08-04-2000, 01:06 PM | #1 |
SCIC
Moderator Member#: 85
SCIC
No Check Engine Light with the ITC..... Belive it or not?
After much needed help from Mike Moffa I finally have my ITC installed and running on my 97 2.2L automatic. I did this on Saturday and flogged the car pretty handily on Sunday with our SC'i'C meet at Hooters and Timmons (nothing like catchin air at 40mph....DOH right Brian) . I still have NO check engine light and I have even advanced timing enough to have the stock ECU retard timing (felt like bogging) .
I am figuring that the reason is something to do with the OBD II software and that it became more strict on newer versions for our cars. With all that said and done next is the J&S to complete the alphabet soup and then the turbo. So for those with 97 2.2L's I would hope you too have the same results and it does make a difference with higher octane gas and some advancement in timing. So Kevin Thomas and others you can consider this an option now that won't throw a CE light and if mine goes I will post here. Rich
08-04-2000, 01:12 PM | #2 |
Moderator Member#: 922
Vehicle:16 WRX (white) 04 FXT (red) |
I thought that OBDII was introduced in the MY00's... Which would be odd since most people with 98-99's have the light come on. *shrug*
08-04-2000, 01:29 PM | #3 |
Member#: 383
Vehicle:2001 Outback Sport Black |
what kind of differences are you noting with the ITC?
08-04-2000, 01:41 PM | #4 |
Member#: 213
Vehicle:2004 Mazda RX-8 Black |
I believe it.. for now
Trust me on this, the CE light will come. At one point, I actually managed to go close to 2 weeks before the CE light came back on. But it always does. By the way, how far did you advance the timing? As of now, my ITC is set at 6/6/6/5/5 and my car seems to run quite well, certainly much better than stock.. |
08-04-2000, 01:46 PM | #5 |
Member#: 626
Vehicle:2001 Impreza 2.5 RS Black Diamond Pearl |
And Subaru said the check engine light shall work in mysterious ways
And thus it came to pass. |
08-04-2000, 02:42 PM | #6 |
SCIC
SCIC
8 if memory serve's me right OBDI covered the 94 and up automobiles and starting with 1997 model years ODBII was phased in which allowed more strict sensoring and caused the CE light and other sensors to trip. The CE light that the 98/99/00's are getting is a misfire code because the ITC intercepts the Crank and Cam signals and modifies it to advance or retard timing.
DADA I am noticing better throttle response off idle and definetly better pull to the top end. If I had the money I would dyno my car and see what kind of #'s I would get but then I can just hear all the anti-auto DYNO chart non believers out there saying there usual. Cacaphony if it does come on I will like I stated post here or in a new post but I am at about 400 miles and nothing not even a blink and I advanced it about 7 off idle and when I got on it was when the stock Knock Sensor beat back the timing. IIRC my settings with out running to my car are 3,6,6,5,3 for now till I play around with it alittle more. I was expecting the CE light when I installed it and even on my trip to LA for our meet and our freeway jaunt which was fun and I used as a Knock/retard/CE light test and nothing. Nick Don't make me come down there and smoke you and your Turbo'ed auto RS like that Integra. And you wonder why he left you like your GIRL!!!! Rich |
08-05-2000, 11:57 AM | #7 |
Member#: 817
The ITC made Throtle response MUCH BETTER and the car pulls much harder. My CE light came on after about a week, mainly cuz I advanced the timing to around 9-10 accross the board. I did a ECU reset and now I'm at +7 across the board with NO CE light. I also have my AFC -5% across the board at High throtle. my car only has exhaust, no intake.
Kyle |
08-05-2000, 04:42 PM | #8 |
SCIC
SCIC
Jay you crack me up . Actually no the CE light works as it light's when I start the car.
Rich |
08-05-2000, 10:00 PM | #9 |
Member#: 626
MPREZYA wrote:
Nick Don't make me come down there and smoke you and your Turbo'ed auto RS like that Integra. And you wonder why he left you like your GIRL!!!! I think my girl left becuz my setup was too stiff, she did not like the harsh ride so I told her to go find another. Hmm, that did not sound car related. Edit: Race me Rich? You have enuff problems losing to Joel. [This message has been edited by NickSTi (edited August 05, 2000).] |
08-05-2000, 10:14 PM | #10 |
Member#: 168
SCIC
Vehicle:2011 M3 and 328i white and black |
I got your back Rich
www.wonderlan.com/~hksupra |
08-06-2000, 12:23 AM | #11 |
Sooby Guru
Member#: 1914
SWIC
Vehicle:2000 2.5RS w/ EJ22T swap and N20. gone. : ( |
On Every car in America, OBD 1 ended in 1995 and starting in 1996 all cars had to have OBD 2.
Eric MY00 Aspen White |
08-06-2000, 12:48 AM | #12 |
Member#: 296
hey dude...
Are you sure your check engine light lamp hasnt blown ? lol J. |
08-06-2000, 04:05 PM | #13 |
SCIC
SCIC
Nick you must think that me not showing to race Joel the "rental car" racer meant I lost. Well let's put it this way if Joel wanted to race then fine more power to him I have no argument. But he said he wanted to race me with his 1.8L not a rental Gran Prix. Which that is all behind us now. Anyways Nick you know I would humiliate you in reverse too .
Rich |
Fidanza Flywheel has a NEW Look!! NO Check Engine lights- Starting at $215 <-------- | JSC Speed | Drivetrain | 68 | 09-13-2007 11:08 AM |
codes with no check engine light | 06STi | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 4 | 12-23-2005 07:17 PM |
Check Engine Light with the Greddy BC. | ShiverinBlue | Newbies & FAQs | 8 | 02-13-2005 09:27 PM |
Oh NO! Check Engine Light! | GRKGT | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 9 | 10-31-2004 06:47 PM |
How to gain HP without modchip, low exhaust noise, no check engine light. | OvRclockR | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 23 | 09-20-2002 03:17 PM |
