Welcome to the North American Subaru Impreza Owners Club Thursday August 13, 2020
Go Back   NASIOC > NASIOC Subaru Models > Tribeca Forum
Old 07-08-2020, 02:51 PM   #1
Draken04
Member#: 131657
2004 Impreza WRX Wag
Default 2008 Tribeca steering wheel shake
Ok, bought my wife a Tribeca to replace her worn out Forester that had gotten to small for the family, and we couldn't afford the Ascent she wanted.
It had mismatched tires on it so scheduled a trip to Tire Rack to get new rubber put on, but found it had a severely bent rim, so ended up with new rims as well.
From day one it had a minor shake in the steering wheel, and after having gone over the front end before we bought it, I just figured it was due to a tire issue because they were worn, so I wasn't worried about it. Putting the new tires on did lessen the shake, and how often it happens, but it is not gone.
Had the front end in the air, checked tie rods, ball joints, all bushings are OK (rear on the lower control arms show wear, but not a worrying amount), steering feels very tight with no slop. I have replaced the front struts in case one was bound slightly (we believe it had hit a curb at one point) and did a normal brake job on the front, new pads and rotors.
Taking it on the road, it will be smooth as glass up to speed. Sometimes taping the break will make the shaking start, sometimes turning will make it start, but it will stay for a while regardless, then just disappear and back to being a very smooth ride. It can happen at 5mph or can happen at highway speeds, and the shaking is always about the same amount.
We did take it into a shop, they checked the alignment and said that was good, they were able to replicate it on a test drive, but were unable to find anything as a smoking gun either.
This. Has. Me. Baffled.
Any ideas on stuff I may have missed?
Draken04 is offline   Reply With Quote
Old 07-13-2020, 12:06 PM   #2
kos
Member#: 118334
2006 Red GDA-F
2005 Aspen White GDA-E
Wheel bearings maybe? I know you said it's smooth at speed, but maybe a bearing is just starting to wear out? Does seem odd...
kos is offline   Reply With Quote
Old 07-13-2020, 03:25 PM   #3
Draken04
Member#: 131657
Bearings felt good when I checked them (not saying it's not possible). Bearings are ~$100ish so I may just replace them to rule them out.
The part that is most odd to me is that when it is there, it's the same at any speed, but when its not there, it's smooth as glass at all speeds.
Old 07-14-2020, 09:01 AM   #4
Sub!eDr!ver
Member#: 88924
2014 Cadenza, Sedona
Past: Tribeca LGTx2 Justy
Could it be something in the power steering? Maybe a sensor going bad or possibly even the power steering pump.
Sub!eDr!ver is offline   Reply With Quote
Old 07-14-2020, 10:21 AM   #5
Draken04
Member#: 131657
Will have to look into what sensor it could be, part of me is leaning towards the rack having an issue. Not sure how a pump could cause it, but can look at it and see if I see anything odd..
Old 07-14-2020, 08:40 PM   #6
rjd_sti
Member#: 103426
2005 WRX STI
Obsidian Black Pearl
Have you checked both driver and passenger side lower control arms? both of mine were worn down after 230k miles and i would get wheel shudder every time I came to a stop and again when I let off the brake pedal. You can see the wheel shimmy if you are viewing it from outside. I replaced both LCA's and that solved my problem. I also got the dreaded knocking noise whenever going over any bumps or uneven surfaces on my right side.
What year and mileage is your wife's Tribeca?
rjd_sti is offline   Reply With Quote
Old 07-15-2020, 12:09 AM   #7
Draken04
Member#: 131657
It's an 08, and mileage on odo is 129k, but it was imported from CA so was replaced, and have no clue what it really is.
the LCAs overall look good, no bends or wrinkles in them, and the only thing I see as an issue is there is a small amount of cracking in the rear bushing. When we were at Tire Rack looked at them with it in the air, and again when I did the struts.
It's going in the air again this weekend (well jack stands) and going to be going over it with a fine tooth comb.
