10-16-2009, 10:28 AM | #251 |
Member#: 54918
Vehicle:673 WHP Element Tuning Pro Comp Engine |
No major hardware changes just some resistors, capacitors, something with the WB circuit, and then a firmware change.
10-16-2009, 10:29 AM | #252 |
Member#: 54918
You should count out loud. If it's taking longer than 3 seconds then you can improve it. With the Nemesis 2.5 you can get it down to about 1.5 seconds and on the 2.6 you can get it almost exactly like OEM.
10-16-2009, 10:56 AM | #253 |
Member#: 86559
BAIC
Vehicle:2005 RS Wagon |
cool thanks, i don't need to shell out for 2.6 but by the end of the month i will contact you about the 2.5.
on another note, do you have 4 inch maf housing? I wanted to remove the MAF but I realized it is needed for the IAT. I read about going GM but im still researching my route. |
10-16-2009, 12:24 PM | #254 |
Member#: 54918
Just stick the MAF sensor into the hole in your fender so it reads ambient air. We run all the race cars this way and all the rotated kits with 4" intakes. It works perfectly with our maps as they are calibrated this way.
Many have tried other IAT solutions but almost everyone went back to this way due to how well it works and how fast it responds to temp changes. |
10-16-2009, 01:11 PM | #255 |
Member#: 86559
BAIC
i'll look into that. so basically i can just zip tie it in the fender correct? you have a picture of the setup?
10-16-2009, 01:49 PM | #256 |
Member#: 141952
Vehicle:2023 M340i |
hmmm, i drastically improved mine but i dont think its even as fast as 1.5 seconds. i have a 2.6. any general tips on getting it started the fastest?
10-16-2009, 05:30 PM | #257 |
Member#: 54918
Tons of fuel (may have to add it into the fuel map areas where the highlighted cell is during cranking. Also it does depend on your fuel pump setup how fast it starts.
Cranking speed makes a difference also. Some built engines or older starts just don't have the kick over speed of the newer cars. |
10-16-2009, 05:31 PM | #258 |
Member#: 54918
There is actually a hole that the sensor fits snugly into. The plug will be in the engine bay and just the probe portion will be in the fender well. If you don't have your fender liner in there you may not want to do this.
10-16-2009, 05:42 PM | #259 |
Member#: 86559
BAIC
oh i get, i'm still pretty stock, bodywise.
my sti only have 11k on the clock, oem starts up uber quick even with 816cc |
10-16-2009, 08:00 PM | #260 | |
Member#: 141952
10-19-2009, 11:04 AM | #261 | |
Member#: 54918
If weight is not a concern like it is for my race car get the strongest battery you can get. I've seen some that are close to OEM size that have 750+ cold cranking amps! It can turn the motor over at like 400 rpm |
10-21-2009, 04:32 PM | #262 | |
Member#: 141952
10-22-2009, 02:22 PM | #263 |
Member#: 54918
I think it was a Delco or Sears. Typically there are many batteries that will fit there but if you ask for a battery for your car they will just give you an OEM equivalent (which sucks).
You need to just look at all the sizes and the specs at the store and pick up the bad boy! |
11-06-2009, 09:33 PM | #264 |
Member#: 205916
South East
Vehicle:2003 Subaru WRX in the 10's and the bends |
Is the 2.6r9 file compatible with Windows 7?
11-08-2009, 07:58 PM | #265 |
Member#: 44256
Vehicle:05 outback xt 02 wrx wagon - crushed :( |
02-12-2010, 10:59 AM | #266 |
Member#: 54918
Yes I have used the Hydra 2.6 software with Windows 7 but I tried a USB-Serial adapter and the driver didn't work. When to the manufacturer's website and a specific Windows update was required. Still the best option is a PCMCIA Serial Card or Express Card.
02-12-2010, 11:02 AM | #267 |
Member#: 205916
South East
Yeah, I ended up just getting a ToughBook. However, what specific update are you talking about? Are you saying that you actually got the windows 7 and hydra to connect using the USB-serial adapter?
02-12-2010, 11:17 AM | #268 |
Member#: 54918
No I didn't bother to install the update to the Windows 7 software since I don't use USB. The specific version was on Prolific's website since that's the adapter I attempted to use.
02-13-2010, 05:17 PM | #269 |
Member#: 30554
RMIC
Vehicle:2013 GLK250 |
Hydra Wideband Sensor Options
I would like to have my a/f ratio information displayed in a 2 1/16" gauge (like the Innovative or Autometer) on my dash. Is there an aftermarket wideband guage that can use the Hydra WB sensor and not cause issues with the Hydra or do I have to have an additional sensor installed?
02-15-2010, 10:41 AM | #270 |
Member#: 54918
At this point your only option is a AIM Sports Digital Dash which is not a gauge. For 2.7 there will be gauge options so I would hold out until that option is available.
02-15-2010, 01:10 PM | #271 |
Member#: 16087
South East
Vehicle:02 WRSTi World Rally Wooooo |
Curious that 2.7 is going to cost how much more then 2.6 because I am also interested in a gauge!
Chuck III |
02-16-2010, 06:43 PM | #272 | |
Member#: 175095
PRSIC
Vehicle:2000 RS Silver |
ScoobaruRS read my mind on this, I was even talking with a friend of mine that has a 2.6 on his swapped RS yesterday asking about the same thing, as a matter of fact I was about to order one of the wideband gauge kits available today. |
02-17-2010, 11:21 AM | #273 | |
Member#: 54918
Right now if you buy a 2.6 we'll offer a free basic upgrade to 2.7. There will be some 2.7s available at the same price as current 2.6 units but some will be +$800 more than what we currently offer with the 2.6. The 2.6s being sold right now have the latest hardware and will be expandable to the highest of the 2.7s when it comes out. We've done it this way because many may not have the $ or the need for all the bells and whistles but as budget and needs increase you'll be able to upgrade. What's on the horizon? OBD2 support, On board data logging (various memory amounts), Full CAN Bus support, User upgradeable software flash, dual DBW Throttle support, more flexible DBW support, easier to use Autotune,and tons of new maps and tuning strategies. That's really on the tip of the iceberg but as you can imagine we can't pack all of that for the same price so you'll have a choice of features and price points. Thanks, Phil Grabow |
03-13-2010, 06:34 PM | #274 |
Member#: 93776
Vehicle:2002 Impreza WRX Silver |
I've tried a few times, but I can't get the Nem 2.5 r12 or 15 to load on my Windows 7 system.. I get the
Component 'COMDLG32.OOCX' or one of its dependencies not correctly registered; a fils is missing or invalid error... I tried to directly download the files however I keep getting it.. I'm running a netbook so I don't have a cd rom for my origional Hydra CD.. Any ideas or anyone else running into this?? EDIT: Scratch that. I used my Thumb drive to install Windows 7 Ultimate inplace of that crappy Windows 7 Starter that was preloaded. No more issues with the Nem program, now lets hope the USB-Serial works.. LOL.. Last edited by lil shoaf; 03-14-2010 at 11:33 AM. |
03-15-2010, 01:02 PM | #275 |
Member#: 54918
Also sometimes you have to "run as administrator" during the install or else you have to manually register some files like we had to do on some Vista versions.
Using the Hydra with the GM AIT Sensor.. | sponaugle | Other Engine Management | 1 | 11-14-2008 01:24 PM |
How does the antilag work on the Hydra? | Crazykev | Other Engine Management | 2 | 10-15-2005 07:11 PM |
How many people are using the Hydra on the STi? | Quick | Other Engine Management | 10 | 10-03-2005 01:20 AM |
The Second Official Unofficial Hydra Thread | bboy | Other Engine Management | 2 | 06-06-2005 11:39 AM |
Hydra Users: Anyone know the Hydra injector mapping? | wgknestrick | Other Engine Management | 12 | 03-07-2005 04:12 PM |
