Welcome to the North American Subaru Impreza Owners Club Saturday September 22, 2018
Old 10-20-2017, 03:58 PM   #1
Baulde
Member#: 220923
Default 02 Outback Hard/delayed shift from 2nd to 3rd and rpm surge
Just started happening: 2002 outback auto, shifts hard and delayed when shifting 2nd-3rd.
Transmission will drop out of gear rev's jump up to 3k or more with a decent delay that allows the RPM's to climb and then grabs/slams into the next gear at high RPM.
Not finding much for direction on google. Any transmission information that someone has exp with? I have read could be TPS or a solenoid. Have topped up fluid, anyone know of a troubleshooting guide? Looking for information on which solenoid is used for the 2-3 shift and how to test/inspect it.
Can one replace said solenoid without replacing the entire valve body?
Or could the delay/surge be cause by some junk in there and a good flush could fix it up?
Baulde is offline   Reply With Quote
Old 10-30-2017, 06:05 PM   #2
Baulde
Member#: 220923
Well transmission shop diagnosed it as a bad clutch pack. Said all electronics were fine. But did this without dropping the pan. Not worth the cost of the car to pay for a rebuild.
I have a transmission from a 1999 Legacy GT, was pulled working for a 5 speed swap. Case is painted black(Possibly already rebuilt?). It has a spin on filter on the side same as the outback so should be the correct generation.
Can anyone confirm final drive on both of these transmissions as 4.11? Any thing else to consider before I swap these?
