Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Old 12-27-2017, 01:44 AM   #151
topfuelman
Member#: 140036
Default Sensor clearance
Sorry I did this over a year ago..it may have been the same as the newer fa engines ... 1.25-1.35mm clearance.
I ground down a thin stainless washer to get mine in spec.
Have a read of this tsb for reference..
https://subaru.oemdtc.com/TSB/11-130-13R.pdf
Trev
Originally Posted by subydude View Post
Could you post the clearances by chance? I have the heads off right now so I can measure.
I've played with the voltage threshold and gotten an extra 500 rpm but it's still breaking up.
topfuelman is offline   Reply With Quote
Old 12-27-2017, 12:41 PM   #152
subydude
Member#: 80649
2000 2.5 Auto-X RSTi
What's A Head Gasket?
Good stuff, thanks!
subydude is online now   Reply With Quote
Old 12-28-2017, 07:35 AM   #153
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
It looks like the adaptronic ECU has a built in trigger scope function. You should be able to troubleshoot your your sync/trigger issues without an oscilloscope fairly easily using datalogs.
Old 12-28-2017, 08:38 AM   #154
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Old 12-28-2017, 12:27 PM   #155
subydude
Member#: 80649
I did pick up a Haltech Elite 2500 this winter to replace my older Platinum Sport 2000. Supposedly the trigger issue is somewhat common on the platinums and is supposed to be resolved on the Elites. I won't know for sure until I put it in and transfer the tune. Although I'll also be checking the trigger height so.....guess I won't know for sure what fixes it.
Old 12-28-2017, 10:12 PM   #156
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Originally Posted by kellygnsd View Post
I know we been using that, i am working with Andy who is also the owner of the company, so far been very helpful and been writing me custom firmwares to test out -i think we close to fixing it.
I also want to measure my cam to sensor air gap to see how far i am off since i'm not running stock cams
Bariga is offline   Reply With Quote
Old 03-03-2018, 10:55 PM   #157
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
replaced ****ty Subaru cam sensors with GT101, bought male connector and crimped to sensor and 3d printed spacer with o-ring grove they are pretty much plug and play now.
My engine only has 1 factory sesnor now which is crank lol
So far i really like the new ECU glad i went this route!
Old 03-04-2018, 03:27 PM   #158
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
When are you gonna be up and running?
Old 03-04-2018, 05:55 PM   #159
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
i`m already driving around adjusting VE table, got 300 miles on the motor so far running WG spring pressure 9 psi.
So far i cant tell the difference in spool between my old 7670 IWG and new 8374 EWG, the ewg is very loud so i hope to never hear it by running **** tons of boost
Getting cold starts on E85 perfected, never worked on vipec...
Old 03-04-2018, 08:35 PM   #160
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
That's cause flex due wasn't real flex fuel on the Vipec. The new link G4+ finally had proper flex fuel and VE fuel modeling. Separate cold start parameters for gas, E85 and anything in between.
Old 03-05-2018, 01:10 AM   #161
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
yeah i was looking at g4+ but after checking out modular i was sold
Old 03-11-2018, 12:30 PM   #162
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Old 03-12-2018, 01:37 PM   #163
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Hard to wire up? Any adapter harness needed or used?
Old 03-14-2018, 07:09 PM   #164
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
took me some time to setup the wiring diagram, then it was just super easy crimp the pins and insert them into ecu connectors.
I just used the aem patch harness for $180
Here is all my files.
https://drive.google.com/drive/folde...Zn?usp=sharing
And ill be getting CAN guage soon too
Old 03-15-2018, 02:55 AM   #165
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Nice, I was looking at a few CAN gauges. Not sure which one I like the best.
Old 03-28-2018, 12:18 PM   #166
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Hooked up the CAN gauge, still waiting on pillar
Old 04-08-2018, 05:58 PM   #167
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Changing my ID1300 to ID1700x this week, will probably clip the injectors on E10 @ idle
Here how e10 ID1300 idle on adaptronic
Old 04-13-2018, 11:47 PM   #168
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
What all can you display on that CAN gauge? Do you have access to all ECU parameters?
Old 04-18-2018, 03:19 AM   #169
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
There are like 40 things in there, pretty much everything you will ever need lol.
Old 04-18-2018, 03:24 AM   #170
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Installed the ID1700x's, man this things are garden hoses.
Got the car to idle stable at 13.4:1 afr with 11 degree timing @ 940 rpm on pump gas.
Old 04-30-2018, 10:43 PM   #171
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Installed new ID750 fuel filter and switched rails to -8 AN
Old 05-02-2018, 04:57 AM   #172
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Does the adaptronic have tables for short pulse width adders? I'm about to switch to those myself.
Old 06-05-2018, 12:26 PM   #173
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
The injector settings have minimum flow rate and i don't use pulse width as the ecu does all the thinking.
Old 06-05-2018, 12:37 PM   #174
Bariga
Member#: 179846
07 STi Limited
EFR 8374 TS EWG
Started working on beefing up fuel system. The system will be fully standalone and i will just feed logging into ecu from FPR, will be using wally 450 as lift pump
Radium Jetpump (had none before and ran out of fuel **** ton of times)
Radium surge tank with built in Fuelab prodigy pump 92902 (909 LPH)
Fuelab electronic FPR
Everything is going to be hidden and look stock in the trunk.
Old 06-05-2018, 11:01 PM   #175
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Once you have the jet pump hooked up can you take some pictures please
How loud is the fuel pump? Seems pretty well priced for everything you get
