12-15-2004, 01:37 AM | #1 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
What % of hp increase per psi of boost?
Is thre any way to figure this? Obviously low compression motors equal smaller % gains, but can go way up in PSI boost levels, while high compression motors have much bigger gain per psi, but cant climb as high without serious problems.
I am just trying to guestimate my hp at this stage, boosting the 2.2 1990 motor which has 9.5-1 compression, 6 psi at this stage, hopefully 8-9 psi by the time I dyno test this spring. I normally estimate an increase of 7% per psi but this is for motors set up for boost, ie low compression motors. Just wondering if high compression motors give a noticeable increase % per psi of boost. |
12-15-2004, 02:32 AM | #2 |
Member#: 49958
Vehicle:'03 Cobra DSG SOLD '02 WRB WRX |
One main thing you need to remember is that PSI is just how much pressure of air is being pushed, not the amount. I think that CFM would have a much greater effect. Without knowing CFM of the air (volume), you really couldn't get a good figure.
12-16-2004, 01:15 AM | #3 |
Member#: 36333
NESIC
Vehicle:98 RS GT30R, closed deck madnes |
yea its really wierd...when someone asks you how much boost you are running, it means absolutly nothing. A vf22 running 15 lbs of boost is going to be a hell of alot more HP than a td04 (stock wrx turbo) running 20.
12-16-2004, 02:58 AM | #4 |
Member#: 73471
SCIC
Vehicle:2004 WRX Stg2+some Blk melon launcher |
lil advice: get somebody knows how to tune it, before u break it
12-16-2004, 03:02 AM | #5 |
Member#: 25516
NWIC
Hey red,
I was wondering if you had a picture of your injectors out of the car. I am still trying to compare the n/a reds to the turbo pinks. Thanks, Dustin |
Similar Threads | ||||
Tuners: how much hp increase per 1 lb of boost? | Tronner | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 10 | 09-16-2007 04:26 PM |
Wanna know what 32 PSI of boost @ 9000 RPM sounds like? | zzyzx | Off-Topic | 36 | 12-15-2005 08:22 AM |
What kind of HP with [email protected] PSI on STOCK motor | Davenow | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 09-08-2002 11:19 AM |
What has more hp 16.5 or 18.0 psi? | phxscooby101 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 01-29-2002 06:31 PM |
How much HP do you get from 1 PSI of boost? | Scoob | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 07-31-2001 12:18 PM |
