05-10-2012, 07:06 PM | #201 |
Member#: 159474
NESIC
Vehicle:2017 Impreza Sport Lithium Red - OLDKID |
Why are you showing pictures and explaining the fog light STALK? Aren't you looking for the BUTTON? I'm so confused!
05-10-2012, 07:10 PM | #202 |
Member#: 263322
NESIC
Vehicle:2011 WRX Limited WRBP |
Oh, I thought this was a thread to get his post count up
05-15-2012, 11:39 PM | #203 |
Member#: 309754
Tri-State
Vehicle:2012 Impreza Sport L Ice Silver Metallic |
Good one,! LOL ! But, No I really need someone to help me get the dash mount switch part number. I am going to a few Subaru dealers and see if i can actually see if there is a part number on the back of the switch from the fog lights kit.
05-16-2012, 07:39 PM | #204 |
Member#: 309754
Tri-State
I went to a few Dealers in my area, but none of them are willing to open the package cause they do not want to mess up the packaging and then they cannot resell it.
05-16-2012, 07:47 PM | #205 |
Member#: 159474
NESIC
Call Subaru.
06-27-2012, 01:15 AM | #206 |
Member#: 324448
International
I notice this sedan rear fog light is also work for Subaru xv ? seem in other forum :-p
07-11-2012, 04:53 PM | #207 |
Member#: 325834
International
Vehicle:2011 Impreza 1.5R Sky Blue Metallic |
Rear fog lamps
Hello everyone. Just joined this forum today to see if anyone could help me find the rear fog lamp for a regular 2011 Impreza sedan. I live in Panama so they ship the 1.5R version and the rear bumper has some black caps and it is a bit different from the US version like in the picture I have attached here.
I have seen it for the regular wagon version of the Impreza I don't think it even exists for the regular Impreza and it is just available for the WRX STI version |
07-12-2012, 03:04 AM | #208 | |
Member#: 305161
Vehicle:2011 STI 4-door |
Here is the link for the Impreza that is just being dismanlted for the spare sparts. According to those pictures, the fog lamp that you are looking for is still on that car. Try to contact that eBay seller for more info. Good luck! http://www.ebay.co.uk/itm/08-10-Suba...item4cfdc4bdf8 |
07-12-2012, 06:24 PM | #209 | |
Member#: 325834
International
Muchas gracias! |
07-12-2012, 07:38 PM | #210 | |
Member#: 325834
International
07-13-2012, 09:12 AM | #211 | |
Member#: 72730
NESIC
Vehicle:2019 Volvo S60 T6-R SPORT CHASSIS |
07-13-2012, 12:39 PM | #212 |
Member#: 325834
International
I have been talking to seller on eBay and he already put the part on sale. The left side is the rear fog lamp and the right is just a reflector. The lamp is activated with the light switch handle. For cars with front fog lamps the ring only has one position to turn the front fog lamps, the cars equipped with both front and rear fog lamps the ring has a 2nd position that will activate it and then go back to the 1st position. I also confirmed this with my owners manual but I can't upload the picture here but if you want it just let me know
Here is the eBay link for the lamp http://www.ebay.com/itm/230825062061...ht_1709wt_1187 Also requested the seller for the part number since it would be easier to find elsewhere |
07-16-2012, 12:38 AM | #213 |
Member#: 192044
Vehicle:2013 STI SWP |
I just installed my Rear foglight today. am going to have a shop wire it into the taillights, So when the Fogs/Runners/headlights are on the light will be powered through that power source. Which harness through the taillights do you want to pick? I believe there was a plug in that had 6 different wire colors and another one had black/red/white/black? I know i will need a ground. And i believe the red is the runners lights and the white/black is the braking light? any input would be awesome!
07-18-2012, 10:25 AM | #214 |
Member#: 325834
International
I haven't found the one for my car . I've been asking the seller on eBay for better pics and part number because I don't want to spend all this money for nothing
07-18-2012, 10:38 AM | #215 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
Please do not use the fog-lamp as another brake-lamp. It is not designed as a brake-lamp and will blind the person behind you if used as such. Trust me, I know.
07-18-2012, 11:12 AM | #216 | |
Member#: 43393
MAIC
Vehicle:2014 Audi a6 Daytona Gray |
07-18-2012, 01:43 PM | #217 | |
Member#: 72730
NESIC
In practice an OEM rear fog is usually not "blinding", and using it as a brake light is probably better than the tools in Audis and Volvos driving around with the rear fogs blazing 24/7/365. Americans can't be trusted with fog lights hahah But really do you want a left side offset brake light? A rear foglight on the left indicates to pass left, a brake light only on the left indicates you have a bulb out ;-) Also this has already been hashed out, you can't use the OEM rear fog switch on the stalk, it is a momentary switch that signals the BIU to turn on the rear fog. It was never determined if the US BIU would run this, and what pins the input/output is on. So if you do this just get a separate switch... |
08-08-2012, 10:21 AM | #218 |
Member#: 103954
So it seems like no one's had success in finding someone to help with programming the BIU. If the VW/Audi guys can figure out how to activate "hidden" features so quickly, there has to be someone in the Subaru camp that can do the same!
08-15-2012, 12:57 PM | #219 |
Member#: 103954
Would anyone happen to know if just plugging in the Euro stalk will allow for the FRONT fogs to turn on with only the parking lamps? I'm pretty sure that the EDM cars work like that from the factory. Otherwise, would we also need a different relay (just like the USDM kit comes with a relay) and/or BIU programming for it to work? Since my OEM stalk is starting to fail on me, I'm trying to decide if it's worth trying to source an EDM stalk for the front fog feature alone instead of buying a USDM stalk.
08-27-2012, 02:30 PM | #220 |
Member#: 325834
International
Rear fog switch
Hi,
I think I mentioned it before but for Impreza's that come with that rear fog lamp, the switch is on the same "ring" that turns on the front fog lamps, the first click would turn on the front fog lamps and the 2nd click for the rear but when you turn on the rear the ring goes back to the first click since is spring loaded. I will try to get a picture of my manual for a better explanation. I think that the rear fog lamps of the Legacy are exactly the same as the Impreza |
11-09-2012, 05:15 PM | #221 |
Member#: 324423
Vehicle:2012 Impreza Sport ISM |
hate to bring up old threads....butttt i think this might help a few guys out
http://richmondsubaruparts.com/parts...iagram=7595320 If you go down and look at part number 5, there is an option for a black and ivory bezel switch...I ordered one today so we will see if it is the right part |
11-13-2012, 08:24 PM | #222 | |
Member#: 270438
NESIC
Vehicle:2011 STi Sedan SWP |
11-13-2012, 11:59 PM | #223 |
Member#: 324423
The part should be here by Friday, I'll let you know
11-16-2012, 09:23 AM | #224 |
Member#: 271589
South East
Vehicle:2016 WRX WRB |
anybody know where I could get a replacement lens for the rear fog light. I just need the actual red lens that's all.
11-16-2012, 11:56 PM | #225 | |
Member#: 1748
NESIC
Vehicle:'09 Outback Sport OBP over DGM |
Similar Threads | ||||
B9 Tribeca amber rear signals and rear fog light | DomozitoLK | Tribeca Forum | 4 | 02-01-2007 12:42 AM |
Rear Fog Light Mod, Anyone done it? | wrxEMT | Interior & Exterior Modification | 4 | 11-23-2001 12:21 PM |
('93-'01) Rear fog lights on 2002 WRX US models ?? | ginowrx | Impreza Forum | 15 | 06-15-2001 06:34 AM |
Rear Fog Light Kit | HRE | giulio | Interior & Exterior Modification | 19 | 05-12-2001 06:48 PM |
Rear Fogs lights-uk Subarus come with? | MichiganRS | Interior & Exterior Modification | 9 | 12-15-2000 09:03 PM |
