06-09-2007, 05:52 PM | #126 |
Member#: 131902
TXIC
Vehicle:2005 WRX Wagon Black |
Thanks
06-12-2007, 10:07 PM | #127 |
Member#: 149350
Vehicle:2005 WRX OBP |
ahh, i just read through all 6 pages of this. great info. so i should take out my K&N cold air intake and just throw in my OEM air box?
06-19-2007, 03:43 PM | #128 |
Member#: 115149
Vehicle:07 STI Murdered & Loud |
YES AND NO TO EVERYBODY!!!!!!!!!!!
JHFC PEOPLE It's laid out for the reader in the first post by UNA! How much simpler can it get????? |
06-19-2007, 06:08 PM | #129 |
Member#: 151432
Vehicle:1998 2.5 RS Arcadia Green Machine |
GReat Info on the intake
07-04-2007, 06:38 AM | #130 |
Member#: 92588
Vehicle:2005 STi Silver |
FYI - CobbTuning.com Aftermarket Intakes is now located at the above link.
11-17-2007, 01:20 PM | #131 |
Member#: 164220
Vehicle:2003 WRX Wagon Blue |
Stock Intake delete???????
Is it wise to take the front air scoop and resonator box leaving the stock box in the engine compartment sucking air directly from the fender well. Its cool air, no water gets in there, and if it does, its high enough, vacuum cant pull it up there.. I was also just goin to throw in a K&N high Flow filter. But would this cause me to run rich? Im pretty sure it doesnt matter cause its just taking everything out before the filter and the MAF Sensor is still goin to be getting the same air flow depending on throttle position. Basically loosing unnecessary air travel, more noise though, saving plastic, and $$$. Why Not????????
11-25-2007, 07:50 AM | #132 |
Member#: 165094
Vehicle:2011 OutBack Sport Sage Green Metallic |
looks lke I'll keep the stock intake but it is a pain to change the element.
11-25-2007, 08:45 AM | #133 |
Member#: 70395
http://forums.nasioc.com/forums/show...&postcount=108
You fail at reading.You will not make power on an intake unless the stock intake system was a restriction in the first place.It all boils down to your power level and the airflow your are moving... |
12-13-2007, 01:42 PM | #134 |
Member#: 166529
APS Cold Air Intake is washable or there are replacement for this filter? Do they sell filter separatly?
04-23-2008, 11:11 PM | #135 |
Member#: 176015
W. Canada
Vehicle:2002 WRX World Rally Blue |
whats the overall opinion on the K&N typhoon CAI? from what i can find it seems its one of the better out there, anyone with bad experiences?
05-06-2008, 07:22 PM | #136 |
Member#: 151991
Vehicle:2003 WRX Silver |
Don't get wrapped around HP
I just want to point out two things here. Unibombers' very first FAQ input said it perfectly. "The primary purpose of an aftermarket intake is to increase the amount of air flow the engine receives". Now focus on the word receives. The next great input came from djviper a whopping 61 posts later! "what it will do however is speed up your spool up and sharpen throttle responce". The faster an engine starts getting air, the faster it can start working. So... if your concern is only for HP numbers or dyno bragging rights, don't bother, because as stated the numbers will not be there. But the numbers don't tell the whole story. You will get benefits like easier/better take off, the bog on a rolling start (for you stop'n'go sign people like me) will be gone, hills where you may have had to downshift and get into higher revs can be taken smoothly in the higher gear. There ARE benefits if you look for a system designed well for the car. BTW, mine is an 03 WRX with the SPT w/heat shield.
05-06-2008, 07:57 PM | #137 | |
Member#: 70395
05-25-2008, 12:16 PM | #138 |
Member#: 63330
Vehicle:2016 Crosstrek Desert Khaki |
What about 2008s? I'm hearing a lot of different stuff about them. A/F seem fine and intakes produce 11 to 20 hp.
05-25-2008, 05:44 PM | #139 |
Big Ron
Super Moderator Member#: 18062
08s are no different, without PROOF vs. "seem fine", using an intake is d u m b.
05-27-2008, 01:41 PM | #140 |
Member#: 63330
Ultimate Racing posted dyno results and said their A/F ratio was well within normal levels.
http://forums.nasioc.com/forums/show....php?t=1360742 Also, some members on various forums have good A/F ratio with their intakes on '08s. That's why I'm kind of wary of what to believe or not. I have an CAI for my 08, but it isn't on the car now, due to my confusion. |
05-27-2008, 02:50 PM | #141 | |
Member#: 157470
South East
Vehicle:08 WRX 4DR WRB |
I beleive they also said in that post that they ran the car with NO TUNE and didnt have any problems. of course getting a tune would definitly help, but it doesnt look like (from the company and other owners) that there would be any problem. There is better things you can purchase for the money, but if you already own it, or want the PSH noise, you will be fine. Last edited by indoubt; 05-27-2008 at 03:07 PM. |
05-28-2008, 02:31 PM | #142 |
Member#: 63330
Already own it, will throw it on purely for the sake of seeing if my MPG increases.
05-28-2008, 03:06 PM | #143 |
Member#: 149059
SWIC
Vehicle:2006 WRX Limited Urban Grey |
+1 Thanks for the great info. I'll stick with my stock intake, it's a good design.
05-28-2008, 03:09 PM | #144 |
Member#: 157470
South East
05-28-2008, 04:48 PM | #145 |
Member#: 34824
SCIC
Vehicle:2008 STI DGM 03 WRX WRB Stage 2 |
05-29-2008, 12:26 AM | #146 |
Member#: 63330
I'm getting about 3MPG more in the city (could be my rims). Midrange power is lost, but high end power is a kick in the arse. I don't think it's "faster", but it definitely rides smoother than normal. Don't feel any anomalies. Will see what happens over the next few days and on the highway. Will have my tuner plug an AF gauge on the car when I take it in for springs and see the data for myself!
09-09-2008, 10:37 AM | #147 |
Member#: 181244
Vehicle:2006 WRX STI Blue |
I read unabombers intake FAQ.. It seems understandable since i know the object is to free up air. All my buddies have been telling me that my car will be running to lean because of that intake. I have posted on the newbie FAQ plus a photo of my car's engine bay since I purchased the car last week. I have the option to take it off or just leave it. Since I still got the stock intake. I know there was a list on the first page which intakes do not affect the car. The problem is I do not know what brand that intake is on the engine until I get my car delivered.
http://forums.nasioc.com/forums/show....php?t=1593628 Edit: I forgot to post but the TurboXS intake install has a dead link |
09-16-2008, 11:50 PM | #148 |
Member#: 186196
Vehicle:05 WRX OBP |
Intake + tune question?
When you say Stock Intake is good for 350 hp do you mean whp?
I have spt intake with heatshield on stage 2 05 wrx. Thinking of going fp big 16g with ebay TMIC and supporting mods. Hoping for 290-300 whp (which will be around 370-380 crank hp i think). Do you think Mead Engineering will want me to put the stock intake back on before the tune? |
09-17-2008, 12:17 PM | #149 |
Big Ron
You need to ask Mead Engineering now, not me. Tuner's advice>>>>>>>anyone on NASIOC's advice.
09-17-2008, 03:02 PM | #150 |
Member#: 186196
ok. Pm sent. thanks
Exhaust FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 318 | 09-06-2021 04:50 PM |
Uppipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 396 | 07-09-2020 02:25 AM |
Pulley FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 120 | 01-29-2020 09:15 AM |
Downpipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 338 | 10-25-2019 12:04 AM |
