11-21-2008, 04:12 PM | #1 |
Vendor Sales Rating: (25)
Member#: 171650
STi Limited Front and Rear Spoilers, 08 Sport Grills, Rare JDM Bits....
STI Limited Front Lip Spoiler for 2006 - 2007 STI and WRX Sedan This is a Genuine Subaru OEM Lip Spoiler off of the 2007 STI Limited. It will fit all 2006 - 2007 STI's and 2006 - 2007 WRX Sedan's, and comes with all necessary installation hardware and instructions. Give your can an agressive look while improving aerodynamics at the same The spoiler is made of heavy duty black plastic with an STI emblem in the center. STi Rear Deck Lip Spoiler Adds a stylish performance touch to the rear decklid.Complete kit with rear brake light. Primed and ready for paint. Fits: Impreza Sedans 2006-2008. 06 STI Rear Diffuser Kit for all WRX's, and 04 - 05 STI's For 2006, Subaru installed a rear air diffuser on the STI to help smooth out air-flow at the rear of the car.This kit allows this diffuser to be installed on any previous STI, and all WRX’s, sedan or wagon.This diffuser has reduced cabin noise in our Project Car, and improves the look of the car from behind. The Kit includes: 1 - Cusco Rear Sub-Frame Brace 1 – Cusco Bracket set 1 – Rear Diffuser 4 – Bolts for Diffuser The only part not included are two small bolts to attach the front bracket to the car. Please note that this kit is not compatible with the Whiteline Heavy-Duty Sway-Bar mounts, and will not fit if you have a tow hitch on your car. Subaru Sport Grille for the 2008 Impreza For the new 2008 Impreza, Subaru has designed an optional Sport Grille to give the car a more agressive, sporty look. Because it's made by Subaru, it will fit like an OEM part, and comes with detailed instructions for installation. It also comes pre-painted to match your car's factory paint. These are in stock, and ready to ship. Please be sure that you specify the color that you need when ordering. Cusco WRX License Plate Re-Location Kit This kit relocated your front license plate from the center of your bumper, to over your left fog-light.This increases the amount of air going over your radiator, or Front-Mount Intercooler, dramatically improving cooling. This is ideal if you are driving in a warm climate, or if you spend a lot of time at the track. Cusco designed this kit for the GC chassis Impreza, but it can easily be retro-fitted to any of the newer models. STI Hood Scoop 02-03 JDM STI Hood Scoops are back in stock and ready to ship! This taller hood scoop is just what you need to get more air over your intercooler. If you have upgraded to a larger Top Mount Intercooler then we recommend this larger scoop to help it work more efficiently. The 2002 - 2003 Scoop is off the JDM STI, and is not pictured, but looks very similar to the OEM scoop. Both scoops come un-painted. The 02-03 JDM STI Hood Scoop also fits the 2004 - 2006 Forester XT. Perrin Shorty Antenna for the 2008 WRX & STI Simply put the factory antenna on the new 2008 Subarus is way too long and unattractive. Eliminate the radio controlled car look with a shorty mast from PERRIN™. Available in either 2” or 3” sizes, these all-aluminum antennas look great thanks to an anodized, black finish. No adapters required. Perrin STI Wing Stiffi now on sale for $44.80 each! The addition of a Perrin Performance STI Wing-Stiffi eradicates annoying wing flex forever. Simply slides into position inside the two halves of the rear wing and uses existing holes for mounting along with 3M adhesive to eliminate the need for any drilling, cutting, or hacking of your expensive OEM wing. Add up to 5 Perrin Wing Stiffi's for a WRC Rally inspired look. STI Air Splitter for STI Hood Scoop If you are running a larger top-mount intercooler, or an STI intercooler, and a larger hood scoop on your WRX, you need the STI Air Splitter to get the maximum improvement in cooling. The STI Air Splitter is taller to reach the larger hood scoop to make sure that all the additional air is diverted over the intercooler. The STI Air Splitter also has a second diverter in the middle to make sure that air is also directed to the front and middle of the intercooler to further aid in cooling. The Air Splitter’s are available for the 02-03 “Bug-Eye” WRX, as well as the 04-05 WRX. Please make sure that you select the correct splitter for your car as they are not interchangeable. This kit includes the splitter, and the rubber baffle that mates up with the intercooler. The STI Hood Scoop is sold separately. Lots more to come..... If you have any questions please don't hesitate to ask, you can contact me via PM, E-mail, phone, or just stop by. Thanks, Mike Makowski FlatironsTuning 5995 Arapahoe Ave. Boulder, CO 80303 (303)-402-5142
11-21-2008, 04:24 PM | #2 |
Member#: 171650
STI Door Decal This Decal came on the front driver's and passenger's side doors, but can be applied to any other location on your car to give a more unique look. STI Fog Lamp Covers for 02 - 03 WRX STI logoed metal mesh covers let the light shine through wile helping to protect stardard driving lights from stones and road debris. Fits: 02 - 03 WRX Sedan and Wagon STI Trunk Emblem This is the trunk emblem that came on the 2004 - 2005 STI. STI Fog Light Decal This is the decal that came on the fog-light covers of the 2004 - 2005 STI, but can be applied to any other location of your car to give you a more unique look. WRX Wagon Roof Rail Deletes This kit includes a left and right molding for all 02+ WRX Wagon's that are necessary to fill in the holes left when removing the roof rails. Professional installation is recommended. STi Front lip spoiler gives your WRX or STi a mean, ground-hugging attitude. Comes in black only. Not compatible with Front Underspoiler. Give your can an agressive look while improving aerodynamics at the same time! The spoiler is made of heavy duty black plastic with an STI emblem in the center. Subaru Part # E2410FG110 WRX $475.00 E2410FG120 STi $475.00 08-09 WRX, STi Front Lip Spoiler (for the WRX) 08-09 STi Front Lip Spoiler (for the STi) 08-09 STi Front Lip Spoiler Last edited by FlatironsTuning.com; 04-27-2009 at 10:51 AM. |
11-21-2008, 04:25 PM | #3 |
Member#: 171650
We just got in some cool JDM BRZ parts.
They are all in our BRZ Exterior section here If there are any other unique JDM parts that you would like to see let us know and we'll see if we can track them down. These are the clear corner lights that come on the Japanese model BRZ, and will help to give your BRZ or FR-S a unique look! These are the housings only. Bulbs are not included, but your bulbs and wiring harness will simply transfer over. Subaru part #'s are: 84912CA120 84912CA130 Click Here to order you JDM BRZ Clear Corners - $95.60 These are the tail lights that come on the BRZ in Japan. Bulbs are not included, but your USDM bulbs should transfer over. Perfect to give your BRZ a unique look! Subaru Part #'s are: 84192CA041 84192CA051 Click here for your JDM BRZ Tail Lights - $637.33 This is an accessory available only in Japan, and will give the interior of your BRZ or FR-S a nice JDM touch. Be aware that instructions are included, but they are all in Japanese. Professional installation is recommended. Subaru part # is 92039CA000 Click here for your JDM BRZ Frameless Mirror - $91.45 STI Gurney Flap for the BRZ Wing will sit in the stock wing, and will actually increase its downforce. This is a very simple way to get a little more grip in the rear of the car at speed. A must for any BRZ or FR-S that sees a fair amount of track time. Subaru part # ST96010AS000 Click here for your BRZ STI Gurney Flap - $154.43 JDM STI Strut-Bar Battery Tie-Down Clean up your engine bay and give it a cool JDM look in the process! Subaru Part #ST82182ST000 Click here for your JDM STI Battery Tie-Down - $165.00 Last edited by FlatironsTuning.com; 03-14-2014 at 04:56 PM. |
11-24-2008, 11:05 AM | #4 |
Member#: 171650
We have put together a Flat Fuel door kit for the 1993 - 2001 Impreza Sedan, Coupe, and Wagon!
It includes all new parts straight from Subaru, and includes everything you need to have a functioning Flat Fuel Door on your GC/GF! Now available on our website at an introductory sale price of only $88.30! . Last edited by FlatironsTuning.com; 11-18-2009 at 06:56 PM. |
12-19-2008, 10:55 AM | #16 |
Member#: 171650
__________________
Call us at: 303-402-5142 Visit our site at: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Check out our Facebook page out: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Follow us on Instagram at: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Need more info? Check out our YouTube page: www.youtube.com/channel/UCjQAaoNCY-cixR9koIE3oeg |
12-29-2008, 11:34 AM | #18 |
Member#: 171650
Monday morning bump.
__________________
01-05-2009, 11:52 AM | #19 |
Member#: 171650
New Year Bump.
__________________
01-07-2009, 12:12 PM | #21 |
Member#: 171650
__________________
01-08-2009, 12:00 PM | #22 |
Member#: 171650
Thursday bump.
__________________
01-09-2009, 11:00 AM | #23 |
Member#: 171650
Friday morning bump.
__________________
01-12-2009, 11:52 AM | #24 |
Member#: 171650
Monday Snowstorm bump.
__________________
01-13-2009, 11:29 AM | #25 |
Member#: 171650
Tuesday morning bump.
__________________
FS: 08 STI Stock front and Rear Sway Bars | geddesk2 | NWIC Private Classifieds | 4 | 03-24-2010 06:55 PM |
FS: NJ: JDM STI pink front and rear Sway bars | lilneel12 | Tri-State Area Private Classifieds | 1 | 10-04-2006 08:44 PM |
FS: RARE JDM STI GC Rally Champ limited Front and Rear seats! | Lam | VIC Private Classifieds | 0 | 08-04-2006 07:19 PM |
FS: NJ Brand new Jdm sti v9 front and rear seats! | D Money | Private 'For Sale' Classifieds | 29 | 04-13-2006 01:07 PM |
'04 JDM STi Brembos, front and rear | kmin | Private 'For Sale' Classifieds | 3 | 07-29-2005 10:15 AM |
