Welcome to the North American Subaru Impreza Owners Club Sunday January 20, 2019
Old 04-25-2003, 06:34 PM   #1
SPeeDSiN
Member#: 4667
Black (well kinda)
Default My STI injectors aren't STI injectors???
I have been trying to diagnose some troubles with my car.
Basically, I have stg2 + injectors + uppipe.
So when I went to get my car tuned at Knowledge, instead of taking out fuel, they were adding it. Weird huh?
So we started tryint to figure out why. Maybe the MAF was bad. So I replaced that, and still got the same voltage readings.
So TXS and Knowledge told me to check my fuel pressure, cause the STI's shouldn't really even idle that well on a stage 2 map.
Well I checked the fuel pressure, and it was between 45 and 47 psi.
So they told me that there have been a few cases where the STI injectors weren't 560cc but actually stock (or something to that affect)
I wanted to know if anyone else has run into this problem.
SPeeDSiN is offline   Reply With Quote
Old 04-25-2003, 08:33 PM   #2
alltractionWRX
Member#: 14819
WR Blue
hmm that's interesting where did you buy your injectors from. Was the box an authentic subaru box?
alltractionWRX is offline   Reply With Quote
Old 04-25-2003, 10:00 PM   #3
Si2WRX
Member#: 13173
309 hp on 93 + W/I
on Dyno Dynamics
Here's the p/n from my injector box: 1611AA510 These are definitely the 565cc (also have seen as 550cc) STi injectors.
Perhaps you still have the packaging as a cross-reference.
Lots of good info here too: http://www.northursalia.com/parts/partswrx.html
Notice the p/n 16611AA231 ... 480cc Legacy STi injectors. Would those fit an EJ20? Not much bigger than the stock 440cc ... hmm.
Si2WRX is offline   Reply With Quote
Old 04-26-2003, 01:21 AM   #4
Imprezd
Member#: 3357
check the vaccum line going to the fuel pressure regulator. It is likely that your fuel pressure is not be raised because your regulator vaccum line is severed or disconnected. Worth a shot...
Imprezd~
Imprezd is offline   Reply With Quote
Old 04-26-2003, 05:35 AM   #5
alltractionWRX
Member#: 14819
WR Blue
Yeah that's weird because Ninos auto accessories sold me 550cc and they are a reputable shop so they wouldn't rip me off. Maybe he just wrote the wrong number on the boards.
WTB: STi pink injectors/ 07 STI injectors/ 06 WRX injectors bwco VIC Private Classifieds 8 06-19-2013 11:40 PM
how will my WRX run on STi injectors w/stock ECU (no piggyback/reflash, etc) annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 04-10-2004 10:14 AM
How do i adjust my utec to 565 Sti injectors? kdogpenny1 Newbies & FAQs 2 02-10-2004 11:45 AM
Why aren't Sti springs and 04 wrx sedan springs compatible? kitbar Brakes, Steering & Suspension 16 10-16-2003 01:02 PM
My Tail lights aren't working CerealKilher Interior & Exterior Modification 2 06-13-2002 06:08 PM
