Welcome to the North American Subaru Impreza Owners Club Tuesday April 23, 2019
Old 04-07-2019, 05:34 PM   #26
blurred
Member#: 47143
I run water/meth as a safeguard/buffer. AEM, 125cc above 10psi and I think 3500rpm. Using turbo power washer fluid which is 50% methanol, pump mounted near the oem intercooler spray tank in the rear fender and using the oem tank for the fluid.
Personally I'd never trust a meth kit to operate as a secondary fuel system
blurred is offline   Reply With Quote
Old 04-07-2019, 06:01 PM   #27
TurboCarnage
Member#: 477613
2017 Wrx
Wrb
im using mine as a safety measure also. im not looking to get crazy power with it but i want it to keep things safe since im upgrading to a socal v3 turbo. thats why i wanted the map switch. with aem off ill still have fun. but with meth on ill feel much better in higher revs
TurboCarnage is offline   Reply With Quote
Old 04-07-2019, 06:09 PM   #28
PDXREALTOR
Member#: 468393
2017 STI
I used to feel the same way about it, only using as a backup.
But with the (new to me) option to map switch I can't see the risk anymore. Enlighten me.
If the meth flow is hooked up to IDC, and the failsafe is based on a lean AFR, how is it so different from filling up with e-85 one day and e-10 the next?
PDXREALTOR is offline   Reply With Quote
Old 04-08-2019, 02:14 PM   #29
PDXREALTOR
Member#: 468393
2017 STI
Crickets.... Lol
It was a serious question. I can't see what I'm missing but..... That sometimes doesn't mean much.
Old 04-08-2019, 04:31 PM   #30
Delphi
Member#: 239335
Not really different at all.
Only thing is, is coming up with the failsafe based on AFR. That I am not too sure on. A turbine flow meter would be easier to do I think.
If you come up with something that would failsafe on AFR please post it or PM me I would be very interested.
Delphi is offline   Reply With Quote
Old 04-08-2019, 05:30 PM   #31
PDXREALTOR
Member#: 468393
2017 STI
I was thinking flow meter too, but then nurp mentioned reliability issues with his AEM. That got me thinking that there is no failure to AFR beyond a failure that show itself everywhere vs. isolation to the meth system itself.
The AFR failsafe i use is this - Innovate PSB1 https://www.innovatemotorsports.com/products/psb1.php
Manual - https://www.innovatemotorsports.com/...SB1_Manual.pdf
It will need a relay arrangement just like yours as it's setup to cut the boost solenoid on overboost and/or lean AFR.
Old 04-08-2019, 05:37 PM   #32
Delphi
Member#: 239335
Interesting.
I thought about this.
https://sirhclabs.com/product/water-...l-flow-sensor/
I do have this sitting on my bench though.
https://www.amazon.ca/gp/product/B01...?ie=UTF8&psc=1
Old 04-08-2019, 06:07 PM   #33
blurred
Member#: 47143
Originally Posted by PDXREALTOR View Post
Crickets.... Lol
Just compare the hardware, software and sensors you have to run your actual fuel system to the wmi hardware, software and sensors.
I would simply run e30-e40 at your power levels for a level of safety.
Old 04-08-2019, 06:16 PM   #34
PDXREALTOR
Member#: 468393
2017 STI
Interesting.
I came across that first one, and also considered it. The one on Amazon is good find if you could narrow the voltage down to 0-5v (sure there's a way with some know how).
There is also the Snow Perf. flow meter with a boost cut feature https://www.maperformance.com/produc...EaAiUYEALw_wcB
That was kind of my thought process for running an AFR based failsafe. The entire failsafe (ARF gauge) is taking it's reading off all those sensors you mention.
I have no ethanol beyond 10%. I've been using TORCO for ~ 100 octane but 1) it's a waste when cruising, and 2) it's a PITA to measure out 3 oz per gallon at the pump..., especially given we don't pump our own gas here in oregon.
Old 04-08-2019, 08:42 PM   #35
Delphi
Member#: 239335
I think I could.
Max flow (1gpm) would be no Jet and the line just free running. At rest it would be what ever it reads.
Measure the voltage with a DVM and see what it comes in at. Supply voltage would be from the other TGV.
Old 04-08-2019, 09:19 PM   #36
Delphi
Member#: 239335
Another update for you guys. Here is the system functioning!
https://www.instagram.com/p/BwBBnM8F..._web_copy_link
Old 04-08-2019, 09:44 PM   #37
PDXREALTOR
Member#: 468393
2017 STI
That's awesome .... now run that thing WOT and flip the switch.
I ordered my controller today...... right behind you!
Old 04-08-2019, 09:50 PM   #38
Delphi
Member#: 239335
I wish, the weather is so nice out but the dyno day is in May. Plus I have some boost leaks at the injector seals. Got new ones on route. Leaks at 30 psi
Old 04-08-2019, 09:59 PM   #39
PDXREALTOR
Member#: 468393
2017 STI
It's going to be a long month. Injector Dynamics o-rings?
How, or where, are you doing the boost leak test at? Do you rotate the engine so all the valves are closed?
Old 04-08-2019, 10:22 PM   #40
Delphi
Member#: 239335
Going to be a crazy long month, good thing I am busy until then mostly
Just on the coupler off the turbo. I didn't worry about rotating the motor off since my air compressor can keep up. I just spray soapy water at every connection on the car.
And yes ID o-rings. Getting new OEM ones.
Old 04-08-2019, 10:32 PM   #41
PDXREALTOR
Member#: 468393
2017 STI
do your ID have those little aluminum buckets that sit in the rails?
Mine are the ID 1300s and they have the buckets with super thin o-rings. those pop in the tgv housing and always pinch. I suggested ID include some spares given they are an odd size and likely a viton .... frustrating.
I need to boost test mine.
Old 04-08-2019, 10:52 PM   #42
Delphi
Member#: 239335
No my are OG ID1000's so I dont have the caps, uses oem style orings.
Old 04-08-2019, 11:13 PM   #43
PDXREALTOR
Member#: 468393
2017 STI
Lucky...
Old 04-15-2019, 10:52 PM   #44
Nurp
Member#: 383782
2014 WRX STi ST
I think I had 3 issues with my AEM Flow Gauge.
1. always read 250cc/l more than the rated nozzle. Sent back to AEM and they said it was working fine so no idea what was going on.
2. had a slight leak from the sensor after about a year but I put some teflon tape around the threads and never had a leak after.
3. would not turn on when very cold. This was usually around -25 to -30 degrees celsius. If it doesn't get that cold where you are then you probably won't have the same issue.
Nurp is offline   Reply With Quote
