12-04-2018, 10:56 PM | #1 |
Member#: 494860
Vehicle:2011 Impreza 2.5i Pearl White |
Tow Strap Installation HELP
Hey guys,
I'm the owner of a 2011 Subaru Impreza and have had a tow hook on my car for a while now. I really like the look of the Sparco tow straps but am not sure if there's an easy way to install them (I'm not looking to actually use it). I've seen people use really long screws and pieces of threaded rod, but I feel like there has to be a better way to do this aside from removing my bumper to get at it. Any and all comments are appreciated, thanks guys.
12-05-2018, 09:10 AM | #2 |
Member#: 265783
RMIC
Vehicle:2017 Forester XT Niner ROS 9 |
why? does it break down all the time? you really shouldn't be towing a subaru; you need a flatbed truck installed on your bumper instead. much trend! so car racing car!
12-05-2018, 09:32 AM | #3 |
Member#: 488722
Vehicle:2000 2.5rs w/EJ20K & (now) 3 other GCs |
Sounds like he just wants it for the looks...
Personally I'd say save your money and don't bother, but if you really just want it for the looks, find something to zip tie it to behind the bumper and let it hang useless in the wind. |
12-05-2018, 12:19 PM | #4 |
Newbie Moderator
Moderator Member#: 91347
Vehicle:2004 Tacoma Crew Cab 2012 Triumph 1050 |
Why do you need to remove the bumper?
http://store.ijdmtoy.com/Track-Racin...7g&click=12691 Don't you just pop that piece out and thread it in? |
12-05-2018, 12:54 PM | #5 |
Member#: 494860
Clearly you weren't listening when I said I want it strictly for looks...
12-05-2018, 12:55 PM | #6 | |
Member#: 494860
Honestly this may be the only way to do it, thanks for the advice brother. |
12-05-2018, 01:06 PM | #7 | |
Member#: 488722
12-05-2018, 01:08 PM | #8 | |
Member#: 488722
Don't really see an issue with it if it's truly just for looks. Can't say I agree with it, but hey at least you're not trying to convince yourself or others that you NEED it for some other reason besides looks. |
12-05-2018, 01:28 PM | #9 | |
Member#: 494860
almost everything that I have on my car aside from the exhaust system is purely for aesthetics. At the end of the day it’s only a 2.5i ***128546; Thanks for your advice broski |
12-05-2018, 08:08 PM | #10 |
Member#: 494860
Yellow Zinc Bolt in Tow Strap Hole
So I asked around and it seems like the best way to install the tow strap that I want is with a hex cap screw.
I work at a fastener distributor and even we don't sell the bolt that I need (M16 x 1.5 x 120-130mm S/S). Unfortunately the closest that I can get to Stainless Steel is yellow zinc. Yellow Zinc will rust over time, I'm just curious if it puts my car at risk of rusting quicker/will the bolt get stuck or corrode from being screwed in with outside weather conditions. THANK-YOU IN ADVANCE |
12-05-2018, 08:09 PM | #11 |
Member#: 494860
In addition to this,
I'm definitely willing to swap out bolts with a new one every six months or so seeing as I can get them for a couple dollars each. |
12-07-2018, 04:52 PM | #12 |
Member#: 488722
Idk man, zipties don't rust.......
If you're really worried about whatever bolt you're gonna put in there rusting, just glob on about an entire bottle of anti sieze on the threads and it'll outlast the car itself. |
12-07-2018, 11:18 PM | #13 | |
Member#: 494860
thanks once again broooo ***128076; |
