Welcome to the North American Subaru Impreza Owners Club Sunday July 22, 2018
Old 07-21-2010, 02:30 PM   #1
njdriver04
Member#: 248747
04' SG XT
Blk
Default Advice for future 4 Gen Full STI Swap
I am in the beginning stage of planning for a full sti swap into a 4 gen legacy/outback wagon 05-06. Looking at salvage outbacks wagons and legacy wagons. I was wondering if I will run into any issues swapping if i decide to go with the outback wagon,. I know they are heavier due to the additional options. Any other issues? Originally i planned to do the swap on my 2000 but i realized it was not worth it.
njdriver04 is offline   Reply With Quote
Old 07-21-2010, 03:39 PM   #2
girodisc
Member#: 177674
You going to just do the motor swap or you buying a wreaked STi so you get everything. If you going for a whole Sti get a 08-09. It will cost more but then you can use all the suspension goodies because they share the same setup.
There shouldn't be an issue with an outback over any other legacy model. If you are doing the tranny swap find a car that's a manual too unless you are swapping the harnesses as well. Converting a Automatic Harness to work correctly with a manual is a PITA.
Buy one with an h6 in it and all buy your motor and crap haha.
Johann @ Girodisc
girodisc is offline   Reply With Quote
Old 07-21-2010, 06:02 PM   #3
jamal
Member#: 71875
No, just buy a turbo legacy or outback. Then all you really need is the 6-speed stuff and a bigger turbo
Also the rear suspenion between the 4th gen legacy and an 08+ impreza is not the same.
jamal is offline   Reply With Quote
Old 07-22-2010, 01:47 AM   #4
njdriver04
Member#: 248747
04' SG XT
Blk
yeah i though 05 on legacy would be a direct swap 06 07impreza
Old 07-26-2010, 05:43 AM   #5
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
The 05/06 LGT already has the STI shortblock.
If you're going to swap turbos, do something bigger than a VF39.
Old 07-26-2010, 09:54 AM   #6
that one legacy
Member#: 103665
+1 to ^
i know a guy with an 05 LGT, he swapped on STi heads and an STi intake manifold and that's all he needed because the rest (engine wise) is the same.
as far as Outback vs Legacy, the only real difference is the height of the suspension. everything else should be very similar.
that one legacy is offline   Reply With Quote
Old 07-26-2010, 12:27 PM   #7
PA-Outback2000
Member#: 161832
2000 Outback Limited
y not swap in a 2000? i will be doing close to that soon.
PA-Outback2000 is offline   Reply With Quote
Old 08-02-2010, 04:45 PM   #8
njdriver04
Member#: 248747
04' SG XT
Blk
rear suspension is different, i blew the head gasket today, so i will change it and move on to something else
Old 08-03-2010, 09:05 AM   #9
PA-Outback2000
Member#: 161832
what does suspension have to do with which generation you swap to?
Old 08-03-2010, 10:36 AM   #10
rougeben83
Member#: 115154
2005 Outback XT
White on grey
If you think it's not worth it in an older, cheaper model, then its certainly not worth it in one thats more expensive, newer, and already came available with an STI-block from the factory
rougeben83 is offline   Reply With Quote
01 2.5RS ANY IDEAS FOR A FULL STi SWAP?? RyanBec Newbies & FAQs 14 10-27-2009 12:08 AM
Advice for future fobbit in Iraq aggie113 Texas Impreza Club Forum -- TXIC 9 07-20-2009 04:31 AM
Arcadia Green 2.5rs with FULL STi swap. For real this time! :( MattD87 Private 'Wanted' Classifieds 113 06-25-2009 07:16 PM
FS: 2002/2005 WRX/STI - Full STI Swap w/ FAT 30R Turbo Kit dcheyne55 SWIC Private Classifieds 6 05-17-2009 11:11 PM
Anyone looking for a full sti swap? snowcrzy SCIC Private Classifieds 14 02-25-2008 02:13 AM
