Welcome to the North American Subaru Impreza Owners Club Friday October 19, 2018
Old 10-16-2008, 08:07 PM   #1
silverongold
Member#: 132599
02 impreza wrx
Default please help! durable turbos?
I am at the hardest part of my build so far. I have :
fully built 2.0 closed bottom end
bc 272? cams
bc valve springs
sti shim less buckets
ferarra? inconel exhaust valves
aps fuel system
750cc injectors
and plenty i have forgotten along the way ha ha.
I will most likely go with an autronic ecu so that i can use the anti lag function and switch it on and off as well. (I'm going for a higher horse power tarmac rally style build).
i do not need a lecture on how hard it is on any part of the car to run anti lag, I'm well aware. what i do need is a few recommendations for turbos that can make about 400 whp, twin scroll, b.b. and of coarse as durable as possible.
any help would be greatly appreciated!
silverongold is offline   Reply With Quote
Old 10-16-2008, 09:44 PM   #2
wrxsti.l
Member#: 156973
2002 ADM WRX STi
STi Black/Blue
The limiting factor is the twin-scroll you seek. There are only a handful of aftermarket twin-scroll turbos that make 400+whp - and I don't how durable any of those are over standard single-scroll turbos or if there is any bonus apart from more efficient spool.
If you want durability, perhaps look at what the rally and/or race guys are using - from memory it is the material used in the turbo that make them durable - and from memory it is a combination of magnesium, titanium and inconel turbo parts that keep them alive. This equals huge expense.
To keep costs down, you might be better off buying a turbo that is cheap to rebuild and uses an inconel turbine wheel that can withstand the extreme heats and violence associated with anti-lag.
Maybe a custom 60 series turbo from Turbonetics, with T4 divided housing and their F1 turbine wheel would suit? And being F1, you'd expect it to withstand anti-lag
wrxsti.l is offline   Reply With Quote
Old 10-16-2008, 11:02 PM   #3
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I second that of Turbonetics
http://www.turboneticsinc.com/produc...category_id=70
Nice looking set of turbos, high quality housings, super expensive
mick_the_ginge is offline   Reply With Quote
Old 10-17-2008, 11:18 AM   #4
railguy
Member#: 53756
I dont understand why you want to run a twinscroll housing on antilag? I mean with antilag it should spool almost no time! Anti-lag kills turbos why dont buy a cheaper less effienct turbo that you can just replace for a couple houndred. I mean no turbo will stand to antilag. but turbonetics would be way to go.
railguy is offline   Reply With Quote
Old 10-21-2008, 07:13 PM   #5
silverongold
Member#: 132599
02 impreza wrx
well what are some ideas for the 400whp range that are rebuild able and more cost affective?
Old 10-21-2008, 07:22 PM   #6
wrxwhat
Member#: 87653
97 Supra / 17 GTR
16 Z06 / 07 STI / 05 Evo
can't go wrong with a 30r..
wrxwhat is offline   Reply With Quote
Old 10-21-2008, 11:20 PM   #7
4wdwrx
Member#: 72042
2002 V7 Impreza WRX
The Blue Mammoth
I read somewhere IHI turbos are best for anti-lag.
4wdwrx is offline   Reply With Quote
Old 10-22-2008, 05:33 PM   #8
rdodger
Member#: 156447
99 18g'd 2.5RS-T
Except the non-rebuildable part
rdodger is offline   Reply With Quote
Old 10-22-2008, 11:50 PM   #9
lwm495
Member#: 71822
Turbonetics GTK offers 1 year warrt!
lwm495 is offline   Reply With Quote
Old 10-23-2008, 08:55 AM   #10
wrxhard
Member#: 108091
garrett tr30r line of turbos. MADE for racing. Expensive, but durable.
wrxhard is offline   Reply With Quote
Please help, Manley turbo tuff Rod length? I'm Slow Built Motor Discussion 1 12-14-2009 09:18 PM
please help!!!! aps turbo inlet jeremywrx15554 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 10-29-2008 02:57 PM
Please Help w/ Turbo XS Fuel Cut Defender nightskyguy General Community 0 08-31-2007 05:12 PM
Please HELP!!!! SZ65 turbo makes screeching noise at idle!!!! sticrazy Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 06-05-2006 01:12 PM
Please help with turbo problem. IWIN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-23-2004 08:47 PM
