Welcome to the North American Subaru Impreza Owners Club Monday June 25, 2018
Old 05-18-2005, 03:59 PM   #26
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
dave got me thinking that something was up, but all the data i can see from previous users points to there being 500 to 700 rpms of difference td04 to vf23. for example, the old dyno plots by shiv (from http://forums.nasioc.com/forums/show...highlight=vf23):
also this one (from http://forums.nasioc.com/forums/show...ight=vf23+vf30) which shows it really coming onto a boil at 4k:
also from http://forums.nasioc.com/forums/show...03&postcount=7
Originally Posted by typec
btw, I've personally seen 15psi @3400 on a VF23 equipped car in 4th gear.
from http://www.mrtrally.com.au/forums/to...p?TOPIC_ID=841
My testing has found after the TDO4
+500rpm lag on VF24/28
+600rpm lag on VF29
+650~700rpm lag on VF34
+800rpm lag on VF23/30
+900rpm lag on VF22
from http://forums.nasioc.com/forums/show...5&postcount=26
Originally Posted by turboxs
Stock: 2890 (w/ catless UP)
FP: 3270
VF30: 3390
VF23: 3470
VF22: 3630
1818: 3760
1820: 3975
so i don't think there's too much wrong here....
ken
Old 05-18-2005, 05:30 PM   #27
scoobie1
Member#: 41559
2007 Brocoma
Okay, so I did a pull on the way home and I was wrong...full boost at 2700 rpm, not 2500. I bought my turbo used, and pretty sure it hasn't been pnp.
scoobie1 is offline   Reply With Quote
Old 05-18-2005, 05:37 PM   #28
TheMadScientist
Member#: 23717
2005 Big red
What gear?
TMS
TheMadScientist is offline   Reply With Quote
Old 05-18-2005, 07:39 PM   #29
scoobie1
Member#: 41559
2007 Brocoma
Originally Posted by TheMadScientist
What gear?
TMS
2nd, traffic was backed up so I couldn't get enough room to crank it up in 3rd, I'll try again later tonight.
Old 05-18-2005, 09:03 PM   #30
jrlandsman
Member#: 79668
i have a vf23 on my car tuned by turboxs and i dont hit 20 psi at all and my boost level on my utec is 400 this seems weird that you claim 20 psi and then 18, i max at about 18 and never hit 20 unless its really cold like winter time anyone else?
jrlandsman is offline   Reply With Quote
Old 05-19-2005, 09:22 AM   #31
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
jr, i also have a totally custom boost control setup: ball+spring MBC and utec-controlled GM solenoid in parallel.
scoobie1, do you have some kind of datalogging capability? eyeballing gauges while driving/shifting has proven very inaccurate in my experience. as a result all of my numbers are directly from utec logs.
ken
Old 05-19-2005, 04:11 PM   #32
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Old 05-19-2005, 05:59 PM   #33
scoobie1
Member#: 41559
2007 Brocoma
ken
Yeah, I'll plug into the UTEC and see what it says after I get back from Washington this weekend.
Old 09-17-2005, 03:29 PM   #34
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
5th gear pull, 1 bar @ 3075rpms, 20psi by 3280.
Code:
 2622,-11.0,2.0,  7, 00,   00,  W/B ,+31.3,   6.0,ECU. , -4.8,ECU.  ,2.0, 17.43
 2622, -9.0,2.8, 67, 10,   00,  W/B ,+33.1,  13.0,ECU. , -0.2, 97.10,2.7, 15.80
 2643, -6.3,2.6, 98, 10,   00,  W/B ,+31.5,  13.9,ECU. , -0.2,WGS.  ,2.6, 15.08
 2686, -3.0,2.8,101, 10,   00,  W/B ,+29.1,  14.9,ECU. , -0.2,WGS.  ,2.7, 15.08
 2686, +0.0,2.8,101, 10,   00,  W/B ,+28.1,  15.9,ECU. , -0.2,WGS.  ,2.8, 15.37
 2662, +1.7,2.8,101, 20,   00,  W/B ,+26.7,  17.5,+30.5, +0.1,WGS.  ,2.8, 15.02
 2721, +2.7,2.8,101, 20,   00,  W/B ,+24.3,  18.1,+30.0, +0.1,WGS.  ,2.8, 14.65
 2707, +3.5,2.9,101, 20,   00,  W/B ,+23.1,  19.7,+29.1, -0.1,WGS.  ,2.9, 14.30
 2738, +4.3,2.9,101, 30,   00,  W/B ,+21.8,  19.8,+28.5, -0.4,WGS.  ,3.0, 14.22
 2784, +5.1,3.0,101, 30,   00,  W/B ,+20.4,  21.5,+27.5, -0.4,WGS.  ,3.0, 14.22
 2791, +5.9,3.0,101, 30,   00,  W/B ,+19.3,  22.5,+26.9, -0.4,WGS.  ,3.0, 14.15
 2801, +6.5,3.1,101, 40,   00,  W/B ,+18.6,  22.8,+26.4, -0.2,WGS.  ,3.0, 14.11
 2815, +7.4,3.0,101, 40,   00,  W/B ,+18.6,  23.7,+25.6, -0.2,WGS.  ,3.1, 14.22
 2863, +8.0,3.1,101, 40,   00,  W/B ,+17.9,  25.5,+24.7, -0.2,100.00,3.1, 14.25
 2893, +8.8,3.1,101, 50,   00,  W/B ,+17.1,  25.8,+24.2, -0.3,100.00,3.2, 14.08
 2841, +9.6,3.2,101, 50,   00,  W/B ,+16.4,  26.9,+23.6, -0.3,100.00,3.3, 13.95
 2944,+10.2,3.3,101, 50,   00,  W/B ,+15.8,  29.2,+22.7, -0.3,100.00,3.2, 13.84
 2923,+11.0,3.3,101, 60,   00,  W/B ,+15.3,  32.3,+22.1, +1.7,100.00,3.4, 13.72
 2981,+11.6,3.4,101, 60,   00,  W/B ,+12.6,  35.7,+21.6, +1.8,100.00,3.4, 13.42
 3027,+12.7,3.5,101, 60,   00,  W/B ,+12.1,  37.4,+20.7, +1.8,100.00,3.5, 12.86
 3038,+13.5,3.5,101, 70,   00,  W/B ,+12.0,  41.1,+19.8, +2.5,100.00,3.6, 12.49
 3058,+14.5,3.5,101, 70,   00,  W/B ,+12.2,  41.9,+19.1, +2.6,100.00,3.6, 12.37
 3115,+15.7,3.5,101, 80,   00,  W/B ,+12.2,  46.9,+17.9, +3.6,100.00,3.7, 12.17
 3052,+17.2,3.6,101, 90,   00,  W/B ,+12.3,  49.3,+16.9, +4.4,100.00,3.8, 12.05
 3144,+18.2,3.7,101, 90,   00,  W/B ,+12.1,  49.5,+16.0, +4.5,100.00,3.8, 11.89
 3124,+19.2,3.6,101, 90,   00,  W/B ,+12.2,  50.0,+15.4, +4.5,100.00,3.8, 11.53
 3280,+20.2,3.6,101,100,   00,  W/B ,+12.2,  54.1,+15.1, +4.4,100.00,3.8, 11.37
 3226,+20.6,3.6, 72,100,   00,  W/B ,+12.2,  58.6,+15.0, +5.2, 96.50,3.8, 11.20
 3300,+20.8,3.5, 32,100,   00,  W/B ,+11.8,  39.3,ECU. , +5.3,ECU.  ,3.3, 11.01
 3313,+18.2,2.8, 11, 00,   00,  W/B ,+29.7,  12.4,ECU. , -5.0,ECU.  ,2.5, 10.96
 3293,+12.1,2.7,  0, 00,   00,  W/B ,+30.6,  15.2,ECU. , -5.0,ECU.  ,2.8, 11.61
 3287, +5.5,2.2,  0, 00,   00,  W/B ,+21.4,  13.3,ECU. , -5.0,ECU.  ,2.6, 11.02
also hit 4.5mafv today... first time ever! see http://forums.nasioc.com/forums/show...0&postcount=33
i'm very pleased with the "old tech" vf23.
edit: 9/26/05 added following log, w/string of 4.5v mafv. suspect 4.6v will come this winter... this pull was ~60* F.
Code:
4182,-12.6,1.7,  0, 00,   00,  W/B ,+11.2,   6.1,ECU. , -4.3,ECU.  ,1.6, >25:1
 4177,-12.4,1.9,  4, 00,   00,  W/B ,+24.7,  10.2,ECU. , -4.3,ECU.  ,2.0, >25:1
 4230,-11.8,2.2,  7, 00,   00,  W/B ,+42.0,   8.9,ECU. , -4.3,ECU.  ,2.1, >25:1
 4166,-10.8,2.5, 13, 00,   00,  W/B ,+41.2,  14.6,ECU. , -4.3,ECU.  ,2.5, >25:1
 4156, -9.2,2.6, 14, 00,   00,  W/B ,+39.3,  14.1,ECU. , -4.3,ECU.  ,2.5, 16.53
 4192, -7.9,2.5, 13, 00,   00,  W/B ,+41.7,  14.6,ECU. , -4.3,ECU.  ,2.4, 14.45
 4208, -6.7,2.6, 13, 00,   00,  W/B ,+41.4,  14.2,ECU. , -4.3,ECU.  ,2.5, 14.22
 4219, -5.3,3.1, 32, 00,   00,  W/B ,+27.7,  25.5,ECU. , -4.3,ECU.  ,3.1, 14.58
 4323, -2.8,3.4, 52, 00,   00,  W/B ,+25.6,  28.3,ECU. , -4.3,ECU.  ,3.4, 15.08
 4380, +0.8,3.8, 82, 30,   00,  W/B ,+16.3,  49.7,+18.2, -2.3,WGS.  ,3.8, 13.81
 4492, +5.9,4.1,100, 50,   00,  W/B ,+13.7,  70.0,+16.7, -2.0,100.00,4.1, 13.28
 4572,+11.9,4.2,100, 80,   00,  W/B ,+14.4,  77.4,+15.0, -0.8,100.00,4.2, 13.53
 4694,+17.0,4.2,100,100,   00,  W/B ,+15.2,  83.6,+14.6, +0.5,100.00,4.2, 13.02
 4823,+20.0,4.3,100,100,   00,  W/B ,+16.6,  90.6,+15.3, +0.0,100.00,4.3, 12.34
 5012,+21.8,4.3,100,100,   00,  W/B ,+17.3,  89.8,+16.0, -0.1,100.00,4.3, 11.77
 5120,+21.6,4.3,100,100,   00,  W/B ,+13.8,  93.8,+16.1, -0.1,100.00,4.3, 11.53
 5265,+20.8,4.4,101,100,   00,  W/B ,+14.9,  95.9,+17.0, +0.1,100.00,4.3, 11.49
 5376,+20.4,4.4,100, 90,   00,  W/B ,+15.2,  95.4,+17.4, -0.5,100.00,4.4, 11.49
 5464,+21.2,4.4,100,100,   00,  W/B ,+16.2,  95.2,+17.0, +0.2,100.00,4.4, 11.53
 5668,+21.6,4.4,100,100,   00,  W/B ,+16.1,  99.0,+17.8, +0.2,100.00,4.4, 11.49
 5707,+21.8,4.4,100,100,   00,  W/B ,+16.6, ---.-,+17.9, +0.0,100.00,4.4, 11.28
 5807,+21.6,4.5,100, 90,   00,  W/B ,+16.9,  97.1,+19.0, -0.9,100.00,4.4, 11.17
 5984,+21.2,4.5,100,100,   00,  W/B ,+17.3, ---.-,+18.8, -0.1,100.00,4.4, 11.14
 6082,+21.2,4.5,100,100,   00,  W/B ,+17.6, ---.-,+19.6, -0.3,100.00,4.4, 11.23
 6093,+21.4,4.5,100,100,   00,  W/B ,+17.6, ---.-,+19.8, -0.3,100.00,4.5, 11.18
 6195,+22.3,4.5,100,100,   00,  W/B ,+18.4, ---.-,+19.8, -0.4,100.00,4.5, 11.14
 6361,+21.4,4.5,100,100,   00,  W/B ,+21.3, ---.-,+20.2, -0.4,100.00,4.5, 11.18
 6385,+20.8,4.5,100, 90,   00,  W/B ,+21.4, ---.-,+21.0, -1.2,100.00,4.4, 11.24
 6680,+19.8,4.5,100, 90,   00,  W/B ,+22.3, ---.-,+22.0, -1.1,100.00,4.4, 11.28
 6561,+19.2,4.5,100, 90,   00,  W/B ,+22.7, 100.0,+23.3, -1.1,100.00,4.4, 11.28
 6447,+14.1,2.7,  0, 40,   00,  W/B ,+10.7,  11.3,ECU. , -3.1,LCM.  ,2.1, 11.61
 5747, +7.0,2.2,  0, 10,   00,  W/B ,+10.7,  10.2,ECU. , -4.0,LCM.  ,2.1, 13.65
 5184, -0.2,2.2,  0, 10,   00,  W/B ,+11.1,  10.6,ECU. , -3.3,ECU.  ,2.1, 22.91
 4894, -7.5,2.2,  0, 10,   00,  W/B ,+11.3,   9.8,ECU. , -3.5,ECU.  ,2.1, >25:1
 4591, -9.8,2.1,  0, 00,   00,  W/B ,+11.1,  23.5,ECU. , -4.3,ECU.  ,2.0, 20.18
Old 09-30-2005, 05:18 PM   #35
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
oh, a nice 40* morning makes me so happy!
Code:
 2165, -8.8,2.1,  8, 00,   00,  W/B ,+17.1,   7.2,ECU. , -4.3,ECU.  ,2.0, 14.61
 2150, -7.3,2.1,  8, 00,   00,  W/B ,+35.6,   7.3,ECU. , -4.3,ECU.  ,2.1, 14.22
 2364, -5.9,2.3, 12, 00,   00,  W/B ,+36.4,   9.2,ECU. , -4.3,ECU.  ,2.2, 14.45
 2456, -5.1,2.3, 13, 00,   00,  W/B ,+37.0,  10.4,ECU. , -4.3,ECU.  ,2.2, 15.02
 2632, -4.3,2.5, 16, 00,   00,  W/B ,+34.9,  14.1,ECU. , -4.3,ECU.  ,2.4, 15.02
 2871, -3.4,2.7, 24, 00,   00,  W/B ,+33.1,  15.3,ECU. , -4.3,ECU.  ,2.6, 14.65
 3124, -2.0,2.9, 32, 00,   00,  W/B ,+32.1,  18.2,ECU. , -4.3,ECU.  ,2.8, 14.58
 3411, -0.6,3.0, 38, 00,   00,  W/B ,+31.2,  10.0,ECU. , -4.3,ECU.  ,3.0, 14.45
 3716, +1.4,3.3, 60, 20,   00,  W/B ,+28.5,  25.3,+26.4, -2.2, 74.70,3.3, 14.18
 4151, +3.7,3.6,100, 30,   00,  W/B ,+16.8,  42.8,+17.8, -1.5,WGS.  ,3.8, 14.65
 4741, +7.4,4.1,101, 50,   00,  W/B ,+14.7,  68.9,+17.2, -2.1,100.00,4.2, 15.12
 5659,+12.1,4.5,100, 80,   00,  W/B ,+17.1,  89.6,+19.7, -1.5,100.00,4.4, 14.30
 6587,+15.5,4.5,100, 90,   00,  W/B ,+22.2, ---.-,+23.1, -1.8,100.00,4.4, 13.50
 6915,+18.4,4.6,100, 90,   00,  W/B ,+23.5,  97.5,+25.9, -1.9,100.00,4.4, 12.52
 6706,+19.6,4.5,101, 90,   00,  W/B ,+23.2,  91.0,+21.5, -1.8,LCM.  ,4.3, 12.25
 5797,+18.6,4.3,101, 90,   00,  W/B ,+17.1,  86.3,+19.0, -0.6,LCM.  ,4.2, 21.40
 4852,+18.0,4.3, 99, 80,   00,  W/B ,+15.9,  82.5,+15.5, +0.1, 83.70,4.3, >25:1
 4246,+18.8,4.1,100, 90,   00,  W/B ,+13.9,  74.7,+14.5, +1.6,100.00,4.1, >25:1
 4420,+19.0,4.2,100,100,   00,  W/B ,+13.4,  82.4,+14.2, +1.7,100.00,4.3, 13.65
 4604,+20.4,4.2,101,100,   00,  W/B ,+14.5,  88.1,+14.7, +0.4,100.00,4.2, 12.02
 4990,+22.5,4.3,100,100,   00,  W/B ,+16.2,  92.2,+16.2, +0.1,100.00,4.3, 11.65
 5042,+22.3,4.4,100,100,   00,  W/B ,+14.1,  97.1,+17.0, -0.1,100.00,4.4, 11.53
 5324,+22.7,4.4,100,100,   00,  W/B ,+15.6, ---.-,+17.2, +0.0,100.00,4.4, 11.42
 5668,+22.7,4.5,100,100,   00,  W/B ,+16.4, ---.-,+17.9, +0.0,100.00,4.5, 11.17
 5920,+21.6,4.5,101,100,   00,  W/B ,+17.0, ---.-,+18.7, -0.1,100.00,4.5, 11.11
 6207,+20.8,4.5,100, 90,   00,  W/B ,+17.7, ---.-,+20.5, -1.1,100.00,4.4, 11.24
 6325,+20.4,4.5,100, 90,   00,  W/B ,+21.3, ---.-,+20.8, -1.5,100.00,4.5, 11.33
 6472,+19.6,4.5,100,100,   00,  W/B ,+21.8, ---.-,+21.7, -0.5,100.00,4.5, 11.39
 6600,+19.4,4.5,100, 90,   00,  W/B ,+22.5, ---.-,+24.2, -1.8,100.00,4.4, 11.48
 6830,+20.0,4.6,100, 90,   00,  W/B ,+23.6,  91.8,+25.1, -1.9,100.00,4.4, 11.49
 6816,+17.0,3.2,  0, 70,   00,  W/B ,+10.8,  17.1,ECU. , -2.0,LCM.  ,3.4, 11.77
 6172,+10.0,2.2,  0, 10,   00,  W/B ,+10.6,  10.4,ECU. , -4.4,LCM.  ,2.1, 14.37
 5537, +2.7,2.2,  0, 10,   00,  W/B ,+11.1,  10.0,ECU. , -3.8,LCM.  ,2.1, >25:1
 4728, -4.9,2.3,  0, 10,   00,  W/B ,+11.2,   9.8,ECU. , -3.4,ECU.  ,2.1, >25:1
 4688, -9.6,2.2,  0, 00,   00,  W/B ,+11.0,  14.6,ECU. , -4.4,ECU.  ,2.1, >25:1
must... get... water injection... running...
Old 01-25-2006, 10:03 AM   #36
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
just some old comparo pics of the 23 vs td04:
Old 01-25-2006, 11:51 AM   #37
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
ken some guy on another forum was telling me his vf23 + tmic + tune (on 91 cali) was going to be close to 300 whp, i laughed.
bren wrx is offline   Reply With Quote
Old 01-25-2006, 11:57 AM   #38
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
with dynos as uncalibrated as they seem to be, it's possible. i had someone tell me that a stock sti dynoing 250whp is reasonable.
even on an "average" one, you'd need a lot more mods than that. adi, ewg would get you close... or just a bottle of n2o. i've actually considered it!
Old 01-25-2006, 12:08 PM   #39
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
when are we goign to see your tuning skills on the dyno or track?
Old 01-25-2006, 12:11 PM   #40
amukaoen
Member#: 62595
04 WRX Cobb S2
World Rally Blue
What are your mods? I'll send you some of the maps I have for my vf23 if you want em. That's weird that you lost some spool time, if anything, my 23 spooled at the same spot as my stock turbo, some people think it axtually spools before my stocker did.
have any dyno graphs of your VF23?
amukaoen is offline   Reply With Quote
Old 01-25-2006, 12:13 PM   #41
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the only people i race are cops.
hopefully this spring i'll make it to NED and see if i can't get a piston to jump out of the block. only running 23psi nowadays... i might have to turn it up some more.
Old 01-25-2006, 12:21 PM   #42
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
you run 7 more psi then me, you are sooooooo davenow
when people ask you that you should say 23 psi on a vf23 beyotchhhhhhh and dump the clutch at 6k
Old 01-25-2006, 12:27 PM   #43
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
the difference between dave and me is that i still have 160psi in all cylinders. launch control is set to 5000, so no 6k dumps.
Old 01-25-2006, 03:25 PM   #44
jamesfacts
Member#: 51282
98 RS
black & blue from parking
No really guys, if you run 300whp out of the 2.0 its definitely going to blow up!
jamesfacts is offline   Reply With Quote
Old 01-25-2006, 06:59 PM   #45
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Yep. 299 ok, 300 KAPOW!
cdvma is offline   Reply With Quote
Old 01-25-2006, 07:09 PM   #46
SketchINoc
Member#: 87370
2005 WRX,Soon to be
EVO9-94 toyota4x4 project
you are using a VF30 with stock TMIC, and you have 300whp. I'm sorry, but all the new VF series turbos flow within 50CFM of each other i think. A VF30 does not push much more than a VF23. It all depends on the dyno. I bet you got tuned on a high reading dyno jet.
SketchINoc is offline   Reply With Quote
Old 01-25-2006, 07:11 PM   #47
TheMadScientist
Member#: 23717
2005 Big red
*popcorn*
Mmmm......Beeeer!
TMS
Old 01-25-2006, 07:20 PM   #48
J-Rex2004
Member#: 68490
'04 tippin' on
fo'fo jackstands.
If you look at the thread he posted his graph in it states it is a VF34 and his tuner says it is some freak knock off turbo....I'm thinking it's a 1818 clone.
If you go to the tdc's web page you will see they don't have a high reading dyno.
J-Rex2004 is offline   Reply With Quote
Old 01-25-2006, 08:45 PM   #49
Carndiggity73
Member#: 59474
02 WRXWgn-RIP
2001 MR2
don't doubt the 2.0 james, the jdm cars had it for years and us american's should embrass it not blow it up
Carndiggity73 is offline   Reply With Quote
Old 01-25-2006, 09:32 PM   #50
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
thank you
how much more hp does the vf22 put out over the vf23 godfather2112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-09-2005 07:17 AM
Where is the best place to get the VF23 waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-24-2003 02:56 AM
Will VF23 from Ver. III STi fit the WRX? mca Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-03-2002 06:27 PM
Let's compare the VF23 to the VF30 turbo's HOKOS Texas Impreza Club Forum -- TXIC 19 07-29-2002 06:10 PM
So whats the best FMIC for the VF23? codean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-18-2002 12:08 AM
