Welcome to the North American Subaru Impreza Owners Club Monday February 19, 2018
Old 01-25-2006, 10:48 PM   #51
Nytmare
Member#: 64175
Originally Posted by J-Rex2004
If you look at the thread he posted his graph in it states it is a VF34 and his tuner says it is some freak knock off turbo....I'm thinking it's a 1818 clone.
If you go to the tdc's web page you will see they don't have a high reading dyno.
VF34 stock tmic, correct.
Freak turbo, probably.
Freak car, definitely.
Nytmare is offline   Reply With Quote
Old 01-25-2006, 10:53 PM   #52
Tdc Tuning
Vendor
Member#: 70993
only AWD Dyno in NH
AP, Utec, Hydra etc.
i said brens car is a FREAK
not that the turbo is
Tdc Tuning is offline   Reply With Quote
Old 01-26-2006, 09:41 AM   #53
bObby
Member#: 66959
04 STi and E46
M3
sorry to jump in at a weird time. but someone asked for a dyno chart.. here is mine . i made 265 whp on a dynapak and 250 ft/lbs torque
mods
vf23
565cc injectors
fuel pump
uppipe
turboback
front mount intercooler
turbo inlet pipe
and tune with a utec by Dan at Tuning Factory(godspeed)
bObby is offline   Reply With Quote
Old 01-26-2006, 09:54 AM   #54
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
henry, do you have a boost/afr chart as well?
in any event, thanks for the dyno plot!
ken
Old 01-27-2006, 09:17 AM   #55
bObby
Member#: 66959
04 STi and E46
M3
no i do not. i can email my tuner and see if he can email me the chart if he has time.
Old 01-27-2006, 10:34 AM   #56
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
30* F morning. nailed it at the top of 1st, took it through second.
pulling some good air! squirting 90% methanol right on the IC helps...
Code:
 3996  +1.7 3.6  51  00    00  W/B   +18.8   14.5 ECU.   -4.0 ECU.   3.5  14.58
 4547  +4.9 4.0  80  30    00  W/B   +13.6   81.6 +17.9  -5.5 WGS.   3.8  14.15
 5367  +9.0 4.3 100  50    00  W/B   +17.2   97.7 +19.6  -6.0 100.00 4.1  12.61
 6071 +13.3 4.5 100  80    00  W/B   +18.9    1.0 +19.9  -6.1 100.00 4.3  11.37
 6613 +16.3 4.6 100  90    00  W/B   +24.1    1.0 +21.2  -6.4 100.00 4.3  11.53
 7183 +18.8 4.6 100 100    00  W/B   +24.7    1.0 +21.4  -7.2 LCM.   4.2  12.09
 6116 +19.4 4.4 100  90    00  W/B   +23.3   88.2 +17.8  -7.0 LCM.   4.1  19.71
 5307 +18.2 4.4 100  70    00  W/B   +18.1   83.9 +15.7  -6.5 LCM.   4.0  20.00
 4130 +17.4 4.4 100  70    00  W/B   +12.1   85.7 +15.4  -6.3 100.00 4.0  20.00
 4345 +18.2 4.3 100  90    00  W/B   +10.7   91.4 +14.2  -6.9 100.00 4.0  18.63
 4675 +18.8 4.3 100 100    00  W/B   +11.9   89.3 +14.4  -7.2 100.00 4.0  12.14
 4967 +20.0 4.4 100 100    00  W/B   +13.9   93.2 +15.3  -7.2 100.00 4.1  11.68
 5249 +21.0 4.5 100 100    00  W/B   +16.5   97.5 +16.1  -6.6 100.00 4.2  11.76
 5473 +21.0 4.5 100 100    00  W/B   +15.9   99.7 +16.8  -7.2 100.00 4.2  11.65
 5858 +21.2 4.6 100 100    00  W/B   +16.9   99.1 +17.2  -7.2 100.00 4.2  11.53
 5931 +21.7 4.6 100 100    00  W/B   +17.2    1.0 +17.4  -7.2 100.00 4.2  11.73
 6313 +21.9 4.6 100 100    00  W/B   +17.9    1.0 +18.0  -7.2 100.00 4.3  11.96
 6435 +21.2 4.6 100 100    00  W/B   +21.7   99.5 +18.8  -7.2 100.00 4.3  12.05
 6720 +21.2 4.6 100 100    00  W/B   +22.2   98.9 +19.7  -6.6 100.00 4.3  12.18
 6901 +20.8 4.6 100 100    00  W/B   +22.1   98.7 +21.7  -7.2 100.00 4.3  12.21
Old 01-27-2006, 10:45 AM   #57
TheMadScientist
Member#: 23717
2005 Big red
Code:
Ooooo 4.6 MAFV very nice.
Just be careful with the meth. You can't see it burn in direct sunlight.
TMS
TheMadScientist is offline   Reply With Quote
Old 01-27-2006, 07:45 PM   #58
scoobie1
Member#: 41559
2007 Brocoma
Originally Posted by amukaoen
have any dyno graphs of your VF23?
Wow, this thread came back from the dead...nope, I lost it a long time ago. Its been almost 2 years since I had that old VF23 dyno'd. A friend of mine got the turbo and the rest of my STg4 setup and put it on his 04 WRX and its weird cause it doesn't spool like it did on my car. Don't get me wrong, his car is still fast but the 23 on my old WRX used to kick in well below 3k rpm and just pull like crazy but it doesn't do that on his car. Maybe I had a ringer?
scoobie1 is online now   Reply With Quote
Old 12-21-2006, 12:49 PM   #59
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
last night, highway on ramp. roll on throttle, 1st gear, from 1krpms through 3rd gear.
Code:
[TSMP][RPM][PSIG][MAF][TPS][LOD][KN][SNB][SIG][IDC%][IGN][VOEF][BMV][MMV][WBO2][IGNT]
000.00 4130 +11.4 3.8  100    0   0  12.1 17.0  49.1 ECU.  95   WGS  3.9  12.05 0.686
000.04 4198 +12.9 4.0  100    0   0  12.1 16.2  52.0 ECU.  95   WGS  4.0  12.08 0.643
000.15 4336 +17.0 4.0  100   40   0  12.2 10.7  62.3 16.9  97   WGS  4.3  12.21 0.411
000.20 4618 +19.4 4.2  100   60   0  12.3 10.3  72.2 14.0  99   100  4.4  12.29 0.372
000.30 4845 +22.9 4.5  100   80   0  12.5 +9.3  85.3 12.9 100   100  4.5  12.54 0.320
000.41 5201 +23.1 4.5  100   80   0  12.7 10.0  94.9 13.1 100   100  4.5  12.65 0.320
000.45 5521 +23.3 4.5  100   80   0  12.6 +9.6  96.6 13.3 100   100  4.5  12.60 0.290
000.59 5875 +21.9 4.6  100   80   0  12.5 10.8  96.5 16.4  97   100  4.6  12.46 0.306
000.64 6140 +21.6 4.6  100   70   0  12.3 11.4  96.9 16.7  96   100  4.6  12.31 0.309
000.75 6319 +21.2 4.6  100   70   0  11.9 15.2  98.9 17.8  96   100  4.6  11.91 0.401
000.82 6516 +20.8 4.6  100   70   0  11.7 16.8  99.8 18.3  95   100  4.6  11.71 0.430
000.90 6731 +20.2 4.6   98   70   0  11.7 17.2   0.0 19.0  95   100  4.6  11.74 0.426
001.04 6983 +21.0 4.6  100   70   0  12.9 20.7   0.0 18.9  95   100  4.6  12.94 0.494
001.08 7267 +21.2 4.6  100   70   0  14.7 21.5   0.0 18.8  95   100  4.6  14.71 0.493
001.20 7272 +21.2 4.6  100   70   0  21.7 21.5   0.0 18.6  95   LCM  4.5  21.67 0.493
001.25 7068 +20.0 4.6  100   70   0  25.0 21.4  99.3 19.5  96   LCM  4.5  25.00 0.505
001.35 6709 +17.4 4.4  100   50   0  25.0 20.5  83.8 21.1  96   LCM  4.4  25.00 0.509
001.45 6280 +16.5 4.4  100   40   0  25.0 15.8  73.4 20.2  96   LCM  4.2  25.00 0.419
001.50 5664 +16.8 4.3  100   50   0  25.0 12.7  55.0 16.5  96   LCM  4.0  25.00 0.374
001.65 5278 +19.4 4.1  100   60   0  25.0 11.3  74.9 14.3  99   100  4.4  25.00 0.357
001.69 5045 +21.0 4.4  100   70   0  22.2 11.1  72.6 13.6  99   100  4.4  22.20 0.367
001.80 4716 +24.5 4.4  100   90   0  15.2 +8.3  79.2 10.0 100   100  4.3  15.21 0.293
001.86 4580 +24.5 4.3  100   90   0  13.5 +8.9  81.8 10.0 100   100  4.3  13.46 0.324
001.95 4550 +24.5 4.3  100  100   0  12.8 +8.9  81.0 10.0 100   100  4.3  12.82 0.326
002.07 4608 +24.3 4.3  100   90   0  12.4 +9.0  83.3 10.5 100   100  4.3  12.42 0.326
002.12 4695 +24.3 4.3  100   90   0  12.3 +9.1  84.7 10.5 100   100  4.4  12.32 0.323
002.25 4821 +24.1 4.4  100   90   0  12.2 +9.1  86.0 11.0 100   100  4.4  12.19 0.315
002.29 4896 +24.1 4.4  100   90   0  12.2 +9.6  85.9 11.5 100   100  4.4  12.18 0.327
002.40 5048 +23.7 4.4  100   90   0  12.2 +9.4  88.3 12.3 100   100  4.5  12.22 0.310
002.48 5111 +23.7 4.5  100   90   0  12.3 +9.3  88.8 12.3 100   100  4.4  12.26 0.303
002.55 5181 +23.5 4.4  100   90   0  12.3 +9.6  88.9 12.5 100   100  4.5  12.33 0.309
002.69 5347 +23.3 4.5  100   90   0  12.3 +9.6  93.2 12.5 100   100  4.5  12.31 0.299
002.73 5465 +23.1 4.5  100   80   0  12.3 +9.5  93.0 13.0 100   100  4.5  12.28 0.290
002.85 5557 +23.1 4.5  100   80   0  12.2 +9.6  92.8 13.1 100   100  4.5  12.22 0.288
002.90 5622 +22.9 4.5  100   80   0  12.2 +9.9  93.7 13.5  99   100  4.6  12.18 0.293
003.00 5744 +22.5 4.6  100   80   0  12.1 +9.5  95.3 13.9  99   100  4.5  12.10 0.276
003.11 5896 +22.3 4.5  100   80   0  12.0 +9.5  96.9 14.1  99   100  4.5  12.01 0.269
003.15 5970 +22.3 4.6  100   80   0  12.0 +9.5  97.0 15.2  99   100  4.6  11.96 0.265
003.30 6021 +21.9 4.6  100   80   0  11.9 10.5  94.8 15.7  98   100  4.6  11.86 0.291
003.34 6084 +21.9 4.6  100   80   0  11.8 10.6  96.2 15.9  97   100  4.6  11.82 0.290
003.45 6184 +22.1 4.6  100   80   0  11.7 11.0  98.8 16.7  97   100  4.5  11.71 0.296
003.52 6319 +21.4 4.6  100   80   0  11.7 12.3  99.5 17.1  97   100  4.6  11.66 0.324
003.60 6409 +21.6 4.6  100   80   0  11.5 14.6   0.0 18.0  95   100  4.6  11.54 0.380
003.73 6506 +21.6 4.6  100   80   0  11.5 15.5   0.0 17.6  96   100  4.6  11.46 0.397
003.78 6612 +21.2 4.6  100   70   0  11.4 15.5  98.8 17.6  96   100  4.6  11.41 0.391
003.90 6719 +21.0 4.6  100   70   0  11.3 16.6   0.0 17.9  95   ECU  4.6  11.31 0.412
003.95 6731 +21.2 4.6  100   70   0  11.3 16.4  98.8 18.2  95   100  4.6  11.28 0.406
004.05 6814 +21.4 4.6  100   70   0  11.3 17.2   0.0 17.9  95   100  4.6  11.29 0.421
004.15 6969 +21.2 4.6  100   70   0  11.3 17.6   0.0 18.4  95   100  4.6  11.30 0.421
004.20 7043 +21.2 4.6  100   70   0  12.3 18.0   0.0 18.4  95   100  4.6  12.27 0.426
004.35 6926 +21.4 4.7  100   80   0  17.2 19.4   0.0 18.0  96   LCM  4.6  17.15 0.467
004.39 6775 +20.6 4.6  100   70   0  20.3 18.6  97.8 18.3  96   LCM  4.5  20.25 0.458
004.50 6511 +18.8 4.5  100   60   0  25.0 14.5  86.4 18.8  98   LCM  4.4  25.00 0.371
004.57 6205 +18.0 4.4  100   50   0  25.0 14.2  79.5 19.1  97   LCM  4.4  25.00 0.381
004.64 5613 +18.0 4.4  100   50   0  25.0 11.5  61.3 15.6  98   LCM  4.1  25.00 0.341
004.78 5414 +19.6 4.1  100   60   0  25.0 12.1  75.9 14.6  98   100  4.5  24.99 0.372
004.82 5207 +21.6 4.5  100   80   0  22.1 +9.3  77.7 11.7 100   100  4.5  22.12 0.298
004.95 4988 +24.3 4.5  100   90   0  13.8 +9.2  86.1 10.8 100   100  4.5  13.75 0.307
004.99 4962 +24.5 4.5  100   90   0  12.8 +9.3  89.8 11.0 100   100  4.4  12.78 0.312
005.10 5001 +24.3 4.4  100   90   0  12.4 +9.4  87.6 11.4 100   100  4.4  12.43 0.313
005.20 4986 +23.9 4.4  100   90   0  12.2 +9.3  87.8 12.0 100   100  4.4  12.16 0.311
005.26 5056 +23.9 4.4  100   90   0  12.1 +9.3  89.0 12.1 100   100  4.4  12.05 0.307
005.41 5117 +23.5 4.4  100   90   0  12.0 +9.4  87.9 12.3 100   100  4.4  12.00 0.306
005.45 5169 +23.7 4.4  100   90   0  12.0 +9.5  87.4 12.5 100   100  4.5  12.01 0.306
005.55 5233 +23.5 4.5  100   90   0  12.1 +9.6  89.8 12.5 100   100  4.5  12.06 0.306
005.60 5322 +23.3 4.5  100   90   0  12.1 +9.6  91.0 12.4 100   100  4.5  12.09 0.301
005.70 5404 +23.5 4.5  100   90   0  12.1 +9.6  92.6 12.5 100   100  4.5  12.10 0.296
005.81 5390 +23.5 4.5   99   90   0  12.1 +9.6  92.2 12.5 100   100  4.5  12.11 0.297
005.85 5363 +23.5 4.5  100   90   0  12.1 +9.5  92.9 12.5 100   100  4.5  12.10 0.295
006.01 5430 +23.3 4.5  100   90   0  12.0 +9.9  93.1 12.6 100   100  4.5  12.00 0.304
006.05 5549 +23.3 4.5  100   90   0  12.0 +9.5  95.1 12.8 100   100  4.5  11.99 0.285
006.16 5598 +23.3 4.5  100   80   0  11.9 +9.5  96.3 12.9 100   100  4.6  11.93 0.283
006.23 5645 +23.1 4.5  100   80   0  11.9 +9.6   0.0 13.1 100   100  4.5  11.89 0.283
006.30 5717 +23.1 4.5  100   80   0  11.9 +9.5  95.6 13.2 100   100  4.5  11.89 0.277
006.44 5798 +22.9 4.5  100   80   0  11.9 10.1  96.7 13.4  99   100  4.5  11.87 0.290
006.48 5821 +23.1 4.5  100   80   0  11.9 +9.6  95.4 13.7  99   100  4.5  11.86 0.275
006.60 5846 +22.7 4.6  100   80   0  11.8 +9.3  95.0 13.5 100   100  4.6  11.82 0.265
006.65 5910 +22.7 4.6   99   80   0  11.8 +9.5  94.9 13.7  99   100  4.5  11.81 0.268
006.76 5946 +22.7 4.6  100   80   0  11.8 +9.5  96.9 14.1  99   100  4.5  11.76 0.266
006.84 5986 +22.9 4.5  100   80   0  11.7 +9.5  94.5 14.6  99   100  4.6  11.69 0.265
006.91 5995 +22.5 4.6  100   80   0  11.7 10.1  96.4 14.4  98   100  4.6  11.68 0.281
007.05 6097 +22.3 4.6  100   80   0  11.6 10.0  96.5 14.5  98   100  4.6  11.62 0.273
007.09 6159 +22.5 4.6  100   80   0  11.6 10.7  97.7 15.0  98   100  4.6  11.59 0.290
007.20 6144 +22.7 4.6  100   80   0  11.5 10.6  98.8 14.9  98   100  4.6  11.53 0.288
007.27 6168 +22.5 4.6  100   80   0  11.5 10.9  98.7 16.0  97   100  4.6  11.53 0.295
007.36 6248 +22.3 4.6  100   80   0  11.5 10.7  99.9 15.4  98   ECU  4.6  11.51 0.285
007.48 6327 +22.1 4.6  100   80   0  11.5 10.8  95.7 15.5  97   100  4.6  11.48 0.284
007.52 6373 +21.9 4.6  100   80   0  11.5 11.3  98.3 16.0  97   100  4.6  11.47 0.296
007.66 6417 +21.9 4.6  100   80   0  11.4 12.8  99.4 16.4  97   100  4.6  11.37 0.332
007.70 6469 +22.1 4.6  100   80   0  11.3 14.9  99.8 16.6  97   100  4.6  11.33 0.384
007.80 6458 +21.9 4.6  100   80   0  11.2 14.8   0.0 16.6  97   100  4.6  11.24 0.382
007.89 6466 +21.9 4.6  100   80   0  11.2 15.1   0.0 16.5  96   100  4.6  11.19 0.389
007.96 6480 +21.6 4.6  100   80   0  11.1 15.2   0.0 17.4  96   100  4.6  11.14 0.391
008.10 6566 +21.6 4.6  100   80   0  11.1 15.6   0.0 17.3  96   100  4.6  11.14 0.396
008.15 6585 +21.6 4.6  100   80   0  11.4 15.9   0.0 16.9  96   100  4.6  11.37 0.402
008.26 6625 +21.6 4.7  100   80   0  12.8 16.3   0.0 17.2  96   ECU  4.6  12.80 0.410
008.30 6681 +21.9 4.6  100   80   0  13.8 16.2   0.0 16.4  96   LCM  4.6  13.78 0.404
4.7mafv makes me
i'm still dialing in the SD map on the utec.. i'd like to lean it out more at redline. so far i am very happy with the advance i'm able to throw back in compared to my safe oem ecu base map. having played around with the oem reflash stuff for a few months now, i have to say it is nice to get back to the utec, primarily because the updating process is far quicker (although i do have to point out that i am helping test a realtime ecu tuning module), and the logging requires a bit less mental processing before intelligent tuning decisions can be made. for these reasons i do feel more comfortable pushing things with the utec than with the oem ecu.
btw, who knew a vf23 could hold 21+psi at redline?
Old 12-21-2006, 12:55 PM   #60
TheMadScientist
Member#: 23717
2005 Big red
Looks like you are pushing the limit on the stock MAP. Any plans to upgrade to a 3bar or bigger?
TMS
Old 12-21-2006, 01:41 PM   #61
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
yeah, i've got plans to.
that's the easy part!
i am going to try branching off the 3bar gm sensor that came with my autometer electrical boost gauge.
on the other hand, unlike some others, my oem ecu definition has tables for slope and intercept for the MAP sensor scaling. maybe i'll just switch to a 3 bar for both oem ecu and utec. i do greatly prefer the oem ecu's boost control over the utec's, and to control boost you have to know what it is.
Old 12-21-2006, 01:54 PM   #62
Jasper
Member#: 80136
2006 Ford F-150
do a writeup on the 3bar sensor ken.i'll most likely be needing one with my new setup come spring (selling AP, going UTEC+enginuity for SD. something tells me a 3" inlet 18G might just max out my MAF
once the alky comes in, hellooooooooooo 28+psi
Jasper is offline   Reply With Quote
Old 12-21-2006, 01:55 PM   #63
TheMadScientist
Member#: 23717
2005 Big red
I have siad that a few times. I get "no way have you tried the new PID?".
My response to that is the stock ecu has much better boost control than anything you can buy for <$5000.
<--jelous that you have the tables to use a 3bar with the stock ecu.
TMS
Old 12-21-2006, 02:48 PM   #64
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
how in the ??
bren wrx is offline   Reply With Quote
Old 12-21-2006, 02:52 PM   #65
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Hey ride5000 what ignition timing do you run in the 90-100% columns on your tune that is 11.5:1?
PaulRex is offline   Reply With Quote
Old 12-22-2006, 08:17 AM   #66
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hey paul, here's the utec timing map:
Code:
Timing Map
   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
   [-100]   [-100]     [23]     [21]     [19]     [17]     [15]     [14]     [13]   [11.5]    [9.5]
   [-100]   [-100]   [22.3]   [20.3]   [18.3]   [16.3]   [14.5]     [14]     [13]   [11.5]    [9.5]
   [-100]   [-100]   [21.5]   [19.5]   [17.5]   [15.5]     [14]     [14]     [13]   [11.5]    [9.5]
   [-100]   [-100]   [22.2]   [20.2]   [18.2]   [16.2]   [14.7]     [14]     [13]   [11.5]    [9.5]
   [-100]   [-100]   [22.9]   [20.9]   [18.9]     [17]   [15.5]     [14]   [13.4]   [11.5]     [10]
   [-100]   [-100]   [23.6]   [21.6]   [19.6]   [17.7]   [16.2]     [14]   [13.8]   [11.5]     [10]
   [-100]   [-100]   [24.4]   [22.4]   [20.4]   [18.4]   [16.7]     [14]   [14.2]   [11.5]     [10]
   [-100]   [-100]   [25.1]   [23.1]   [21.1]   [19.1]   [17.3]   [14.7]   [14.6]   [12.5]     [11]
   [-100]   [-100]   [25.9]   [23.9]   [21.9]   [19.7]   [17.9]   [15.4]   [14.9]   [12.7]     [11]
   [-100]   [-100]   [26.6]   [24.6]   [22.6]   [20.4]   [18.5]     [16]   [15.3]   [12.9]     [11]
   [-100]   [-100]   [27.5]   [25.5]   [23.5]   [21.1]     [19]   [16.7]   [15.7]   [13.1]     [11]
   [-100]   [-100]   [29.3]   [27.3]   [25.3]   [21.8]   [19.6]   [17.4]   [16.1]   [13.9]   [11.6]
   [-100]   [-100]   [30.5]   [28.5]   [26.5]   [23.1]   [20.8]   [18.4]   [16.5]   [14.6]   [12.1]
   [-100]   [-100]   [31.4]   [29.3]   [27.2]   [24.1]   [21.8]   [19.4]   [17.1]   [14.8]   [12.1]
   [-100]   [-100]   [32.3]   [30.1]   [27.8]   [25.2]   [22.8]   [20.5]   [17.8]     [15]   [12.1]
   [-100]   [-100]   [33.2]   [30.9]   [28.5]   [26.2]   [23.8]   [21.5]   [18.4]   [15.2]   [12.1]
   [-100]   [-100]   [31.6]   [29.8]   [27.9]   [26.1]   [24.2]   [22.4]     [19]   [15.5]   [12.1]
   [-100]   [-100]   [32.3]   [30.5]   [28.7]   [26.9]   [25.1]   [23.3]   [19.6]   [15.8]   [12.1]
   [-100]   [-100]   [33.1]   [31.3]   [29.5]   [27.7]   [25.9]   [24.1]   [20.1]   [16.1]   [12.1]
   [-100]   [-100]   [33.7]     [32]   [30.2]   [28.5]   [26.7]     [25]   [20.7]   [16.4]   [12.1]
on the above pull it was a little bit less advanced:
Code:
Timing Map
   [-100]   [-100]     [23]     [21]     [19]     [17]     [15]     [14]     [13]     [11]      [9]
   [-100]   [-100]     [23]     [21]     [19]     [17]   [15.6]     [14]   [13.4]   [11.5]     [10]
   [-100]   [-100]   [30.5]   [28.5]   [26.5]   [23.1]   [20.8]   [18.4]     [17]   [14.6]   [12.1]
   [-100]   [-100]   [31.4]   [29.4]   [27.4]   [23.9]   [21.4]     [19]   [17.4]   [14.8]   [12.1]
   [-100]   [-100]   [32.3]   [30.3]   [28.3]   [24.6]   [22.1]   [19.5]   [17.8]     [15]   [12.1]
   [-100]   [-100]   [33.2]   [31.2]   [29.2]   [25.4]   [22.7]     [20]   [18.1]   [15.2]   [12.1]
   [-100]   [-100]   [31.6]   [29.6]   [27.6]   [24.8]   [22.5]   [20.1]   [18.3]   [15.4]   [12.1]
   [-100]   [-100]   [32.3]   [30.3]   [28.3]   [25.5]     [23]   [20.6]   [18.6]   [15.6]   [12.1]
   [-100]   [-100]   [33.1]   [31.1]   [29.1]   [26.2]   [23.6]   [21.1]     [19]   [15.8]   [12.1]
   [-100]   [-100]   [33.7]   [31.7]   [29.7]   [26.8]   [24.2]   [21.5]   [19.3]     [16]   [12.1]
i made the changes yesterday. i just took a couple of quick logs and things seem to be handling the timing well so far.
a few notes: min MAP for mapping is 10psi, max is 24.5, so the 100 column is really only used when the MAP sensor is maxed out. OLF crossover points are 1000rpm, 20% TPS, and 12psi MAP with a 1psi hysteresis. this keeps the utec out of the picture while at wastegate boost or lower.
also, i'd like to point out that the latest utec firmware DOES interpolate horizontally. in other words, even though the MLP may show up as "90" in the log, if the actual boost level is midway between what would be 90 and 100 load it will set timing midway between the two. this is quite unlike the older software that did not interpolate horizontally at all.
Old 01-01-2007, 09:41 AM   #67
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
recent 4th gear log: http://forums.nasioc.com/forums/show...7#post16499327
CN: 1 bar at 3075rpms
how much more hp does the vf22 put out over the vf23 godfather2112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-09-2005 08:17 AM
Where is the best place to get the VF23 waitandbleed92 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-24-2003 03:56 AM
Will VF23 from Ver. III STi fit the WRX? mca Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-03-2002 07:27 PM
Let's compare the VF23 to the VF30 turbo's HOKOS Texas Impreza Club Forum -- TXIC 19 07-29-2002 07:10 PM
So whats the best FMIC for the VF23? codean Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-18-2002 01:08 AM
