Tire & Wheel Forum sponsored by The Tire Rack |
11-29-2010, 11:25 AM | #1 |
Member#: 257446
Effect of Wheel Weight on Mileage?
Does anyone know if the weight of the wheel has a significant effect on mileage? I'm assuming steelies weigh more than alloy rims. I've seen alloys down in the 17-20 lb range.
Just wondering if it's even worth consideration. Thanks!
11-29-2010, 11:38 AM | #2 |
Member#: 207826
Vehicle:85k 2002 WRX Correct Fitment Crew #034 |
No gas mileage difference at all.
<---- has 16 lb and 24 lb wheels |
11-29-2010, 11:41 AM | #3 |
Member#: 254097
Vehicle:2010 2014 Impreza |
My winter set-up is 16" alloys instead of my stock 17". Probably lost 6-7lbs per corner, no mileage difference to speak of.
11-29-2010, 11:44 AM | #4 |
Member#: 141040
BAIC
Vehicle:07 2.5i wagon UGM |
Weight generally has little effect on highway mileage. It only increases rolling resistance, which is peanuts compared to drag.
The effect on city mileage will be slightly more, but not any more than putting some luggage in the trunk. |
11-29-2010, 12:59 PM | #5 | |
Member#: 95901
The more stop and go driving you do the more the rotational mass of the wheel and tire will effect your gas mileage, and brake wear. By how much? Not enough to justify buying a full set of new wheels and tires. $1500 buys a lot of fuel. Especially considering that $1500 is on top of the fuel you would normally purchase. Last edited by 68Cadillac; 11-29-2010 at 01:02 PM. Reason: Egnlish be hard, yo. |
11-29-2010, 01:15 PM | #6 |
Member#: 251904
Vehicle:2010 WRX 5 Door SSM |
11-29-2010, 01:46 PM | #7 |
Member#: 141040
BAIC
OK, great example of correlation not equating to causation in that article.
It's extremely unlikely that the change in wheel weight was what caused the big change in mileage in the Car and Driver test. Much more likely is that it was caused by the increase in drag resulting from a shorter sidewall, along with the progressively wider tires and, in the 18" and 19" sizes, the softer compound increasing rolling resistance. Take a look at bicycle wheels for an example: the more aerodynamic wheels have larger "sidewalls" which reduce drag at the expense usability (crosswinds become a bigger issue). Last edited by sniper1rfa; 11-29-2010 at 01:56 PM. |
Similar Threads | ||||
Wheels width vs. wheel weight on street car | CR22 | Tire & Wheel | 34 | 12-10-2008 12:33 PM |
How much cooling effect does wheel have on brakes? | shemoves | Brakes, Steering & Suspension | 13 | 07-05-2006 12:23 AM |
Effects of tire/wheel weight on 1/4 mile times??? | B-Kerr | Brakes, Steering & Suspension | 0 | 02-17-2003 02:15 AM |
Effect of aftermarket parts on market value? | Sauginius | General Forum Archive | 6 | 01-19-2001 12:56 AM |
