found an hks turbo back 450 bucks, now what else?? |
09-28-2004, 12:35 AM | #6 | |
Member#: 45737
Vehicle:2004 WRX STi Black/Gold |
09-28-2004, 01:20 AM | #7 |
Member#: 524
Depends on the area, and the tuner. If custom tuning the ECUtek is an issue... well I know there is a good unichip map for that stuff, and on stock injectors they work great. I mean I was the first person to have a unichip on a STi and have cracked 400WHP on one.
I just think that most people here are more comfortable with the reflash, even if the unichip works just fine. |
09-28-2004, 01:22 AM | #8 |
Member#: 34112
TXIC
Vehicle:i only like ot as a friend |
NAAAAAAAAAAAWWWWWWWZZZZZZZZZZ!!!
, i've got a wicked td-04 that get you to around 500whp, give or take a few. $2k and its yours... |
09-28-2004, 01:22 AM | #9 |
Member#: 61006
2000 can reach 350-400 whp??
not really possible... |
09-28-2004, 01:23 AM | #10 |
Member#: 22321
do it the ghetoo way.
take off the stock turboback, run open exhaust put on the green. 220 dollars for modded injectors MBC 2000 dollars who said he wanted it to last. |
09-28-2004, 01:58 AM | #11 |
Member#: 524
green running real boost w/o EM AND upgraded fuel system is dead.
09-28-2004, 02:15 AM | #12 |
Member#: 46107
Vehicle:2004 STi Black |
I think it is possible, if you do all your own installation and tuning. See here:
stock STi baseline: 245whp used hks dp: +20whp $100 used fp green turbo: $950 used greddy emanage w/ harnesses: $300 used modified wrx injectors: $200 used top feed fuel rail setup: $375 used walboro fuel pump: $75 If it's tuned well that could put you at about 375-400whp on 100 octane and Maybe 350whp on 93 pump gas. A $400-500 catback exhaust is a waste of money if you are shooting for that goal with that little money since it gives you maybe 5-10whp, while just a cheap downpipe should give you twice the gain. Same thing with a $150-200 intake. Now you still should have a couple hundred more for the nessecary gauges to go with that setup, and even if you couldn't tune it yourself, it's only another $150-250 for a dyno tune with emanage. You would need a replacement clutch before you know it, and you may need new rear axles sooner than you think. |
09-28-2004, 02:31 AM | #13 |
Member#: 71297
used fp green turbo: $950------->>what model?
I really want to stay with the stock turbo. |
09-28-2004, 02:36 AM | #14 |
Member#: 524
emange = broken motor.
hell thier POS boost controler is doing wonders for trying to break my car. jesus. Not only does it fail to work in sub 50 degree temps, but just recently it decided to stop controling boost at all. Thanks $550 boost gauge I guess. |
09-30-2004, 10:35 AM | #15 |
Member#: 71297
Thanks alot guys!! This is a cool website!!
09-30-2004, 01:22 PM | #16 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
09-30-2004, 03:51 PM | #17 |
Member#: 39462
Vehicle:04 STi Type R Spec Broken Wallet |
Upgrade the SWTS Linkage
Best bang for the buck. However, a lobotomy might be more useful in this case. |
10-01-2004, 01:47 AM | #18 |
Member#: 22731
NWIC
Vehicle:2002 WRB Do-Luck GDA worldoneperformance.com |
Ralph...
300 whp for that amount can be had pretty easily through the means we talked about in emails. 350whp can come your way for not much more also. Let me know if you have more questions. |
10-01-2004, 10:41 AM | #19 | |
Member#: 71297
10-11-2004, 12:18 AM | #20 | |
Member#: 6971
NWIC
Vehicle:2008 WRX STi SSM |
Scary! That's not the first time I've heard of the E-01 borking out. |
10-11-2004, 08:54 AM | #21 |
Member#: 23676
NESIC
Vehicle:. |
Gut the downpipe and third cat=free
Perrin short ram=170 STI UTEC/Tuna=1600 Greddy boost/EGT gauges=300 Just over 2k, and easily 300whp |
10-11-2004, 08:57 AM | #22 | |
Member#: 23676
NESIC
Vehicle:. |
Just because your unit failed (yeah because a quality company has ZERO failures right?) dont generalize the emanage as junk |
10-11-2004, 02:25 PM | #23 | |
Member#: 6971
NWIC
Only 2 cats on the STi as far as I can tell Please correct me if I'm wrong. |
10-11-2004, 08:58 PM | #24 |
Member#: 65609
SCIC
Buy all your **** used. Buy a used TBE, used downpipe, used headers, and a walbro...and you'll be at around $1,000. Then save...personally my 350whp setup cost me a pretty penny...think over double your figure...
10-11-2004, 09:01 PM | #25 |
Member#: 65609
SCIC
You're going to need...
Front Mount Intercooler(or you could go top mount i guess...if you want heat soak) Turbo Back Exhaust Downpipe Headers Injectors Fuel Pump Bigger Turbo Ecutek EM(cheap and really good) Tuning ~400 |
I Have $1500 To Spend On A '04 Wrx. What Are The Best Performance Mods To Get???????? | DEVIL_WREX | Newbies & FAQs | 47 | 05-24-2007 07:21 PM |
05 STi. $2500 to spend.. best mods to get? | CDSpencer | Newbies & FAQs | 32 | 12-16-2006 12:07 AM |
$1500-$2000 to spend on my STi | yelWRXlow1 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 22 | 08-11-2005 06:15 PM |
Scenario: $6000 to spend on STI mods within warranty | 1STPSTI | General Community | 29 | 10-29-2004 01:14 PM |
$1,000 To spend on mods.... what to get.. | x Neo x | STi Forum Archive | 13 | 08-11-2003 06:07 PM |
