Welcome to the North American Subaru Impreza Owners Club Thursday August 13, 2020
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 07-22-2020, 12:52 PM   #1
dneve85
Member#: 493759
Default AF Correction Spikes
So I was on an OTS tune for about a year and would notice my AF Correction 1 values jump back and forth by ~10%. This would happen while cruising with 5-10% throttle on level pavement. For example, it would drop to -10, then flash back to 0 and do so until throttle position changed or the surface of the road changed.
Fast forward to 2 weeks a go. I installed additional parts on the car and brought it into a local performance shop to do a smoke test and pressurized boost leak test. While they found a couple small leaks and fixed them, the issue is still happening. Currently I am going through an E-tune process and as most of you know, questions and then answers can take a day to hear back. So i am trying to be proactive and see if anyone here can point me to what might be going on. I did notice water in the air box about a year a go, could that have caused the MAF to have issues?
MAF and MAP sensors have been cleaned, problem still occured.
I have logs if you would like to see them.
Thanks!
dneve85 is offline   Reply With Quote
Old 07-22-2020, 01:44 PM   #2
dpetro1
Member#: 487500
2018 WRX
I would say that +/- 10% is fairly normal especially for an OTS tune.
See where things land once the custom tune is done. While cruising +/- 5% is really spot on.
dpetro1 is offline   Reply With Quote
Old 07-22-2020, 01:56 PM   #3
dneve85
Member#: 493759
Disregard this reply
Old 07-22-2020, 04:30 PM   #4
dneve85
Member#: 493759
I don't think I was very clear. So with steady throttle, no change in load, AF correction bounces around by 10% until load changes. So going 55mph with steady throttle on a level surface, my AF Correction goes from -6 to 4 to -6 to 4 to -6 to 4, etc. or 20 to 10 to 20 to 10 etc. So while my sustained values are w/in the recommended parameters, this jumping around shouldn't be happening.
Old 07-22-2020, 04:35 PM   #5
dpetro1
Member#: 487500
2018 WRX
Ahh, I see
Does this just happen for a few seconds a few minutes into your trip? My car does this, tuner told me this normal behavior, some type of o2 sensor check.
If it's doing it the entire drive then there could be an issue.
Good ole anxiety port...
Old 07-22-2020, 04:42 PM   #6
dneve85
Member#: 493759
Ahh, I see
I can make it last as long as the road stays level and my foot is at the same throttle position. Doesn't seem like normal behavior to me. I can feel the fuel cutting in and out.
Old 07-22-2020, 04:43 PM   #7
dpetro1
Member#: 487500
2018 WRX
I would mention it to your tuner. Take a log of the problem to send as well.
Old 07-22-2020, 04:51 PM   #8
dneve85
Member#: 493759
I have, and we are trying to troubleshoot it. I just wanted to reach out to the forum to see if anyone else has experienced this and if they know what it was caused by.
Old 07-23-2020, 12:50 PM   #9
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
If you have an aftermarket intake, check the wiring harness extension for the MAF.
These can go bad and cause erratic behavior
gn4rwhals is offline   Reply With Quote
Old 07-23-2020, 09:05 PM   #10
tegxsi
Member#: 446029
AF correction1 is a short term fuel trim (STFT)... it's usually all over the place especially with sudden throttle changes. What you are seeing isn't out of the ordinary.
tegxsi is offline   Reply With Quote
Old 07-24-2020, 09:12 AM   #11
dneve85
Member#: 493759
I disagree with you. Can you replicate this behavior? If it's normal, why is my tuner perplexed by it and trying to troubleshoot it? It shouldn't be jumping around by exactly 10.16 every time when there is no change in the load.
Old 07-24-2020, 09:13 AM   #12
dneve85
Member#: 493759
I am having the issue using a speed density tune too, so idk how the MAF cable would effect that.
Old 07-24-2020, 09:43 AM   #13
Rexy18
Member#: 500337
So the issue is either mechanical (car related) or tune (tuner related). You say it isnt the tune so then its your car. I would assume its the tune, and that oscillation by 10% or more happens only upon certain load/throttle request/input. Trims are adjusting because youre teetering between two cells and your tuner needs to fine tune it after he finds it.
I am tuned too and i noticed same behavior but ONLY upon very light throttle (output—so letting go of the pedal to a point the holding). It only happens sometimes when i hit the right cells and ecu adjusts accordingly. I think this happens when there is a change of load based on light throttle input, at least in my scenario. So yes, i would agree with texgsi that it is “normal “ behavior. I dont feel anything except my eyes seeing 0% then 10.17% then 0% and so on for 2-5 cycles.
Rexy18 is offline   Reply With Quote
Old 07-24-2020, 10:07 AM   #14
dneve85
Member#: 493759
I am tuned too and i noticed same behavior but ONLY upon very light throttle (outputóso letting go of the pedal to a point the holding). It only happens sometimes when i hit the right cells and ecu adjusts accordingly. I think this happens when there is a change of load based on light throttle input, at least in my scenario. So yes, i would agree with texgsi that it is ďnormal ď behavior. I dont feel anything except my eyes seeing 0% then 10.17% then 0% and so on for 2-5 cycles.
I have seen the issue before with the MAPerformance OTS tunes. Maybe it is just something with the Subie ECU. Happy to hear someone else is experiencing this. I will pass this information on to my tuner. Thanks for the input.
Old 07-24-2020, 11:10 AM   #15
alapilusa
Member#: 424692
2015 WRX
This has been happening to me for probably 3 years and 80,000+ miles. Usually happens within the first few minutes of my drive, but will happen rarely further into my drive. Only at very light load. I've come to ignore it over time. Has no real effect on drivability/performance, and clearly it has no issues with reliability or else I would have had serious problems by now. Its something with either the ECU specifically, or a sensor warming up/calibrating over time.
alapilusa is offline   Reply With Quote
Old 07-24-2020, 11:12 AM   #16
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
If I understand correctly we are all seeing this:
https://datazap.me/u/gn4rwhals/weird...ata=1-2-3-7-21
Old 07-24-2020, 11:44 AM   #17
alapilusa
Member#: 424692
2015 WRX
Not exactly. There is no step up/down between changes. It just fluctuates directly between 2 values at just about 10 apart. For instance - +5, -5, +5, -5 with no values in the middle. If I remember to pay attention when I drive this weekend, i'll try to grab a log of it and post it.
Old 07-24-2020, 02:23 PM   #18
Rexy18
Member#: 500337
Sounds about right, about 10% swing back and forth a few times.
Old 07-24-2020, 02:55 PM   #19
dpetro1
Member#: 487500
2018 WRX
This is what i was mentioning in an earlier post. Tuner told me its normal so I moved on with my life.
Old 07-24-2020, 03:03 PM   #20
dpetro1
Member#: 487500
2018 WRX
Wait, why do we have two threads on this now? I can't follow...
Old 07-26-2020, 01:17 AM   #21
keehs
Member#: 517038
Plus or minus 10 seems normal for an ots tbh
At least from what Iíve seen. Log it against tgv activity, does anything correlate there?
keehs is offline   Reply With Quote
Old 07-27-2020, 10:52 AM   #22
dneve85
Member#: 493759
You can see what I am talking about in the beginning and end of the log. It jumps around by a variable of 10.16 with no change in acceleration or load. https://datazap.me/u/dneve85/log-159...data=1-8-11-21
Old 07-27-2020, 12:51 PM   #23
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
That is really odd, I see that its actually adding fuel when it doesn't need it.
Zoomed in: https://datazap.me/u/dneve85/log-159...zoom=7199-7662
Old 08-01-2020, 11:20 PM   #24
emu1342
Member#: 419426
2015 WRX
Thatís so bizarre. My WRX does something similar. I wonder if itís a bad O2 sensor. Weird thing is, the car runs great unless I use cruise control. Thatís when AF numbers go crazy
emu1342 is offline   Reply With Quote
Old 08-06-2020, 12:02 PM   #25
dneve85
Member#: 493759
That is exactly what is happening to me now. AF Learning jumps to -20 while using cruise control. No clue what the hell is going on. Hoping my tuner can work his magic.
